POV-Ray : Newsgroups : povray.off-topic : Inspect DLL Server Time
18 Jul 2026 18:33:55 EDT (-0400)
  Inspect DLL (Message 12 to 21 of 61)
Subject: Re: Inspect DLL
Date: 12 Oct 2009 09:44:52
Message: <4ad332d4$1@news.povray.org>
>> OK, so here's a question: I think I understand how to load a DLL and
>> call the functions it exports, but... how do you find out what functions
>> a DLL exports?
>   That's what headers are for.
Or documentation, for that matter.
OTOH, if you don't have either of these...
Date: 12 Oct 2009 10:05:00
Message: <op.u1oxemzu7bxctx@e6600>
On Mon, 12 Oct 2009 15:11:47 +0200, Invisible <voi### [at] devnull> wrote:
> I found several other DLLs which apparently export... absolutely
> nothing. (Why do they exist then?)
A DLL need not export its functions by name.
> Some DLLs for highly complex tasks appear to export a tiny amount of
> stuff, so clearly there's something I'm not seeing.
A COM-based DLL need only expose a single function, one that returns a COM
interface pointer. The complex stuff is then reached through that
interface.
> And then there are huge, huge numbers of DLLs on the system which aren't
> registered anywhere.
Not all DLLs are COM servers.
> And who says that staring into a screen full of code numbers is a good
> way to learn stuff? ;-)
I don’t even see the code anymore; all I see now is blonde, brunette,
redhead...
FE
Date: 12 Oct 2009 10:09:13
Message: <4ad33889$1@news.povray.org>
But wouldn't that mean that there's no way to reach its functions?
(Unless you happen to know the exact base address - which will change in
the next version of the DLL...)
> COM interface pointer. The complex stuff is then reached through that
> interface.
I was under the (mistaken?) impression that COM methods are exported as
DLL functions, and the COM system runs on top of the underlying DLL
infrastructure.
Indeed.
And even the ones that are don't actually need to be registered; just
the ones that lots of people might want to find by ClassID. You can
access a COM server by its file path instead...
> redhead...
WIN!
Date: 12 Oct 2009 10:46:35
Message: <op.u1ozbwxg7bxctx@e6600>
You can export functions by ordinal (i.e. number).
> infrastructure.
http://msdn.microsoft.com/en-us/library/ms694363(VS.85).aspx
http://msdn.microsoft.com/en-us/library/ms682305(VS.85).aspx
http://msdn.microsoft.com/en-us/library/ms686615(VS.85).aspx
FE
Date: 12 Oct 2009 11:09:07
Message: <4ad34693$1@news.povray.org>
>> in the next version of the DLL...)
And, indeed, a few DLLs show unamed functions exported (i.e., a number,
but no name).
But some DLLs appear to export *nothing*. Not even unamed functions. I
suppose they could contain "resouces", but...
>> as DLL functions, and the COM system runs on top of the underlying DLL
>> infrastructure.
That explains what some of the function calls are, but still doesn't
really say how it *works* internally.
Still, I guess you don't really need to know. I'm just curious about
such things.
More puzzling: CoGetClassObject() allows you to get hold of any class by
its ClassID. CoCreateInstance() creates any object given a ClassID and
an InterfaceID. This gives you a pointer to the object's interface. But
I cannot find any way of actually calling methods. If you have a DLL,
you can do GetProcAddress() to look up a function and call it. But if
you have an interface pointer, there doesn't seem to be any way to call
methods of the interface...
Date: 12 Oct 2009 11:14:07
Message: <4ad347bf@news.povray.org>
  If someone releases a dll but not headers or documentation for it, you'll
probably better avoid using that dll. You can't expect for its interface to
not to change in the future.
Date: 12 Oct 2009 11:17:12
Message: <4ad34878$1@news.povray.org>
I'm thinking more about writing plugins, but where I don't have any
documentation that says what functions it's supposed to export. If you
can find a working plugin, you can find out what it exports.
Of course, with no clue what parameters each such function takes, or
what the hell it's supposed to do, it's still pretty hopeless I guess...
Date: 12 Oct 2009 11:18:07
Message: <4ad348af@news.povray.org>
  Do you really want to write a plugin for a completely undocumented system?
Date: 12 Oct 2009 11:33:59
Message: <4ad34c67@news.povray.org>
Well, in the case of VST, it's not that it's undocumented, just that you
have to pay money for the documentation...
...but yeah, I guess it's pretty much a non-starter.
Date: 12 Oct 2009 12:09:27
Message: <op.u1o251a97bxctx@e6600>
An "interface" is a list of function pointers. In C and C++ the layout of
an interface is typically described in a header file.
FE
