POV-Ray : Newsgroups : povray.off-topic : Visual C# .net (and XNA) first impressions Server Time
4 Jul 2026 13:45:24 EDT (-0400)
  Visual C# .net (and XNA) first impressions (Message 7 to 16 of 46)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Visual C# .net (and XNA) first impressions
Date: 12 Oct 2009 03:56:58
Message: <4ad2e14a@news.povray.org>
> The only problem with code refactoring is that it really does have to
> recompile the code, which means it can't refactor code that doesn't
> compile. If you have a half-finished function you're typing in, and you
> realize you want to convert something in the middle of an earlier function
> into a stand-alone method, you have to clean up what you're working on
> enough to do that.
> Unless they've fixed that since last I looked.
They seem to have fixed that, I tried what you said and it worked fine.
Date: 12 Oct 2009 04:02:25
Message: <4ad2e291$1@news.povray.org>
>  You can do pretty much the same thing in C++, by implementing the methods
> in the class declaration. Of course this is recommended only for small
> classes. With large classes you'll end up with a megaclass which will be
> hard to understand and maintain, so it will cause more trouble than it's
> worth.
Yes, this had always been my mentality with C++ too, in fact it was very
rare I would put any actual code in the class declaration file.  With C#
though it kind of forces you to do this (I don't know whether it's possible
not to), which at first I thought was terrible, but once I got used to
"collapsing" the code with the little +/- icons in the margin, I think it
works really well.  You can have multiple levels of the collapse tree and
define your own collapse regions in the code if you want (so if you had
several methods implemented all relating to one part, you could collapse all
these together).  The result is that the source file *looks* like simply the
class declaration, but when you need to you can expand any part to see the
actual code.
If I went back to using C++ for something, I might be tempted to do this
too.  I wonder if the Visual C++ Express edition IDE is the same as the C#
one?  Maybe I just have an old version of the C++ one that doesn't contain
some of the newer features.
Date: 12 Oct 2009 09:33:19
Message: <4ad3301f@news.povray.org>
> works really well.
  I'm not completely convinced by having the need of a specialized source
editor in order to understand the source code better. If you ever need to
develop the source in some environment where you don't have that editor
with those fancy features, you are going to find yourself wading through
thousands and thousands of lines of code.
  Things like code block collapsing and code coloring are definitely
helpful, but IMO good-quality code shouldn't rely on those editing features
in order to keep itself understandable and maintainable. You never know
when you will have the need to understand the code in an environment
which lacks those features.
Date: 12 Oct 2009 11:01:15
Message: <4ad344bb@news.povray.org>
"scott" <sco### [at] scottcom> wrote in message
news:4acf4330$1@news.povray.org...
> One little niggle I had to start with was that when you define a class,
> you need to write the code for all the methods of that class in the
> definition too (in C++ I would usually put the actual method code in a
> separate file). [...]
In the .NET environment, you could do it that way by writing an interface,
then implementing the interface in a class definition. I wouldn't recommend
doing that just to make C# behave like C++, though. C# is great at what it
does, and C++ is great at what it does, but they're really two different
languages. C# is a front end for the .NET CLR, and is made so that C and C++
programmers have a familiar way in to that environment. C++ is for
programming down to the bare metal, and hopefully always will be.
I use .NET languages when I need to quickly make input modules. You still
can't beat C++ for performance, though. :)
Date: 12 Oct 2009 11:45:08
Message: <4ad34f04$1@news.povray.org>
> features
Yes that's a good argument for not always using those features in general,
but for me personally I don't think my C#.net/XNA code will ever be opened
in anything other than the MS IDE :-)
Date: 12 Oct 2009 12:15:20
Message: <4ad35618$1@news.povray.org>
You are perfectly welcome to write a second bit of source code and maintain
it in sync with the main file when using C# also. ;-)
> If you ever need to
It's really not a problem. I actually find it easier to find things in C#
than in C++, exactly because I know where to look. If I want to see how
alpha::beta is implemented, I know where to find it and I know what search
string to put in. In C++, I'm lucky if I can figure out what header file
it's in, let alone where in the class heirarchies it is.
That's one thing I'm finding about trying to figure out this huge
undocumented code base I'm working with - it's almost impossible to actually
track down where the f'ing code *is*. There's way too many things like
typedef enum {
   ... 300 lines of enums ...
} TYaddaBlow;
OK, now go grep thru half a million lines of code looking for that
declaration to figure out what the possible values for the enum are. Don't
forget that the same name is defined in three different layers of the
architecture, so even when you find it, you need to read the 2000-character
gcc line to try to figure out which .h file containing the declaration gets
included first, so you know which enum definition that particular source
file is using.  </rant>
Then you generate the header docs from the source code and you're good to
go. There's no reason to make maintaining two files a manual process. On the
other hand, if you *want* to do so, you certainly can.
Date: 12 Oct 2009 12:16:15
Message: <4ad3564f$1@news.povray.org>
>> you realize you want to convert something in the middle of an earlier
>> function into a stand-alone method, you have to clean up what you're
>> working on enough to do that.
Kewl. I remember reading someone's paper about how they figured out (for
example) which brace you had intended to close in something with the wrong
number of closing braces. It was a novel approach to incremental parsing.
Date: 12 Oct 2009 12:21:27
Message: <4ad35787@news.povray.org>
> go.
  Not everything in a source file is supposed to be part of the public
interface.
Date: 12 Oct 2009 12:50:13
Message: <4ad35e45$1@news.povray.org>
>> go.
> interface.
Ah, but it *is*, in C++.[1]  In C#, you can tell it to leave the private
functions out of the generated documentation altogether. :)
[1] Which, incidentally, I find highly annoying when it's time to add a
helper function to a class to split up a big file, and I have to go declare
this completely private class in a different file *and* recompile everything
that uses the class, even tho I've just said "nobody outside the class is
allowed to use this anyway."  But that's a minor annoyance, just part of the
job, compared to the *CRAP* I'm dealing with lately in this code base. :-)
Date: 12 Oct 2009 13:49:15
Message: <op.u1o7sdl37bxctx@e6600>
On Mon, 12 Oct 2009 18:50:12 +0200, Darren New <dne### [at] sanrrcom> wrote:
>> public interface.
No.
> In C#, you can tell it to leave the private functions out of the
There is no reason why a C++-capable version of "it" could not do the same.
FE
