POV-Ray : Newsgroups : povray.off-topic : Lazy SUSE Server Time
13 Sep 2025 02:19:02 EDT (-0400)
  Lazy SUSE (Message 1 to 7 of 7)
Subject: Lazy SUSE
Date: 22 Nov 2009 03:45:34
Message: <4b08fa2e$1@news.povray.org>
Now this is interesting:
If the tools that come with openSUSE 11.2 are right, then on my AMD
Phenom QuadCore box single-threaded apps (e.g. MegaPOV or MCPov ;-))
perform doubly poor (or actually something around 6.5-fold): Not only do
they use just 25% of the total available processing power - by their
failure to do so they also motivate some instance in the system to
further reduce that total, by throttling the CPU clock from 2.3 GHz to
as low as 1.4 GHz (actually 1.15 GHz when idle)...
Does someone have an idea whether this is controlled by the OS or by the
CPU itself - and where I could turn it off?
Subject: Re: Lazy SUSE
Date: 22 Nov 2009 04:17:02
Message: <4b09018e@news.povray.org>
  Isn't that the correct number for a single-threaded app running on a
quad-core?
> - by their
  Are you sure it's not doing that because of overheating instead?
Date: 22 Nov 2009 05:00:40
Message: <4b090bc8$1@news.povray.org>
> quad-core?
Yes - so far, so good...
>> - by their
Pretty bloody likely not, as the CPU clock indicator goes /up/ when load
increases - not the typical reaction to thermal issues, is it? :-P
But I found the solution to the riddle: What I saw was only the
/average/ clock; when not under full load, openSUSE will apparently put
some of the cores in a kind of standby mode, throttling their clock to
half speed, while happily running the processor-hungry single-thread app
on some other core still clocked at full speed.
Subject: Seperates clocks for separate cores?
Date: 22 Nov 2009 16:00:00
Message: <4b09a650@news.povray.org>
> But I found the solution to the riddle: What I saw was only the /average/
> clock; when not under full load, openSUSE will apparently put some of the
> cores in a kind of standby mode, throttling their clock to half speed,
> while happily running the processor-hungry single-thread app on some other
Is it really possible to put individual cores into standby or clock a core
individually?
Is this a feature of AMD or does it work with Intel, too?
What about Intel Quadcores, which are basically two double cores?
Subject: Re: Seperates clocks for separate cores?
Date: 22 Nov 2009 16:31:33
Message: <4b09adb5$1@news.povray.org>
> individually?
There's no reason it couldn't be. The parts in your cell phone all have
individually-controlled power so they can be turned off for the miliseconds
you're not using them to make the battery last longer. I wouldn't be
surprised if people worried about it enough (at least the heat if not the
power consumption) that Intel went and added such to the separate cores.
   Is God willing to prevent naglams, but unable?
     Then he is not omnipotent.
   Is he able, but not willing, to prevent naglams?
     Then he is malevolent.
Date: 22 Nov 2009 23:15:35
Message: <4b0a0c67$1@news.povray.org>
> miliseconds you're not using them to make the battery last longer. I
> wouldn't be surprised if people worried about it enough (at least the
> heat if not the power consumption) that Intel went and added such to the
> separate cores.
Well, my laptop from early 2007 (C2D T5600) could do it. I could even
fix the other core to run at 1GHz and let the other one throttle between
1 and 1,83GHz due to need of cycles.
So yes, I'd it's common on today's processors.
-Aero
Date: 22 Nov 2009 23:39:20
Message: <4b0a11f8$1@news.povray.org>
> individually?
Apparently so. If the interface to the other CPU components run at a
different frequency than the cores anyway, then it should actually be
quite straightforward.
 From what I see on the internet, Intel CPUs can do the same only for
pairs of cores (at least with the CoreDuo technology). They have some
alternative called "duty cycle modulation" though, in which they appear
to stall a core comletely at regular intervals; maybe they can do that
for individual cores, too.
(Random fun fact: At the frequencies modern CPU cores run at, signals
can travel no faster than about 10-15 cm per clock cycle: Anything
faster than that would exceed the vacuum speed of light.)
