POV-Ray : Newsgroups : povray.off-topic : One step closer to Permutation City Server Time
27 Feb 2026 11:31:18 EST (-0500)
  One step closer to Permutation City (Message 1 to 10 of 41)
Subject: One step closer to Permutation City
Date: 14 Dec 2009 12:53:10
Message: <4b267b86$1@news.povray.org>
https://console.aws.amazon.com/ec2/help/spotrequests.html
I always thought that was a very realistic way of working things.
   Human nature dictates that toothpaste tubes spend
   much longer being almost empty than almost full.
Subject: Re: One step closer to Permutation City
Date: 15 Dec 2009 07:26:24
Message: <4b278070$1@news.povray.org>
Permutation City?
This is an interesting move. As I understand it, an Amazon "instance" is
like a virtual machine. So starting and stopping one is quite a lot of
work. Not sure what you'd use a VM that could shut down at any random
second for...
Date: 15 Dec 2009 13:30:37
Message: <4b27d5cd$1@news.povray.org>
> Permutation City?
Yep. In case my late-night comment was confusing (and it was), I meant I
thought Permutation City's fictional depiction of spot prices for
computation sounded very realistic, and here we are a few years later doing
just that.
> work.
It takes a couple of minutes to do so, yes.
> second for...
Hook it to a persistent disk and render an animation? Restart from where you
left off?  If each frame only takes a minute or two and you are rendering a
feature-length animation...
Extra responsiveness to read-mostly queries as long as it's cheap enough?
Date: 15 Dec 2009 16:56:22
Message: <4b280606$1@news.povray.org>
Darren New wrote:
>> Not sure what you'd use a VM that could shut down at any random second
>> for...
> you left off?  If each frame only takes a minute or two and you are
> rendering a feature-length animation...
I guess it hadn't really registered that it's possible to make an
instance immediately start doing work as soon as it boots up. I was
thinking a VM that you're interactively working with isn't much use if
it's going to die any second...
Interestingly, the documentation for DevPay seems to indicate that I
could (for example) create an instance, install POV-Ray, and charge
people money to run this instance, and thereby earn money. I bet it
wouldn't actually work though.
http://blog.orphi.me.uk/
Date: 15 Dec 2009 17:08:00
Message: <4b2808c0@news.povray.org>
Yes. I have an instance that when it boots it looks to see if there's a
backup of the wiki files in S3, and if so it installs them. Then it starts
the wiki server. Every 10 minutes or so, if something has changed it copies
a backup back to S3.  I still have to restart the instance by hand, because
they don't actually die unless I screw it up, but it's not hard to make a
rc.local that runs something.
I am not sure what "work" means here. It apparently has some troubles, but
not that much. I was thinking of making one to run my distributed job
computing software (aka OddJob), but I couldn't figure out all the places
where my S3 password was stored and such, so I didn't keep chasing it.
Date: 16 Dec 2009 04:49:14
Message: <4b28ad1a$1@news.povray.org>
> Yes. It's not hard to make a rc.local that runs something.
...unless you run a Windows instance. ;-)
> but not that much. I was thinking of making one to run my distributed
> job computing software (aka OddJob), but I couldn't figure out all the
> places where my S3 password was stored and such, so I didn't keep
> chasing it.
I'm thinking more about the following:
1. No sane person is going to pay money to run POV-Ray on Amazon when
they could just run it locally on their own PC for free.
2. I have a vague recollection that attempting to do this contravines
the POV-Ray license.
3. If you *were* going to pay money for a POV-Ray rendering engine, you
wouldn't want to log in, start up a VM, copy all your files onto the
server, configure all of POV-Ray's options, set it running, and check it
three times a day to make sure it hasn't finished. (You'll still be
charged if you don't shut it down as soon as the render is done.)
What you'd *actually* want is a button in POV-Ray that says "submit to
server" and it grabs all the files, INI files, etc., zips them into a
big bundle, uploads it, adds it to the server render queue, and emails
you the result when it's finished or something.
As far as I can tell, it's not possible to do this. Or at least, it's
not possible to use DevPay to do this. You'd have to have an instance
running constantly, and you'd have to pay for it whether there's work to
do or not.
Date: 16 Dec 2009 12:30:43
Message: <4b291943$1@news.povray.org>
Then you use the Windows equivalent, which is a service.
Well, no, you have to do more than have just POV-Ray there. For example, you
could have a mechanism where the person sets up the configuration on their
own computer, clicks a button that launches 10 Amazon instances and
distributes frames to them and collects the results, then composes them into
a video when you're done, after shutting down the instances that were rendering.
Right.
> do or not.
I don't understand why you'd say that. It works OK for me. I just never got
around to doing the button that launches the instance, altho having it read
the configuration and go from there works fine.
Date: 16 Dec 2009 15:28:17
Message: <4b2942e1$1@news.povray.org>
Well, yeah, or whatever.
Agreed.
>> to do or not.
As far as I can tell, DevPay lets you earn money for anything that's
just an AMI. If it isn't an AMI, but some application that *runs* an
instance as part of its operation, DevPay isn't applicable.
Date: 16 Dec 2009 20:29:56
Message: <4b298994$1@news.povray.org>
You'd have to launch the instance with your AMI, yes. You get paid for
people running your AMI.
Date: 17 Dec 2009 04:27:09
Message: <4b29f96d$1@news.povray.org>
Granted I haven't read the detailed documentation. But it looks like you
can put together an AMI and list it on Amazon's website with "hey, you
can run this thing for $2/hour". But that would mean that to use your
AMI, somebody would have to select it, start it up, copy their files
onto it, launch POV-Ray and tell it to render.
If you wanted to be able to submit renders from your PC and have them
automatically run, you'd have to have an instance constantly running,
waiting for work to be submitted. Which means that when there's no work
in the queue, you're paying money for an idle instance to run. And even
when there is work, DevPay doesn't appear to offer a way to charge money
for submitting a job to a queue, only for physically starting an AMI.
Assuming I've understood the documentation correctly anyway...
