POV-Ray : Newsgroups : povray.off-topic : New car Server Time
3 Apr 2026 11:07:55 EDT (-0400)
  New car (Message 81 to 90 of 184)
Subject: Re: New car
Date: 4 Feb 2010 13:01:05
Message: <4b6b0b61$1@news.povray.org>
Invisible wrote:
> In the category of "I realise nobody actually gives a damn but I'm going
> to tell you all anyway": I have a new car.
Me too!
http://www.zbxt.net/~aero/saab/sc_front.jpg
http://www.zbxt.net/~aero/saab/sc_back.jpg
> I had a mark-I Renault Megane. I now have a mark-II Renault Megane with
> a bigger engine. (I still have yet to determine *exactly* what model
> I've bought, but it has a 2.0 L petrol engine which may or may not be
> turbocharged.)
I doubt it's not turbocharged.
> - The clutch doesn't enguage until you completely remove your foot from
> the pedal. You can lift the pedal all the way from the floor to almost
> fully released, and you're still not moving. Only in the last 5mm or so
> of travel do you get any power to the wheels.
Traditional French clutch. All the French cars I've drive have had a
clutch like that. It's something I've never got used to.
> - You don't get a key. Instead, you get a huge lump of plastic. If this
> is within 200 yards of the car, all the doors unlock, and the "start"
> button is enabled. (Yes, you actually start the engine by pressing a
> huge "start" button. How stupid is that?)
I wouldn't like the automatic locking/opening, but starting with a
"start" button is pretty logical - as long as you don't separately need
to put the key to the lock (sorry BMW, THAT's plain stupid).
> This means that if I park my car and go shopping, and I happen to walk
> past a shop front that's fairly close to the car park, my car will
> unlock itself and allow anybody who notices and hops in to start the
> engine and drive off.
I'd guess the engine will shut down when you're far enough?
> (Presumably once they get out of range, the engine will stop and they'll
> be locked in? Or maybe it won't - imagine if you were driving the car
> normally and the radio ran out of battery power. Could be quite a safety
> issue!)
Ah yes, if it doesn't load the battery while driving or alert the car
that "hey, my battery is running out, please disable the safety shutdown
feature".
> I still haven't found a way to lock the car yet. Presumably if I walk
> far enough away, it will lock. (But I'll be far away, so I have no way
> of verifying this.)
Try pushing all the buttons! :D
> - Rather than having the normal 4 or the extravagent 5 gears, it has 6.
> I'm not sure why. You'd think they would use this to add more gears to
> the top of the range; but no. They just took the other gears and spaced
> them closer together. In other words, you need to change gear more
> often.
It gives you the possibility to drive more economically - at least in
theory.
> (Which, considering that the clutch doesn't work properly, isn't
> much fun.)
It does. It's just French.
> - It does not appear to be possible to turn the headlights on or off.
> They just turn themselves on or off when they feel like it. (Presumably
> too many French people decided to drive off in the middle of the night
> with no lights on or something?)
That's actually a good thing. Light automation rocks, when you get used
to it you'll hate the German cars without it :-).
> In addition to all this, it has the usual minor stuff that all cars
> have.
Ah yes, "nothing ever works properly". Fix the problems and it'll be a
nicer ride.
> The wipers don't work very well (but then, they never do).
Wait, what? They never do? In the history of me and cars I've had *one*
car with *one* problem on wipers and that was a loose nut on a 14-year
old car!
> The
> brakes are very sharp. (Presumably it just had new brake shoes or
> something.)
New brakes take a part of the glory, but mostly it's just the way the
brakes are built. I too have new brakes, but they aren't oversharp (then
again, I've always liked the feel of Saab's brakes - they just fit my
braking foot).
> It's taken me ages to fiddle with all the mirrors such that
> I can see properly. And so on.
Yes, and to get the seat positioned etc. That always takes some time.
> So it's a rubbish car then?
If it was, would you have bought it?
> Well, not so much. The steering is absurdly light - not sure if that's
> good or bad.
That depends on you and what do you like. I like light but sensitive
steering - Audi had a steering that absorbed the road to itself, even
while it wasn't a light one, I didn't like that, but I assume someone
else does.
> The suspension seems... "better" somehow. The car doesn't
> tip over when it goes around corners, and driving over lumpy roads (or
> just ramps) doesn't shake you around so much. It's better-damped or
> something.
Maybe it's just not worn out yet? Well ok, probably they have had some
time to tune it up, it's not the same model as your previous car, after all.
> I couldn't say whether the 20% bigger engine makes it go any faster,
If it doesn't, it's crap :).
> since I'm constantly in the wrong gear. (I've yet to figure out how to
> access 6th gear. Every time I try I get 4th instead.) Selecting reverse
> is a tad tricky too. I guess I'll get used to it.
You will, you just need to find the 6th first to know how to get there.
-Aero
Date: 4 Feb 2010 13:05:05
Message: <4b6b0c51$1@news.povray.org>
Invisible wrote:
> My 4-gear Peugeot 1.1 seemed happy to do 60 or so in 3rd gear. But then,
> while it had a small engine, it was also pretty light too...
As I think I've mentioned earlier, I have an old Saab 9000 as a hobby.
I've bought a new gearbox to it, having extremely long gears - it will
take 120-130km/h (around 75mph) on 2nd gear before the rev limiter, so
3rd should be somewhere around 170-180km/h (around 105mph) :-). The
figures on standard gearbox are 100km/h (62mph) and 150km/h (93mph). I
can't wait to get to put it in the car :-).
-Aero
Date: 4 Feb 2010 13:11:35
Message: <4b6b0dd7$1@news.povray.org>
Orchid XP v8 wrote:
> (I also don't understand why one of the manouvers they get you to
> demonstrate is reversing around a corner. This has to be the MOST STUPID
> THING EVER. You should NEVER, EVER do this in real life! So... WTF?)
Why not? You can reverse to a parking slot (or out of it) or to a garage
for example.
Try doing it with a trailer :-). After that reversing only the car is
pretty easy...
-Aero
Date: 4 Feb 2010 13:18:49
Message: <4b6b0f89@news.povray.org>
Invisible wrote:
> scott wrote:
>>> However... is it a 2.0 T 16V or a 2.0 VVT?
>>> The documentation from the shop says it's the VVT. The stickers on
>>> the car itself just say "2.0 16V".
I think the VVT means variable valve timing.
>> If you have the turbo you'd probably be able to hear it, speed up to
>> about 3000 rpm in 2nd or 3rd gear, then take your foot off the
>> throttle, you should be able to hear it making a faint high pitch
>> whining noise.
Also roll up to 3krpm and floor it - if it's a turbo, it accelerates
significantly better than the old one did. And I do mean clearly
significantly.
> From what I've seen, if a car has turbo, it constantly makes that
> annoying whistling sound.
No, if a car has a broken turbo, it may do that. A good turbo can also
whistle on certain occasions, but not constantly.
> Also, if you floor it, nothing happens for 4
> seconds, and *then* it takes off like a rocket.
No, if a car has significantly too big turbo and a crappy engine control
system, it lags 4 seconds with nothing happening.
Go ahead and give Saab 9-3 TTiD or BMW 123d a test-drive. They both have
*two* turbos, still no whistle nor mentionable lag.
-Aero
Date: 4 Feb 2010 13:22:45
Message: <4b6b1075$1@news.povray.org>
> for example.
Sure. But we're talking about reversing around a corner, out of one road
and into a side road.
> pretty easy...
Heh. I still have trouble just parking in small spaces. Still, my new
car has a superior turning circle and sharper power steering. (Now if
only selecting reverse wasn't so hard and the clutch worked properly...)
http://blog.orphi.me.uk/
Date: 4 Feb 2010 13:24:50
Message: <4b6b10f2@news.povray.org>
Oh yeah, like they're *really* going to let some college kid test-drive
a £400,000 car. :-P
Still, the only vehicle I've come across that had a turbo was a busted
old Land Rover that was, like, 30 years old or something and rusting
apart... Maybe they've improved since then?
Date: 4 Feb 2010 13:34:09
Message: <4b6b1321@news.povray.org>
> Me too!
...it's grey.
Really?
The turbo version apparently generates an extra 30 BHP.
My previous car (exact same brand and model, just the previous revision)
had a clutch which behaved normally. (Although it was starting to wear
out TBH. One more reason to get rid of it!)
>> of verifying this.)
Turns out the button on the door handle will lock the door - if the key
is in range.
>> much fun.)
[Insert joke here about the legendary tendancy of the French to not work.]
This morning I drove to work on a dark, cloudy day - but the computer
still decided I didn't need my lights on. *I* would have kept them on
anyway...
> old car!
The wipers leave little streaks behind at exactly eye-height [but only
on the driver's side].
The rear wiper only sweeps 10% of the screen in the first place [because
it's conical], and do almost nothing to clear even the area being swept.
And, unlike any other car I've seen, driving at speed seems to somehow
*attract* water to the screen, rather than repel it.
Well, yes. ;-)
So far I haven't been able to climb above 35 MPG - so that's 10 MPG
lower than my old car. :-(
Selecting reverse requires you to pull the little ring. But, unlike my
old car, it's at the opposite end of the stick, which keeps confusing me...
Subject: Re: Manual mayhem
Date: 4 Feb 2010 13:35:14
Message: <4b6b1362$1@news.povray.org>
Invisible wrote:
> First of all, all the diagrams are for a left-hand drive car. You think
> that doesn't matter? Well, the buttons on the central console are the
> other way around on a right-hand drive car. (E.g., the lock and start
> buttons are the other way around.)
Still the gearbox is the same etc, so not everything is mirrored?
> Thirdly, the manual contains endless instances of "if you have this
> option, press button A. Alternatively, if you have this other option,
> press button B." But which freakin option do *I* have?!
If you don't know, you test it.
> My favourit is the manual for the stereo system, which tells you how to
> load and unload CDs from the CD changer, but omits to mention WHERE THIS
> IS! (I have since discovered that I don't actually *have* one - contrary
> to the information given to me when I purchased the car.)
Ask them to lower the price for that or to change a CD-changer to the car.
> I spent 20 minutes trying to find the airbag disable switch on the
> passenger door before I figured out that when they switched the car to
> right-hand drive, they forgot to move the switch. So it's still on the
> right-hand side, it's just that that isn't the passenger side anymore!
Aaahahahaaa :-D
> And another thing. Does anybody remember when if you wanted to fit
> seatbelts, you just went to B&Q, bought some seatbelts, and bolted them
> to the car?
OTOH you now have officially room for 5 passengers (really for 4) and
also seatbelts for 5 passengers. Why would you fit more of them?
> Well of course *this* car has seatbelt pre-tensioners,
> force-limiters, front and side air bags, and who knows what else. So if
> you want to do *anything* to the seats or seatbelts, you have to get a
> qualified Renault engineer to do it.
Isn't it actually a *good* thing that it's a lot safer than your old car?
> Now manufacturers *always* want you to use their own parts. They make
> way more money that way. And I'm pretty sure that no matter what the
> manual says, putting non-approved engine oil into my engine isn't going
> to destroy it (provided that it's of the correct type).
Yep. It just can void the warranty.
> But it seems
> there are so many things on this car that require specialist equipment
> to work on.
Yes, there are.
> You're supposed to get the crash sensors and air bag pyrotechnics
> checked annually - which can only be done by specially-trained Renault
> technitions with specialist equipment.
That's probably in the service program, right?
> Good thing I don't have the Xeon lights though - those have to be
> referred to a qualified service technition due to the high-voltage
> components inside. (Seeing a pattern here yet?)
OTOH you don't need to change xenon bulbs so often. I drove 90Mm's with
the original xenon bulbs on Audi. Just try to do that with halogen.
> And then there's the controls. I think I'm going to have to build a
> flowchart or something. Take one example:
> The control for the wipers has 4 positions, A, B, C and D. In position
> A, the wipers are off. B is intermittent. C is normal speed, and D is
> fast speed. Unless your car is fitted with the automatic wipe option, in
> which case B is intermittent wipe depending on the amount of water
> detected.
Well yes, this is pretty normal.
> [Don't you just love the way *you* have to know what the spec of the car
> is to figure out which instructions apply?]
Yes. The other possibility would be that the manual says that you
*don't* have that one option and then it's added afterwards.
> Mine evidently has the automatic option, since it wipes every 20
> seconds, but now and then it suddenly starts frantically trying to file
> through the glass! o_O
If you have a properly working automatic wiper option, you simply don't
need to touch the lever yourself except for some rare wipe-once
-situations - just keep it in the automatic position.
> This is probably THE single most annoying feature. It's raining, you
> stop at some traffic lights, and suddenly you can't see ANYTHING. Or
> even worse, you stop at a busy junction, trying to find a gap to pull
> out into. This is THE MOST CRITICAL TIME to need to see what's around
> you, but no, your wipers have turned themselves off without your
> permission.
Yes, that sounds stupid.
> Now of course, the lights turn themselves off, not when you stop the
> engine, but when you open the door. So somebody has programmed in a
> feature [I forget how you select it] where the lights stay on for 30
> seconds after you lock the car. (They call it "guide me home" -
> presumably so you can see your front door or something...)
Yes. You can see the lock in your door to fit the key, it's very
practical :-).
> And the middle part of the back seat folds out into a table with cup
> holders. WTF?
If you'll take some nice girl to a car-picnic and it starts to rain, you
can benefit from that table ;-).
-Aero
Subject: Re: Beautiful safety warnings
Date: 4 Feb 2010 13:52:20
Message: <4b6b1764$1@news.povray.org>
Invisible wrote:
> What I liked most was the warning to never put the seatbelt under your
> arm or behind your back. It seems so *ludicrously* obvious that this
> will result in horrifying bodily injury that I cannot believe anybody
> would do something so stupid...
> ...and yet, they bothered to print the warning, so...
That's a warning I'd remove, to let natural selection do its job.
> I also liked the warning to never leave children unattended inside the
> car. Yeah, LIKE ANYBODY IS TAKING ANY NOTICE OF THAT ONE! Still, I guess
> the idea isn't really to keep children safe, but to protect Renault from
> lawsuits. ;-)
I read about a man who had to do something at work on a weekend. It was
supposed to be pretty quick (a 5 minute thing). He was in the car with his
child (presumably to go somewhere else afterwards). He actually spent *three
hours* inside the office. When he came back, the kid was dead.
Temperature inside the car, which was receiving direct and strong sunlight
and had no open windows: 50°C.
Date: 4 Feb 2010 14:01:37
Message: <4b6b1991$1@news.povray.org>
Orchid XP v8 wrote:
> Still, my new
You haven't driven Volvo 940/960 or even 740/760, have you? ;)
-Aero
