POV-Ray : Newsgroups : povray.off-topic : go! Server Time
4 Jul 2026 15:25:01 EDT (-0400)
  go! (Message 8 to 17 of 27)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: go!
Date: 11 Nov 2009 23:18:52
Message: <4afb8cac$1@news.povray.org>
nemesis wrote:
> http://golang.org/
Hmmm. Interesting. (Three people have told me about this already. :)
 > Interfaces can be added after the fact if a new idea comes along or fo
r
testing—without annotating the original types.
That's a good step towards the "next language" bit I was talking about
earlier. Where unit testing is trivial in the language, or some such.
 > Go's concurrency primitives derive from a different part of the family
tree whose main contribution is the powerful notion of channels as first
class objects.
Very nifty. I suspect I'm going to have to look into this more.
 > It is practical to create hundreds of thousands of goroutines in the s
ame
address space. If goroutines were just threads, system resources would ru
n
out at a much smaller number.
And this.
I was very skeptical just glancing thru it at first, but it seems there's
more going on than evident at a quick glance.
Subject: Re: go!
Date: 12 Nov 2009 05:42:25
Message: <4afbe691@news.povray.org>
> for testing—without annotating the original types.
This is one of my favourit things about Haskell classes [which are
really interfaces]. You can add them to any type you fancy.
> family tree whose main contribution is the powerful notion of channels
> as first class objects.
I must admit, I'm not sure what this even means. Might be interesting
though.
"Do not communicate by sharing memory. Instead, share memory by
communicating. And there is no spoon."
> same address space. If goroutines were just threads, system resources
> would run out at a much smaller number.
> And this.
Lots of languages have light-weight threads, no?
http://blog.orphi.me.uk/
Subject: Re: go!
Date: 12 Nov 2009 11:40:33
Message: <4afc3a81$1@news.povray.org>
> though.
CSP. A bunch of actors running around exchanging messages asynchronously,
each process being a single thread in its own address space. Like Erlang or
any of the other dozens of languages designed for real-time distributed
processing.
That the channel itself is a first class object makes for the ability to do
cool stuff like passing the channel to a new version of the program running
on a different computer, so you don't lose any outstanding messages.
Assuming they really mean "first class" there.
Many have lightweight threads that also occupy multiple processors. I.e.,
most languages where you can launch 10,000 threads launch them in one
process and fake it 100%.
But yes, the availability of lightweight objects and first-class channels is
a good combination. Either one alone is difficult.
I'll have to see what kind of introspection they support and what kind of
dynamic loading.
Subject: Re: go!
Date: 12 Nov 2009 11:47:26
Message: <4afc3c1e$1@news.povray.org>
>> though.
> asynchronously, each process being a single thread in its own address
> space. Like Erlang or any of the other dozens of languages designed for
> real-time distributed processing.
So you mean each thread waits for messages to arrive, processes them,
maybe sends some other messages, and then waits for the next message?
> do cool stuff like passing the channel to a new version of the program
> running on a different computer, so you don't lose any outstanding
> messages. Assuming they really mean "first class" there.
Mmm... In C, an integer is a "first class" thing, but that doesn't mean
you can send it over a network connection, for example. They might mean
that these channels only work inside a single running instance of a
single program.
> I.e., most languages where you can launch 10,000 threads launch them in
> one process and fake it 100%.
Oh, OK. I assumed they all do what Haskell does - you call forkIO and it
creates a thread. You specify CLI options to say how many *real* threads
to use.
[It's mildly irritating that to change the number of real threads, you
must stop and restart your program - and also you can only control this
from the CLI args...]
> of dynamic loading.
Ah, dynamic loading is fun.
Subject: Re: go!
Date: 12 Nov 2009 12:03:06
Message: <4afc3fca$1@news.povray.org>
Essentially, yes.
> single program.
If you can send a channel over another channel, then all you need is to
encapsulate channels over sockets and you're done. If you can't send a
channel over another channel, then it isn't first class.
No. Generally, desktop languages that supported threading before multi-CPU
machines were common either fake it or use OS threads. Any language with a
"threadpool" structure in the library is probably one of these.
Java with green threads faked it, Java with real threads allocates threads
one for one, C# uses real threads, Smalltalk fakes it, C and C++ tend to use
real threads, etc.
Of course, java and C# can change the semantics to use lightweight threads.
C and C++ are probably stuck unless they break compatibility with all the
other thread languages. Smalltalk is probably stuck with its own threads
because everything there is "too open".
It's important for long-running programs, things with plug-ins, etc. Even if
it's just dynamic linking. Of course, given it's google, they might very
easily say "crash out if you want to load a different implementation of
something, because everything we write recovers automatically anyway."
Subject: Re: go!
Date: 12 Nov 2009 12:14:38
Message: <4afc427e$1@news.povray.org>
> Essentially, yes.
Seems like a conceptually simple model.
>> mean you can send it over a network connection, for example. They
>> might mean that these channels only work inside a single running
>> instance of a single program.
I would suggest that sending a channel over a channel is probably
trivial, but sending a channel over a socket is probably *highly* complex...
> multi-CPU machines were common either fake it or use OS threads.
Oh. Really? I didn't know that...
Well, now I guess I understand why everybody gets so excited about
Haskell's concurrency support then. :-}
> Even if it's just dynamic linking. Of course, given it's google, they
> might very easily say "crash out if you want to load a different
> implementation of something, because everything we write recovers
It's supposedly one of the big plus points of Java - not that I have
*ever* seen *any* Java program which actually supports plugins, mind you...
As an aside, GHC theoretically is supposed to support dynamic loading.
Good luck making it actually work though...
Subject: Re: go!
Date: 12 Nov 2009 14:03:50
Message: <4afc5c16@news.povray.org>
That was the idea. Sort of like Lambda calculus - very simple, easy to prove
things about with the right formalisms. Then it turned into products.
> complex...
Could be, could be. But you can conceptually make it work without breaking
the language.
That's part of it.
At the time Java did it, it was rather new. Nowadays, Java's mechanisms are
fairly lame compared to the competition.
Subject: Re: go!
Date: 12 Nov 2009 14:11:23
Message: <4afc5ddb@news.povray.org>
> That was the idea.
I gathered. ;-)
LOL.
>> you...
> are fairly lame compared to the competition.
Question: How many Java programs have you seen that are more than
Tic-Tac-Toe demo programs? ;-)
(Personally, I haven't seen many - although there are a few...)
Subject: Re: go!
Date: 12 Nov 2009 14:22:12
Message: <4afc6064@news.povray.org>
Quite a few.
Subject: Re: go!
Date: 12 Nov 2009 15:18:55
Message: <4afc6daf@news.povray.org>
Orchid XP v8 escreveu:
A large part of the e-commerce web is powered by java application
servers.  The reason you only see old tic-tac-toe java "applets" is
because that's what is left on the web after Sun's goals for desktop
java apps got spoiled by Microsoft with their own incompatible Java runtime.
That said, desktop java apps are still used at a fairly large scale.
Federal Postoffice agency here in Brazil uses one such app for all its
transactions.  It has that caracteristic Swing look-and-feel.  I gather
banks also rely on java infrastructure heavily.  You quite never deal
with it directly, though.  Only with the familiar generated HTML.
a game sig: http://tinyurl.com/d3rxz9
