POV-Ray : Newsgroups : povray.off-topic : An annoying thing in Windows (which mostly doesn't happen in Linux) Server Time
4 Jul 2026 10:33:24 EDT (-0400)
  An annoying thing in Windows (which mostly doesn't happen in Linux) (Message 51 to 60 of 78)
Subject: Re: An annoying thing in Windows (which mostly doesn't happen inLinux)
Date: 20 Sep 2009 20:15:41
Message: <4ab6c5ad$1@news.povray.org>
clipka wrote:
> Of course the script first verifies that the shell is compatible with
> the command syntax used in the script, goes on to find out what compiler
> to use, and so on...
Yes, it's one of those lovely systems where you write code to describe the
code that describes the code that gets compiled, because otherwise it's just
too much a PITA.
Date: 20 Sep 2009 21:02:40
Message: <4ab6d0b0$1@news.povray.org>
> the code that describes the code that gets compiled, because otherwise
> it's just too much a PITA.
Yup.
So much for portability :-P
Date: 20 Sep 2009 22:16:56
Message: <4ab6e218@news.povray.org>
C isn't portable. C just lets you put several versions of the source code
into the same file. :-)
Subject: Re: An annoying thing in Windows (which mostly doesn't happen in Linux)
Date: 21 Sep 2009 03:26:29
Message: <4ab72aa5$1@news.povray.org>
>  Something like a half year ago I had 10 GB of free space in my C: drive.
> Today I had less than 4 GB,
I think the moral of the story is that nowadays you can't really survive
with only 4GB or 10GB of free space on the C drive without performing
regular clean-ups.  I guess most developers assume way bigger hard drive
space so don't care about leaving around odd MBs here and there.
OOC why such a small C partition?  HDs are really cheap, I don't think you
can even buy anything under 120GB now.
Date: 21 Sep 2009 07:58:36
Message: <4ab76a6c$1@news.povray.org>
> code into the same file. :-)
Yeah, I guess that's a fitting description :-)
Date: 21 Sep 2009 11:54:10
Message: <4ab7a1a2@news.povray.org>
  Even if a 100 TB disk was free, I am still not eager to reinstall Windows.
Date: 21 Sep 2009 14:19:49
Message: <4ab7c3c5@news.povray.org>
Depending on the version of Windows, you could get a new disk and just move
the partitions over, one way or another.  It's really no harder than
recovering from a HD crash.  Let me know if you are interested.
Date: 21 Sep 2009 18:06:41
Message: <4ab7f8f1@news.povray.org>
> you can even buy anything under 120GB now.
Older versions of Windows, prior to XP, you could do it, since a)
settings didn't get saved into c:\documents and settings\, and neither
did documents. I don't think there is any *obvious* way to move
settings, and if you did, you would break things that assume they will
be in the same place, instead of checking the current path for it, and
while you can move the documents, **I know** personally that this breaks
some applications which expect the document path to remain the same,
after detecting they are in XP or higher.
What this means in practice is, you can't **clean up** anything, because
any programs that store settings outside the registry, or anything else
they need, will end up on C, even if you install them on Q, or
something. The more things you have installed, the more caches,
settings, data, etc. get shoved into C anyway, and the less and less
room you have for anything else. So, under XP, if you don't do it the
stupid way, which is, "Install everything in the same massive
partition", you eventually run out of room, and not just because half
the shit, including MS' own patches/installers are often too stupid to
clean up after themselves either, never mind anyone else's.
void main () {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 22 Sep 2009 03:28:40
Message: <4ab87ca8@news.povray.org>
> some applications which expect the document path to remain the same, after
Such an application that assumes absolute folder paths that are hard coded
would be ridiculous.  It would mean for instance it would only work on
English 32bit XP and nothing else.  German XP (and I suspect all other
languages) has different folder names for My Documents, 64bit has a "Program
Files (x86)" folder, Vista has C:\Users rather than C:\Documents and
Settings, didn't Win2K have C:\WINNT as the windows folder or something?
Basically such a program would suck so much, the fact that it stored it's
data on C rather than D would be the least of your worries.
BTW Vista can trick older/badly written programs in to thinking they are
writing to a certain location, but actually stores the files in the correct
area.  If you tell Vista your user area is somewhere else (eg D drive) then
really everything will be put on the D drive, even by badly behaved programs
that try to write directly to the C drive.
Date: 22 Sep 2009 03:35:37
Message: <4ab87e49$1@news.povray.org>
> Windows.
At some point though (if not already) you are going to have spent more time
trying to fix these things than it would have taken to just reinstall.
Didn't you spend ages trying to defrag this drive a while ago too?  If it
was me I'd just bite the bullet and reinstall before I wasted any more time
on such issues.
