POV-Ray : Newsgroups : povray.off-topic : More barcode fun Server Time
27 Feb 2026 16:31:12 EST (-0500)
  More barcode fun (Message 1 to 10 of 25)
Subject: More barcode fun
Date: 30 Oct 2009 06:07:34
Message: <4aeabae6$1@news.povray.org>
So check it out. I made a little chart showing the start and stop codes
for various types of (1D) barcodes. Now I can tell which type of barcode
I'm looking at.
(Actually, so far I've yet to find anything with a barcode other than
the four on the right. However, I'm told that packing cartons often use
a varient of I25...)
Download 'barcode types 2.pdf' (3 KB)
Subject: Re: More barcode fun
Date: 30 Oct 2009 09:22:30
Message: <4aeae896$1@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:4aeabae6$1@news.povray.org...
> I'm looking at.
In all of the programming projects I've ever done involving printing of bar
codes, I've only ever used those... mostly code 39, although I used 128 once
for making very small bar codes, and 2 of 5 for an PO system where the
vendor specs required that format.
In most cases, I've used some external tool, like a specialized bar code
printer, to generate the symbols. I did once (about 15 years ago) have to
write a program to generate code 39 on a laser printer by iterating the
rectangles myself. I had to copy the spacing out of a book, which was a
weekend well spent, let me tell you. :D
Date: 30 Oct 2009 09:29:08
Message: <4aeaea24@news.povray.org>
Indeed, code 39 and code 128 seem quite popular. I've found very few
code 93 barcodes. (And, obviously, UPC-A / EAN-13 is everywhere.)
In PostScript, it's not a challenging thing to do. (As you can see, I've
just done it.)
I'm currently writing a small Haskell library for this. Currently it
understands 2 of 5 standard and interleaved, code 128, and I'm currently
implementing code 39. Of course, the library only handles converting
characters into 1s and 0s and back again. In "real" barcode handling
things are far more complex; bar thicknesses have to be within certain
tollerances when printing, and scanning is a fairly sophisticated problem...
Date: 30 Oct 2009 09:37:33
Message: <4aeaec1d$1@news.povray.org>
news:4aeaea24@news.povray.org...
> problem...
I've never tried to implement a scanning algorithm, but it looks like an
interesting challenge. Not much novelty in it, I s'pose, although there
might be some room to develop more sophisticated two dimensional bar code
scanning processes.
When I had to make my own code 39, I coded for a specific model of laser
printer at 300 dpi, and I translated the tolerances to integer values before
I made my translation table, then translated those into the graphics command
that drew filled rectangles on the printer. That restricted the size
variations I could do, but it kept me from having slight variations in size
due to rounding errors; mostly all that was so that I could get the software
done and out the door quickly.
Date: 30 Oct 2009 09:47:02
Message: <4aeaee56$1@news.povray.org>
> scanning processes.
The fun part of scanning, of course, is this:
1. You have to figure out where the hell the edges of the barcode are.
2. You have to work out how far away the barcode is, and hence how wide
each of the bars is.
3. If the barcode has been scanned at an angle, the bar thicknesses may
be different at one end verses the other end, and you need to compensate
for this.
4. The barcode might be dirty, and you need to account for and reject
noise in the signal.
5. You have to figure out which kind of barcode this is.
6. The barcode could be upside down. (E.g., my tape labels have all the
barcodes actually printed the wrong way round. Go figure.) If so, you
need to detect this and flip the barcode.
7. The barcode scan could be incomplete. (E.g., the scanner beam goes
across a corner of the barcode, only picking up some of the bars.)
8. If you're using a 2D *camera* instead of a real laser barcode
scanner, multiply all of the above issues by 7.
It's not as trivial as it sounds. ;-)
Yeah, well, PostScript makes it fairly easy to draw a few rectangles at
an exact absolute size on any compatible printer. (The print tolerances,
however, will vary by model. I'd suspect that, e.g., an inkjet printer
probably won't print small barcodes with sufficient accuracy.)
Date: 30 Oct 2009 09:54:16
Message: <4aeaf008$1@news.povray.org>
news:4aeaee56$1@news.povray.org...
Sorry, didn't meant to imply it wasn't hard, just that other people have
done it a few times. :)
I'm currently working (in my spare time) on trying to write a fluid dynamics
solver, which also isn't novel, but it's new to me. I got into it thinking,
"How hard can it be?"
Hoo, boy.
Date: 30 Oct 2009 10:11:04
Message: <4aeaf3f8$1@news.povray.org>
> Hoo, boy.
Hahahahaha.
0WN3D!
Here, have a cookie:
http://www.youtube.com/watch?v=58_s6r7PaKo
This is what happens when you play with a simple non-linear dynamical
system. (It represents about a day's worth of computer time, BTW.)
Date: 30 Oct 2009 10:13:54
Message: <4aeaf4a2$1@news.povray.org>
> I'd suspect that, e.g., an inkjet printer probably won't print small
You can buy parcel shipping online here in Germany, and you get a label to
print out with the barcode on.  This is then scanned by the machine at the
unmanned drop-off point.  Once my inkjet had a blocked nozzle and I was
there for 10 minutes trying to get the damn thing to scan.  Then I realised
what the problem was, got a black pen and filled in the bar that had a bit
missing by hand - it worked!
Date: 30 Oct 2009 10:17:31
Message: <4aeaf57b$1@news.povray.org>
> to print out with the barcode on.  This is then scanned by the machine
> at the unmanned drop-off point.  Once my inkjet had a blocked nozzle and
> I was there for 10 minutes trying to get the damn thing to scan.  Then I
> realised what the problem was, got a black pen and filled in the bar
> that had a bit missing by hand - it worked!
That's pretty epic, really... :-D
Actually, I notice the Royal Mail let you buy "stamps" online now, where
the stamp is actually a PDF file which prints out a 2D barcode...
Oh, and I finally found out what all those zig-zags are for:
http://en.wikipedia.org/wiki/RM4SCC
Date: 30 Oct 2009 10:18:53
Message: <4aeaf5cd$1@news.povray.org>
news:4aeaf3f8$1@news.povray.org...
>> dynamics solver, which also isn't novel, but it's new to me. I got into
>> it thinking, "How hard can it be?"
>> Hoo, boy.
> Hahahahaha.
> 0WN3D!
I look forward to seeing it with great anticipation. However, it's about
10:15 AM on a Friday where I'm at now, which puts me at the office, which
has blocked YouTube and almost everything else that's interesting.
Fortunately, the blocking software service that we use appears to think that
the Internet and the Web are the same thing, so I can come here to cool off
my brain cells. Puts me in mind of a friend of mine, who once said to me,
"Usenet? Is that new? What's their web site look like?"
