![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: And you thought flash was only good for youtube.
Date: 29 Nov 2009 11:53:56
Message: <4b12a724@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Nicolas Alvarez wrote:
> HTML5 is not W3C.
Even worse. :-)
Human nature dictates that toothpaste tubes spend
much longer being almost empty than almost full.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 29 Nov 2009 11:56:57
Message: <4b12a7d9$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Warp wrote:
> It's a piece of software (or hardware, if we are technical).
It is, technically, the inverse of a modem. A modem takes a digital signal
and modulates/demodulates it to make it analog. A codec takes an analog
signal and codes/decodes it to make it digital. Hence, it's not the
standard, but the device or process of following the standards.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 29 Nov 2009 11:57:54
Message: <4b12a812$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Warp wrote:
> Eero Ahonen <aer### [at] removethis zbxt net invalid> wrote:
>> And when it's a piece of hardware, it most probably is a piece on
>> software on that hardware ;-).
> With simpler codecs it could be hardwired, so no software.
The old "voice scramblers" were that way: a comb filter to select out a
bunch of frequencies, frequency shiufters to move them around, and then
something to combine them up again.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 29 Nov 2009 12:02:16
Message: <4b12a918$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> the ad-hoc made-up stuff that browser implementors come up with is a
>> nightmare.
> In part because W3C has a broken standards process that fails to account
> for how the world actually works.
Care to explain that one?
(I have no idea what the W3C standards process is. I just read the specs.)
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 29 Nov 2009 12:14:13
Message: <4b12abe5@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Darren New wrote:
> If you said "nothing becomes an official web standard until three
> browsers implement it identically", you by definition wouldn't have this
> problem.
You also by definition wouldn't have any standards in the first place,
because nobody would ever implement anything even slightly similarly.
> When's the last time you said "My ftp server won't talk to your FTP
> client"? Why? Because there were several interoperative implementations
> *before* it was a standard.
Have you *seen* the FTP spec? Sure it works, but it's _horrible_! >_<
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 29 Nov 2009 12:45:14
Message: <4b12b32a$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Not true. Look at the IETF spec process. There are proposed standards that
just don't become standards until several people have implemented it
similarly enough that they interoperate in all the ways required by the spec.
W3C looks at what's going on, says "this would be a better way, so everyone
should change how they work things."
It's actually not too bad, overall. And it has evolved over time. It's *way*
better than HTTP for example.
Even so, put it this way: How many browsers can't get to the web server
(HTTP, an IETF standard), compared to the number of browsers that render the
page incorrectly (HTML, a W3C standard)?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 29 Nov 2009 12:46:51
Message: <4b12b38b$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> nightmare.
>> account for how the world actually works.
They make stuff up, and then try to claim it's the standard. It's broken
because there's no good reason for browsers that have already implemented
things differently than what W3C later standardizes on to change.
Right. And what reason do you have to believe that *anyone* does or will
follow those specs?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 29 Nov 2009 20:06:25
Message: <4b131a91$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> *before* it was a standard. Sure, sometimes you get a mess like email
> address parsing, but that's the price you pay for interoperability.
On a related side note.. Wish the twits would standardize all their
bloody download redirects, which they now all seem to bloody use, for no
apparent reason, on 90% of the sites which plugins/programs that attempt
to help download, or redirect to a more reliable manager, or just do
anything beyond passing the file to the browsers ftp/http file transfer
system. A few have mangled things so badly you can't even *get* a file
from them if you have something installed, about 50% of them you can't
use the normal "just click", or wait for their page to script load it,
because it triggers a set of events in things like FlashGot, which
results in the download not even starting, and then, in about 20% of
cases, and this "never" happened until the last 1-2 years, you get the
file downloaded, but the "name" passed to the downloader is wrong. I.e.,
you end up with something like:
local name source
get.php www.somefileserver.dum/files/realname.zip
Part of this is the fault of the manager, mind you, which doesn't check
to make sure the destination name and the source are the same, but
seriously.. This isn't being done, as near as I can tell, to undermine
download managers or plugins, its designed to help the site track who is
downloading, in most cases, and its getting continuously worse over
time. And if it was an issue with trying to stop things like getright,
why not make a client with "most" of the same features, provide some
standard way to say, "This can't be downloaded via multiple
connections.", which is usually the problem they are trying to stop, or
just *leave out* that feature, and make it work with every damn site?
Problem solved. Instead you have unreliable managers in the browsers,
which can and *have* failed to properly download a file on me, resume,
if they even do that, unreliably, can't keep running if you close the
browser, and provide "no" other features at all, including warning you
of non-unique names, or redirecting specific file types to specific
folders, or anything else that a real manager provides.
File transfers that don't involve a bare client, or bittorrent, are
becoming increasingly stupid and unusable.
void main () {
If Schrödingers_cat is alive or version > 98 {
if version = "Vista" {
call slow_by_half();
call DRM_everything();
call functional_code();
else
call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 30 Nov 2009 04:04:55
Message: <4b138ab7$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> specs.)
> follow those specs?
So what you're saying is that we should let somebody make up some
mangled mess of a system, and then stamp it as a "standard", rather than
designing something properly?
Stuff like making something like Flash a standard rather than designing
SVG? And the single proprietry implementation should be the standard spec?
Isn't that exactly why everybody's so upset with the MS document "standard"?
(Not that your claims are unfounded - AFAIK, nobody has implemented the
CSS3 drop shadow properties, for example. But then, that's a fairly
dubious feature in the first place...)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 30 Nov 2009 10:50:42
Message: <4b13e9d2$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> specs.)
>> will follow those specs?
No. I'm saying that if you're going to standardize something, you should
either standardize what people are already doing, or standardize what people
aren't yet doing, rather than trying to "standardize" what people are
already doing but in a different way.
And when you're trying to standardize communication mechanisms, you should
probably strive to ensure interoperability, given that it's, you know,
communication and all that.
> "standard"?
You obviously missed the part where I mentions "multiple inteoperating
implementations available to the public", right?
That's exactly my point. Nobody follows the standard because they're
prescriptive and made up out of whole cloth.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
