POV-Ray : Newsgroups : povray.off-topic : Encrypted drive problem Server Time
15 May 2026 07:09:42 EDT (-0400)
  Encrypted drive problem (Message 11 to 20 of 37)
Subject: Re: Encrypted drive problem
Date: 5 Dec 2009 08:58:06
Message: <4b1a66ee@news.povray.org>
>> The issue is that most people have their Outlook pst files as their
>> most valuable posession, and to backup the pst files you need to quit
>> Outlook
> Not true. Just make a shadow copy, and back up the shadow copy. It's
> pretty easy.
OOC, how do you actually do this?
http://blog.orphi.me.uk/
Date: 5 Dec 2009 12:46:25
Message: <4b1a9c71@news.povray.org>
>>> Outlook
>> pretty easy.
The only trick is that vshadow will make a shadow copy, and then delete it
when your script exits. So this sets up some environment variables and calls
vshadow -nw -p -script=XYZ.bat -exec=PDQ.bat c:
That creates a shadow copy of C:, writes  bunch of environment variables
into XYZ.bat that describes where it put the shadow copy, then runs PDQ.bat.
In this case, the script that invokes vshadow is the PDQ script, so after it
invokes vshadow, it sources the temporary script to set the environment
variables[1] and deletes it and goes to the end of the script. At the
beginning, it tests if we're in the callback (looking at CALLBACK_SCRIPT)
and goes to IS_CALLBACK if so. (This obviously would have been more clear as
two scripts, but I never really expected to write a tutorial about it.)
If it's running as the callback, it sources the generated script full of
environment variables, calls vshadow again to connect SHADOW_ID_1 to B:. It
then runs robocopy to back up \users\darren to m:\darren with robocopy.
When robocopy finishes, it falls off the end of the script, which returns to
the first callback, which sources the environment variables into *that*
script and jumps to EOF, which then invokes vshadow to delete the shadow
copy (which also unhooks B: from anything).
Kind of convoluted, but as you might guess, I'm not the original author.
Looking at it again, I realize what one really wants is to just stick :EOF
after the first invocation and be done, and let the return delete the shadow
copy.
[1] MS clearly hasn't caught on to the whole "environment variables get
passed in memory" concept yet.
   Human nature dictates that toothpaste tubes spend
   much longer being almost empty than almost full.
Download 'backup darren.bat.txt' (3 KB)
Date: 7 Dec 2009 02:35:06
Message: <4b1cb02a@news.povray.org>
> pretty easy.
OK will check your later post in more detail on how to do this - could be
very useful.
>> - not many people here like having Outlook turned off for 30 mins while
>> several Gbs of files are copied to the server each day.
> What, they don't go to sleep?
Nearly everyone here takes their laptop home with them each night, and I
don't know how many of them would leave their laptop on every night "just"
to do backups.  Besides, home internet is usually very limited upstream,
it's going to take a while.
Date: 7 Dec 2009 11:04:34
Message: <4b1d2792$1@news.povray.org>
>> pretty easy.
> be very useful.
Yah.
> "just" to do backups.
So have a script they start before they turn it off at night that does the
backup then shuts down the machine.
Or tell them that if they break the computer, they lose all the work they
did since last time they left it at work. Their choice. :-)
> upstream, it's going to take a while.
You only have to move changed files. How much are they going to change when
they take it home after work and before sleep?
Date: 7 Dec 2009 11:15:02
Message: <4b1d2a06$1@news.povray.org>
That's a good idea.
> when they take it home after work and before sleep?
I imagine they are only going to change a few emails, but some people have
sevreal multi-GB pst files for Outlook which I guess would need to be sent
to the server even if they are 99% the same?
Anyway, it seems as if the volume copy solution will work.  I was playing
about today and seems as if even a few PST files making up 10 GB will copy
within a few minutes to our server here - while Outlook was running with
them open.
Date: 7 Dec 2009 11:28:19
Message: <4b1d2d23$1@news.povray.org>
>>> pretty easy.
> it when your script exits. [...]
So vshadow is the tool for working with Shadow Copy?
http://msdn.microsoft.com/en-us/library/bb530725%28VS.85%29.aspx
OK, I've never heard of this tool before. Time to start reading...
Date: 7 Dec 2009 11:30:19
Message: <4b1d2d9b$1@news.povray.org>
>> the backup then shuts down the machine.
> That's a good idea.
BTDT. :-)
> have sevreal multi-GB pst files for Outlook which I guess would need to
> be sent to the server even if they are 99% the same?
Uhhh. Probably, yeah. I'm not sure if you're using Exchange why you'd be
storing the definitive version of .pst files on the laptop. Why not store
them on the exchange server?
The unix rsync utility has the capability of doing a checksum of the
destination file and of the beginning of the source file and only copying
the end if those two checksums are the same.  If Outlook mostly appends, you
might want to consider something like this.
I'm glad. It's a bit of a bugger to track down vshadow.exe, but it sounds
like you got it going. The /Z option to robocopy is handy too.
Date: 7 Dec 2009 11:32:53
Message: <4b1d2e35$1@news.povray.org>
Well, it's the command-line utility for it. Most people code the API calls
into their program, but if you just want shell scripts, you can use the
sample command-line utility out of the resource kit, which is called vshadow.
It's a bit annoying to find the executables, but it is free. I suspect you
need different versions for different OSes.
Date: 7 Dec 2009 12:01:20
Message: <4b1d34e0@news.povray.org>
> store them on the exchange server?
And if using $something_else, just use IMAP and you'll have copies of
mails at the server.
-Aero
Date: 7 Dec 2009 16:16:40
Message: <4b1d70b8$1@news.povray.org>
> calls into their program, but if you just want shell scripts, you can
> use the sample command-line utility out of the resource kit, which is
> called vshadow.
> you need different versions for different OSes.
Right. So what you're saying is that when you use a real backup product,
it probably uses VSS to do its work without stopping people using their
stuff? (But you can also use vshadow if you have nothing better...)
