POV-Ray : Newsgroups : povray.off-topic : An annoying thing in Windows (which mostly doesn't happen in Linux) Server Time
4 Jul 2026 09:15:19 EDT (-0400)
  An annoying thing in Windows (which mostly doesn't happen in Linux) (Message 39 to 48 of 78)
Subject: Re: An annoying thing in Windows (which mostly doesn't happen inLinux)
Date: 20 Sep 2009 13:40:17
Message: <4ab66901@news.povray.org>
clipka wrote:
> Darren New schrieb:
>> I.e., it's handled by the package manager, not by install scripts and
>> so on, so if you compile and install from source, it's not going to
>> bump the use count on your libraries.
> That's what I wanted to know - thanks.
> So, Windows is actually a lot better at this... /theoretically/.
I wouldn't say that. It's just that the installer for WIndows comes with the
program. If I compile something from scratch on Windows and it uses some
DLL, I'm not going to be able to ensure that DLL doesn't get deleted out of
the system either.
It's still the "package manager" part of Windows handling it. It's just that
Windows installers talk to the package manager as they run.  (And indeed,
the whole "MSI" bit is making software more into Linux-style packages.)
I think the real difference is that there are relatively few DLLs that are
shared amongst multiple programs from multiple companies but not part of the
system. I.e., most programs that need graphics stuff either puts libpng.dll
into the application's directory or it uses the graphics libraries that
already come with Windows. Linux apps tend to have a lot more references to
"random" underlying libraries that aren't officially part of "Linux" as
such.  Windows uses "components" for the bits that are shared, and those are
in the registry and thus tracked the way they're supposed to be. The places
where you have lots of common functionality (e.g., Office), you have a
"common files" directory, and your installer is set up to deal with the
stuff in there appropriately. (I.e., there's a lot of help from Windows
installers for shared but not universal functionality, in part because the
writers of Windows also make a lot of money selling stuff with a lot of
shared functionality like Office and MSSQL and such.)
Date: 20 Sep 2009 13:45:04
Message: <4ab66a20$1@news.povray.org>
nemesis wrote:
> I understood your point.  Hand-compiled and installed povray or any
> other is of no concern to the package manager.  Thus, it'll uninstall
> libpng without caring if hand-compiled povray uses it or not.  It
> doesn't even know hand-compiled povray exists.  Nor should it.
"It'll break your code, *and* it *should*!"  Ah, the mindset you can get
away with when writing non-commercial software. :-)
Date: 20 Sep 2009 13:51:39
Message: <4ab66bab$1@news.povray.org>
Darren New wrote:
> if you compile and install from source, it's not going to bump
Excellent fun. Compile something from source, and the package manager
doesn't know you have it, and tries to install it again.
Weirdly, most software you compile from scratch has an uncanny ability
to figure out what libraries are installed, no matter whether you're
using RPM or DEB or EMERGE or...
http://blog.orphi.me.uk/
Date: 20 Sep 2009 13:54:57
Message: <4ab66c71@news.povray.org>
>> I had that.
>> Then I discovered that it can't delete the IE web cache. (Due to some
>> kind of weirdness with it being system and hidden or something like
>> that.)
> Well, you do have to turn that off. "attrib -h -s junkdir /s"
Yeah, I think I tried that too. Basically there was something or other
"magical" about that folder. Windows Explorer could delete it, but from
the DOS box is was unclear whether it existed, couldn't quite be
deleted, etc. I don't know if it was the attributes or the desktop.ini
file or just a magic path hard-coded into the system or what... Tcl
killed it without difficulty though. Haskell too. (All the more amusing,
since Haskell is running under a Unix emulator...)
>> Even built a little Tk GUI for it, so you can see how much longer it's
>> going to take. (Deleting 0.8GB of web cache takes a while...)
> You can do this with "disk cleanup" tho.
Not programatically. And not on a roaming profiles folder on the server.
> Damn, you need a new job.
Really?! o_O
Date: 20 Sep 2009 14:42:05
Message: <4ab6777d$1@news.povray.org>
Orchid XP v8 wrote:
> Darren New wrote:
>> if you compile and install from source, it's not going to bump the use
Or you get to make up a package file by hand.
The worst I ever dealth with was a package that needed a very specific
version of Boost, and since Linux doesn't do the whole "side by side" thing
very well,
It's not that uncanny. It tries to compile the code, and if the compiler
returns error messages, it knows why.
Date: 20 Sep 2009 14:53:51
Message: <4ab67a3f@news.povray.org>
  Most libraries are installed in a directory which the compiler directly
checks when you tell it to link that library in. Thus to check whether the
library is in the system it's enough to try and compile something which
tries to link that library and see if it succeeds.
  Moreover, all libraries are installed in the same few semi-standard system
directories in all popular Unix-based operating systems, so even if the
compiler is not used to check for the existence of the library, it's just a
matter of looking for them in those established directories.
Date: 20 Sep 2009 14:54:42
Message: <4ab67a72$1@news.povray.org>
True. Not without COM, and not if the profiles aren't logged in.
Date: 20 Sep 2009 14:55:13
Message: <4ab67a91@news.povray.org>
  What's the package manager going to do? Scan the entire system for
executables which might be using that library? Sure, it could do that,
if you want to wait.
Date: 20 Sep 2009 16:26:25
Message: <4ab68ff1$1@news.povray.org>
Even that wouldn't necessarily work. Note I didn't say there was an easy fix
for the problem. I was mocking the attitude that since there isn't an *easy*
fix, then it *should* break.  I.e., that the attitude is "this should be
broken" rather than "this is regrettably broken."
But sure, if you uninstall stuff and it leaves libraries around, I can
imagine a button you could push that says "Scan all the executables right
now and tell me what libraries are installed that no executable references."
Along with "tell me the last time someone loaded this library."  Then you
could clean things up that stopped being used when you deleted some package
six months ago.
Date: 20 Sep 2009 18:49:44
Message: <4ab6b188$1@news.povray.org>
> the program. If I compile something from scratch on Windows and it uses
> some DLL, I'm not going to be able to ensure that DLL doesn't get
> deleted out of the system either.
Yes, but I *can* roll my own installer to do it.
And it's standardized. It's not like I'd need to make an installer for
Debian, another for Ubuntu, yet another for what-have-you-not...
