POV-Ray : Newsgroups : povray.off-topic : Trivial trigonometry Server Time
5 Jul 2026 03:43:22 EDT (-0400)
  Trivial trigonometry (Message 121 to 130 of 178)
Subject: Re: Trivial trigonometry
Date: 2 Dec 2009 11:49:48
Message: <4b169aac$1@news.povray.org>
Warp wrote:
>   That's the kind of "observation" I don't understand.
They're still working on that one.  Someone recently proposed it's actually
gravity waves causing the "collapse", which is why it doesn't happen until
you get enough particles that gravity becomes significant. Or some such.
That's another one of those "nobody is sure why yet" kind of things.
   Human nature dictates that toothpaste tubes spend
   much longer being almost empty than almost full.
Date: 2 Dec 2009 11:51:27
Message: <4b169b0f$1@news.povray.org>
Warp wrote:
>   It was not sarcasm, it was puzzlement.
I will keep that in mind, then. :-)
Generally speaking, as a native speaker of English, when you express
something like that as a statement rather than a question, it comes across
with an invisible "Yeah, right, pull the other one" kind of statement. At
least to me.  Just so ya know.
Date: 2 Dec 2009 12:14:28
Message: <4b16a074@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> >> No. The "interference" is caused not by the particle, but by the slits.
> >   How does the photon know there was another slit nearby, and behave
> > differently if that was so?
> Nobody knows.
  But it seems that everybody knows that it does not happen by the photon
going through both slits?
  (After all, it would make sense: If there's no other slit to go through,
then it can't go through two slits, and thus its behavior is different than
if there was another slit and it went through both.)
  Or is this again that kind of almost-supernatural phenomena like the
photon somehow knowing that one year from now it will be measured which
slit it went through and thus it will already know to not to produce the
interference pattern?
Date: 2 Dec 2009 13:49:51
Message: <4b16b6cf$1@news.povray.org>
>> Nobody knows.
Correct.  Or, rather, nobody has ever measured anything that would imply the
photon goes through both slits as a wave. Nobody has ever measured the
actual wave-like nature of photons, other than that the probability you
measure one of those particles at a particular place shares much of the same
math as waves. (The probability that *two* photons do something does *not*
share the same math as waves.)
The photon, in some very rare cases, might go through both slits, but not at
the same time as a wave. Instead, it might actually go in a circle and go
through both. But it's vanishingly improbable, and maybe even impossible if
the probabilities actually add up to zero.
Essentially, every single time you find a photon, you find an entire photon.
There's never a case where you get a half a photon. Hence the "quantum"
nature of it all. You don't get half a photon just like you never ever find
an electron with half a charge, and just like you don't find a coin that
comes up half heads half tails. The only "interference" you get is patterns
when you measure where lots of photons go.
But it only goes through one slit if you measure which slit it went thru.
This is true even *if* you make the measurement *after* the slits. You never
see the photon going through both slits, like you would if it were actually
a wave.
Again, it's not a question of one photon making an interference pattern.
It's a bunch of photons making an interference pattern. Any one photon shows
up all at once and makes a single discrete mark wherever it hits. It's just
more likely to hit in one area than another.
It's sort of like saying that at a sufficiently small scale, there aren't
waves in water either. If there's a "high" wave, you're more likely to see a
molecule of H2O high above the average surface level than if there's a
trough. You can calculate the probability of H2O molecules being in a
particular place, but you're never going to see an H2O molecule interfering
with itself. (At least, not in the "classic" size of water waves.) You can
ask "how does the beach get more wet near the waterline than higher up if
water isn't waves?" It's because you're more likely to find an H2O molecule
close to the waterline than higher up the beach. But that doesn't mean H2O
is made out of waves.
But in short, yes, it's the same weirdness, which is how people know it's
not waves per se. Being a wave would imply it's actually the photon itself
that's controlling where it goes. But we already know you can control where
the photon goes retroactively, which would obviously make no sense if it was
deciding based on being a wave. If it's interfering *because* it is going
through both slits, you wouldn't be able to change whether it went thru both
slits or not after it already hit the detector. There's something deeply
unintuitive going on that nobody understands.
BTW, it's also pretty easy to prove it's not something in the photon that we
can't measure controlling how it works. That's what Bell's Inequality is about.
Date: 2 Dec 2009 15:05:18
Message: <4b16c87d@news.povray.org>
  The interference pattern in the detector is not a measurement?
  But I thought that's the whole idea in the Copenhagen interpretation:
Particles are in superpositions until they are measured, in which case
they collapse into a definite state. Thus when you measure a photon, you
will always find a collapsed photon.
> a wave.
  You also never see the cat in both live and dead states at the same time.
  Of course I implied that you perform the test many times and see the overall
pattern that the photons create.
Date: 2 Dec 2009 15:17:44
Message: <4b16cb68@news.povray.org>
No. It's a bunch of individual measurements of different photons. There's no
way to look at *one* photon and decide whether there was one slit or two.
Because it's not a wave, it's a particle, so it always makes the same sort
of single-spot quantum event in a single place.
If every time one measures something, one gets "it isn't a wave", then why
would one think it's ever a wave?
Particle *probabilities* are in superpositions. That doesn't make them waves.
But again, this is a question of "why does it work that way", and not "how
does it work", and AFAIK nobody knows the underlying reason why the
probabilities work out the way they do.
>> a wave.
That's actually evidence for it being particles and *not* waves. :-)
Yes. But if a photon was a wave, it could interfere with *itself*. It could
split up and go through two separate slits. One photon doesn't make an
interference pattern, and that's how you know the photon isn't a wave. You
don't see half the photon's energy hit here and half hit there with a blank
spot in the middle.
Date: 2 Dec 2009 15:38:41
Message: <4b16d050@news.povray.org>
  That's like saying that you can't measure the probability of a coin
giving heads because you can only toss one coin at a time.
  I'd say tossing 100 coins one after another is exactly as valid as if you
had tossed one coin 100 times simultaneously (if that was physically possible).
  Because of the interference pattern?
  If it behaves like a wave, what can we deduce from that?
> >> a wave.
  It's an argument that measurement doesn't necessarily tell what was the
state before the measurement was performed.
  That just doesn't convince me. Just because the photon collapses when it
hits the detector doesn't mean that on the way it didn't pass through both
slits at the same time and interfered with itself.
  It sounds like you are arguing that particles cannot be in superimposed
states and that there's no collapse phenomenon when they are measured, but
instead they are always at single places at a time, in particle form. In
other words, that the Copenhagen interpretation is wrong. (Of course, if
I have understood correctly, nobody has proven that it's right, but you
are seemingly claiming it's wrong. Has that been proven?)
  (Not that I have the slightest idea what I'm talking about. The problem
I'm having is that, seemingly, people have no idea why the interference
pattern appears yet are completely sure it's *not* because photons are
in wave state at any point.)
> You
> spot in the middle.
  You don't see it because if you try to see it, the photon collapses and
the only thing you see is a particle.
Date: 2 Dec 2009 16:21:12
Message: <4b16da48$1@news.povray.org>
Warp wrote:
> Patrick Elliott <sel### [at] npgcablecom> wrote:
>> Warp wrote:
>>> when the state of the particle is "observed" (whatever that might mean)
>> Merely that you have done something to it which changes its unknown
>> state, usually causing it to make contact with another particle(s), such
>> as a detector.
>   I think the Copenhagen interpretation goes beyond that. If the decay of
> the radioactive substance causes the flask to be broken, killing the cat,
> it has already been "observed" (by whatever detector caused the flask to
> be broken) and thus there are no superimposed states, but according to
> the Copenhagen interpretation there are, until some external observer opens
> the box.
But, the Copenhagen interpretation is intended as an example, where by
the "mechanism" isn't part of the system that causes the observation.
The presumption being that what ever opens the box to look is what
*causes* the result. It was never intended to be used to imply that the
state in such a box could/does exist in the real world. In short, you
are exaggerating the meaning of the example. There may be others doing
so too, but most understand that the *entire box*, and the cat inside,
is the particle, and that the observer is basically what ever "looks"
into the box to see what happened, which could be an X-Ray machine, for
all that it matters, or a guy with a crowbar, or just some single
particle, shot at the box, which "quantum tunnels" through the inside,
and other the other, carrying some information on the state inside. The
*observer* is never a conscious observer, it is always, "What ever
happens to interact with the particle, causing it to change."
And, if you think about it, it can't be otherwise. If you observe a
particle with a detector, the detector "causes" the state change. Turn
on a flashlight, photons cause the state change. There is no way to
*observe* an object that doesn't involve us hitting the particle with
another particle, and measuring what the change in *that* particle is,
thereby deriving what happened to the other one. All Copenhagen really
says is, "If nothing is interacting with the particle, the particle's
state isn't known, but the moment something does (which they confusingly
termed "observer"), the state becomes fixed." Its sort of like the way
normal people use "theory" to mean guess, but scientists mean, "already
supported by evidence". "Observer" doesn't mean what the average person
would mean by it. Imho, it was a really poor choice, but we are, at this
point, stuck with it. lol
void main () {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 2 Dec 2009 16:27:14
Message: <4b16dbb2$1@news.povray.org>
> actually gravity waves causing the "collapse", which is why it doesn't
> happen until you get enough particles that gravity becomes significant.
> Or some such.
Ok. Already gave and answer to why this is odd, but.. Just to let you
clarify - How do you "measure" or "observe" what a particle as even
done, without colliding it with something? What process do you use that
doesn't involve a "state change" resulting directly from a scientific
instrument *causing* the state to change? There isn't one, so the
Copenhagen interpretation can't be arguing that "looking at something",
without actually, you know... "looking at it", does anything. By
definition, anything you can/do do, which looks at a particle, involves
*other particles*, so I am unclear what the heck either one of you are
claiming is different here from any other sort of quantum physics.
Again, we can't measure/observe a particle, without interacting with it,
so claiming that "changing" it by observation differs from changing it
by hitting it with another particle is just... not making any sense at all.
void main () {
   If Schrödingers_cat is alive or version > 98 {
   else
Date: 2 Dec 2009 16:28:47
Message: <4b16dc0f@news.povray.org>
No. It's like saying a coin doesn't land half-heads-half-tails. You can
certainly measure the *probability* of a photon hitting in a particular
place. That doesn't mean the photon is or ever was a wave.
Yes. And even tho you get about half heads and about half tails, not a
single one of those coins wound up with half the heads showing or half the
tails showing. They were all either 100% heads or 100% tails, when you look
at each one individually.
Similarly, each photon is a particle, and it never goes through both slits,
just like a coin never lands 50% heads and 50% tails.
There's one set of measurements that give the same probabilities as if the
photons were propagating as waves. But there's also other ways to explain
the interference pattern (mathematically speaking) that has the same
arithmetic but a different interpretation. This different interpretation is
consistent with *all* the measurements.
It's like looking up at the sky and saying "The sun goes around the earth,
obviously."  But yes, maybe the earth goes around the sun, and you'd get the
same appearance as the sun, but if you look at other *planets* you can tell
they're all going around the sun.
If you flip 1000 coins, and it comes up 500 heads and 500 tails, can we
deduce that each flip landed half heads half tails?
But *no* measurement *ever* detects waves. They only detect distributions of
particles that match the mathematics of complex numbers. Waves also match
the mathematics of complex numbers. But not everything that matches the
mathematics of complex numbers is a wave.
Well, you're arguing the question that has confused nobel-prize-winning
physicists. I can only try to explain what I understand them to say. I can't
really convince you per se.
Nobody can figure out what would cause a "collapse", nobody has math that
explains when the collapse happens, nobody has ever observed a particle in a
non-collapsed state.
> states
No, I'm saying they aren't waves. What's superimposed isn't a "wave", but
probabilities. Yes, particles are in superimposed states. That doesn't make
them waves. Since the states particles can be superimposed and tangled up
with the states of other particles, and that tangling does *not* act like a
wave, then it's experimentally determined that superimposed states aren't
waves either. It only looks like a wave if you look at one of them.
That's not what I said. You only ever *measure* them in a single place at a
single time in particle form. How would you really know what it's doing if
you never observe it doing it?
There are theoretical reasons to believe it's impossible to observe them
being waves. (Otherwise, they wouldn't be quantum, for example.) Indeed, the
whole "black body radiation" question that started quantum physics falls
down if photons are waves in flight, which is why people stopped thinking
they were waves in the first place: it was impossible to understand
something glowing hot if light is waves.
I think people are still debating, but as far as I know, all the really
smartest people think quantum theory comes in quantums. :-) The whole
problem with the Copenhagen interpretation is that nobody knows why it would
collapse, nobody has any math to explain the collapse, and it doesn't give
you any answer better than you get with "it's never a wave", especially
without being able to explain why it collapses.
Maybe if someone knew what caused the collapse, or under what circumstances
it happened, you could test if Copenhagen was valid or not. But it doesn't
make any predictions the always-a-particle theory makes.
They know because when you actually put *two* photons together, they *don't*
make an interference pattern. If photons were waves, you wouldn't get
lasers, for example. And they wouldn't interact with electrons in the way
they do, even when you're not "observing" them.
I may have no idea if you start out in your automobile in your driveway
where you got to, but I'm pretty sure you didn't drive to Hawai'i. :-)
>> You
>> spot in the middle.
I think it's Occam's Razor here. Why postulate a quantum being a wave if (1)
no observation is capable of ever seeing it as a wave, (2) it behaves in
ways contrary to it being a wave when in flight, and (3) everything you *do*
see can be explained without it ever being a wave?
