POV-Ray : Newsgroups : povray.off-topic : Yet another reason why they shouldn't grant software patents Server Time
4 Jul 2026 09:46:27 EDT (-0400)
  Yet another reason why they shouldn't grant software patents (Message 62 to 71 of 81)
Subject: Re: Yet another reason why they shouldn't grant software patents
Date: 22 Nov 2009 16:07:26
Message: <4b09a80e$1@news.povray.org>
Darren New wrote:
> Patrick Elliott wrote:
>> Darren New wrote:
>>> People don't patent algorithms. They either patent computer hardware
>>> that accomplishes a task, or they patent an algorithm applied to
>>> accomplish a specific task.
>> In which you just contradicted yourself. Specific tasks are not relevant.
> They're very relevant.
>  > X + Y = Z is a specific task too,
> No, that would be a mathematical formula, which is not patentable.
> Tell me, are you actually educated in this field? Have you personally
> ever talked to a patent lawyer and had them explain how the patent
> system works? Or are you just reading groklaw and thinking that tells
> you how to be a patent lawyer?
> Because what you're saying leads me to believe you haven't any idea what
> you're talking about.
There is also a saying, "The surest way for someone to not understand
something is for their paycheck to be based on failing to understand
it." I think some of these patent lawyers are falling pray to this
problem. Same with most of the people writing a lot of these patents. If
there must be a range for which it does apply, and this isn't at all
certain, given the speed and nature of computer development and rapid
turn over of applications, then it has got to be a **lot** narrower than
what is being applied. And, you are missing my point again. Yes, what I
gave as an example is a mathematical formula, but the rules don't
require that it be a formula, just that it have the same attributes as one.
But, what ever. Our arguments on the matter are not going to define
where the lines get drawn.
void main () {
   If Schrödingers_cat is alive or version > 98 {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 22 Nov 2009 16:10:30
Message: <4b09a8c6$1@news.povray.org>
>> Well, then don't. I consider the wording, no matter what it says, to
>> be little more than slight of hand.
> Welcome to the legal system!
>> This differs how from say, computing the area of a circle, using the
>> "data" out of the prior step, in which you determined the circumference?
> That's a mathematical formula. Applying that formula in order to
> calculate how far to turn the wheel as you go around a corner in order
> to reduce the wear on tire treads of your car? That's patentable. See
> the difference?
Yeah, you are doing *more* calculations. Its still, "Take data, feed it
into formulas, get a correct result.", and you are still just taking
data from X, feeding it into Y, then into Z, to get the end result. You
want to built a machine to do that, find. You build an algorithm to do
that, its not part of the machine, nor is the machine... Oh, hell.
Forget it...
void main () {
   else
Date: 22 Nov 2009 16:27:36
Message: <4b09acc8@news.povray.org>
> it."
Yet, oddly enough, we have an adversarial court system, wherein if you don't
understand something about the law, you tend to lose your cases.
I'm not arguing that.
Yes. And a formula for a circle doesn't have the same attributes as a method
for calculating how much torque to apply to a differential to reduce the
tread wear of your tires, given that the motion of the gears is approximated
by a circle closely enough that you can apply the formula that you can't
otherwise patent.
You're arguing that you're right, except for the details. I'm saying the
details matter.
That's what I've been saying.
   Is God willing to prevent naglams, but unable?
     Then he is not omnipotent.
   Is he able, but not willing, to prevent naglams?
     Then he is malevolent.
Date: 22 Nov 2009 16:28:57
Message: <4b09ad19@news.povray.org>
No, you're not. The end result isn't useful unless it *actually* reduces the
wear in your tires. You can calculate all the discrete logarithms you want,
but unless you establish a process of communication, you're not doing public
key encryption.
Date: 23 Nov 2009 14:21:49
Message: <4b0ae0cd$1@news.povray.org>
>> it into formulas, get a correct result.", and you are still just
>> taking data from X, feeding it into Y, then into Z, to get the end
>> result.
> the wear in your tires. You can calculate all the discrete logarithms
> you want, but unless you establish a process of communication, you're
> not doing public key encryption.
The end result isn't useful in algorithms unless its "correct". In this
case, "correct" means you got the answer you wanted, not something else.
But, thought we where dropping this. lol
void main () {
   else
Date: 23 Nov 2009 16:28:06
Message: <4b0afe66@news.povray.org>
Since at this point you seem to be *intentionally* missing the point, sure.
Date: 25 Nov 2009 00:16:59
Message: <4b0cbdcb@news.povray.org>
Intentionally? I think I will refrain from making the same accusation...
Seriously though, this reminds me of a discussion I had one day with a
guy that was going to college for Electronic Engineering, at the same
time I was taking Computer Information Systems, on approaches to AI and
what we thought would actually work. We spent like 3 hours dancing
around each others definitions and statements, without once realizing
that there was no real core difference in our position. It took stepping
back on my part and presenting a redefinition of the problem.
In our case.. I am not sure I could come up with a redefinition that
wouldn't dig the hole deeper. The ball would therefor seem to be in your
court, if you wanted to continue, but, unfortunately, the last few
attempts you made to describe what you thought "my" position was
where... Lets just say you where reading things between the lines that
didn't even involve the same book, never mind printing date. I think we
are perhaps both badly misunderstanding each other.
void main () {
   else
Date: 25 Nov 2009 00:37:13
Message: <4b0cc289@news.povray.org>
That was a complement. :-)
> I think we are perhaps both badly misunderstanding each other.
Perhaps. I think you're still talking about "should" and I'm still talking
about "is". I'm not advocating that software *should* be patentable. I'm
simply saying that right now it is, and I find your assertion that everyone
including every lawyer on both sides of the argument and all the judges and
patent examiners are colluding to "forget" that some things aren't
patentable seems far-fetched.
Discussing the "should" of it might be interesting, but only with someone
willing to discuss shades of grey.
   You know the kamikaze monsters in Serious Sam
     with the bombs for hands, that go AAAAAHHHHHHHH!
   I want that for a ring tone.
Date: 25 Nov 2009 14:35:17
Message: <4b0d86f5$1@news.povray.org>
> talking about "is". I'm not advocating that software *should* be
> patentable. I'm simply saying that right now it is, and I find your
> assertion that everyone including every lawyer on both sides of the
> argument and all the judges and patent examiners are colluding to
> "forget" that some things aren't patentable seems far-fetched.
> someone willing to discuss shades of grey.
Well. In a sense you are correct. It is a should. But its a "should"
based on a reasonable argument about the nature of software and
"existing" definitions of what is excluded. The argument isn't that
there is collusion, its that the nature of software is sufficiently
complex that one can't simply expect patent lawyers, or judges, to have
a clear understanding of what it *is*, and under such conditions, its
all too easy to create a long series of cases supporting it, when it
should never have been in the first place. That is all that is being
argued by the Groklaw site too. That the nature of the subject should
have excluded it, but that most didn't look at it right, and some of
them may have, due to their own interests, *intentionally* misled the
patent system into looking at it in a way that supported patents, while
being careful to derail attempts to argue against it.
And, seriously, how many of the companies involved wouldn't have wanted
patents? I would argue that, in most cases, the people involved in such
cases where "both" companies or individuals, who where arguing not over
whether someone should own a patent on it, but who. They are hardly, on
either side, given the number their own law departments already have on
things, going to argue that the process **itself** is invalid, not just
the specific patent. I am sure you can think of parallels where this
has, or could, happen.
void main () {
   else
Date: 25 Nov 2009 14:53:55
Message: <4b0d8b53@news.povray.org>
I disagree that most of what the groklaw article talks about is relevant.
When they're arguing about abstract computer theory, they're intentionally
ignoring the fact that (for example) isomorphic changes can actually be
novel and inventive.
For example, you could argue that patenting the layout of a particular
typewriter keyboard should be allowed, especially if it gives a significant
improvement over previous keyboard layouts, right?
If you're going to insist that it's impossible even theoretically to improve
a device in a novel way by modifying the software it is running, then we'll
have to disagree.
Which is not to say that I think software should be patentable. Just that
excluding it merely because it is software doesn't make sense to me.
> patents?
About half. The half that lost the patent case in court, in particular. And
that's why we have precedents. You can't argue that this case applies to him
and an identical case doesn't apply to you.
But sure, in general? Go for it. That's what the legislature and judges
decide, and that's what's before the courts now.
