POV-Ray : Newsgroups : povray.off-topic : Modern Linux desktops suck Server Time
2 Jul 2026 10:14:22 EDT (-0400)
  Modern Linux desktops suck (Message 118 to 127 of 127)
Subject: Re: Modern Linux desktops suck
Date: 24 Nov 2009 14:06:16
Message: <4b0c2ea8@news.povray.org>
Eero Ahonen <aer### [at] removethiszbxtnetinvalid> wrote:
> Neeum Zawan wrote:
> >     Not really on Linux. It eats up the CPU, and doesn't seem to utilize
> > many capabilities of the graphics card - which the Windows plugins do.
> The Linux Flash is still a crappy piece of shit. It's a resource hog and
> still it's amazingly stupid (eg. won't handle second soundcard, even
> though it supports ALSA).
  Hardly Linux's own fault given that Flash is, at least in principle,
a proprietary format owned by Adobe, who also makes the Linux Flash plugin.
Date: 24 Nov 2009 14:27:51
Message: <4b0c33b7@news.povray.org>
I fully agree, the fault is on Adobe, which doesn't seem to be keen to
allocate resources to get the freaking thing to work. But still it's the
Linux version that's ultimately crappy, AFAIK Windows-Flash works much
better.
-Aero
Date: 24 Nov 2009 15:16:16
Message: <4b0c3f10@news.povray.org>
> better.
  But you can't blame Linux for that.
  OTOH the current plugin can be used for basically any Flash app out
there, so it's better than nothing.
Date: 25 Nov 2009 09:43:58
Message: <4b0d42ae$1@news.povray.org>
Yes, I already agreed on that (and have agreed all the time). It just
doesn't remove that Adobe piles more sucking on Linux-plugin than on
Windows-plugin.
Yes, if you have enough power. I think I do now, I haven't yet got my
new workstation (Q9550, 8GiB etc) to lag with flash, while my laptop
(C2D T5600 (1,8GHz), 4GiB etc) couldn't play youtube videos with flash,
since I didn't have enough CPU power (OTOH, MPlayer plaid them with
under 1% of CPU usage...).
-Aero
Date: 25 Nov 2009 16:59:13
Message: <4b0da8b1$1@news.povray.org>
On Tue, 24 Nov 2009 09:23:40 +0000, Invisible wrote:
> I'd be surprised if that actually works.
> The option you want to change might be at default, and thus there's no
> entry for it in the config file. It might have a highly non-obvious
> name. Or it might be configured from a totally different file. (E.g.,
> there is [presumably] a file somewhere which configures your network
> interfaces. But the DNS configuration is in an entirely unrelated file.)
Most Linux/Unix config files include defaults commented out - that's
pretty standard.  So grepping does work quite well.
Jim
Date: 25 Nov 2009 17:02:56
Message: <4b0da990@news.povray.org>
On Tue, 24 Nov 2009 09:24:48 -0600, Neeum Zawan wrote:
> On 11/23/09 21:38, Jim Henderson wrote:
>>>>> http://www.xkcd.com/619/
>>>> Full-screen flash video support has been around for a while.
>> utilize
>> I use it quite frequently, and while it does suck CPU, it does run full
>> screen, which is what the claim there was....
>> "Works for me"....
> 	Ah. You have a fast CPU.
AMD-64 2 GHz dual core processor - not really blazingly fast by today's
standards.  That's the desktop machine.  The Dell laptop is a single core
(I believe) Intel 32-bit processor that runs at about 2 GHz as well.
I've a slower laptop in the office (a Thinkpad t42p) that's slower and
still seems to handle it OK.
> 	It's like saying "X works", when you don't have 3-D working. A
major
> "feature" of the plugin fails to work. From my perspective, that means
> it *doesn't* work.
> 	Anyway, on many computers, including mine, playing HD videos full
> screen on Flash gets jerky. CPU can't handle it, and the CPU isn't
> supposed to handle it - the video card is.
I don't disagree with that - I'm not saying it's the best engineered
piece of software in the world, but I am saying that it works well enough
for the rare occasions I do use it.
Jim
Date: 25 Nov 2009 19:28:28
Message: <4b0dcbac$1@news.povray.org>
	Try Hulu. Set whatever you're watching to the highest quality, and then
switch to full screen. On my machine (P4 2.53 GHz), it plays, but it
kind of jerks a few times a minute.
	It should give trouble on your slower machines.
	Of course, it's possible that the plugin _is_ working with your 3-D
cards (all of them?). It's not that they don't support video cards at
all - just that it rarely works.
ASCII and ye shall receive.
Date: 25 Nov 2009 19:31:17
Message: <4b0dcc55$1@news.povray.org>
	I'm not sure about the "most". I'm guessing you more often deal with
common _system administration_ (mature) tools - which often are as you
described - as opposed to just wild stuff for the desktop.
	Or it could be a distribution thing - they may be the ones who place a
fully commented config file for common tools.
	Let's put it this way: For most of the config files that sit in my
_home_ directory, they didn't come with a config file with all the
options - although many do have a sample one in /etc that has _common_
options...
Date: 26 Nov 2009 01:53:33
Message: <4b0e25ed$1@news.povray.org>
>> core (I believe) Intel 32-bit processor that runs at about 2 GHz as
>> well. I've a slower laptop in the office (a Thinkpad t42p) that's
>> slower and still seems to handle it OK.
and then
Have done, and yes, it's jerky at the highest resolution, but I've always
had problems with it because of my bandwidth (only 3 Mbps down here at
home).
D
At issue really is a definition of "working".  I consider it working if I
can watch video effectively.  You seem to consider it working only if it
behaves in a particular manner, such as offloading the video rendering to
the GPU.  That'd be nice, but doesn't fit my general definition of
"working" which is "I can use it most of the time without a problem".
Biggest problem I have with it is the damned thing has memory leaks
galore.
Jim
Date: 26 Nov 2009 01:54:24
Message: <4b0e2620$1@news.povray.org>
with
place a
> options...
True, and yes, I'm talking about system config files, which are generally
mature and well documented/commented.  There's that pesky "works"
definition issue again. ;-)
Jim
