![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> Talking to oneself is generally the first sign of insanity.
>> ...or just having really, really few other people to talk to?
> I wonder whether there's any difference.
You're not mixing up cause and effect now, are you? :-P
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible wrote:
> (Although it does have hot-swap bays and a few
> percent higher clock speed.)
I would like to remind all advertisers that "hot-swap" does not mean "you
don't have to unrack the server to change the drive." Thank you.
> I have no idea who the hell needs 144GB of RAM, but I'm not one of them
People holding the entire database in RAM.
> Also interesting is that the HP stuff tends to give you by far the most
> bang for your buck.
On the occasions that it works, yes. Until it falls apart.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Get ready for Windows 7. Pre-order your copy NOW!"
WTF? Last time I heard, Windows 7 is still theoretical. It won't be
released for a decade.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> (Although it does have hot-swap bays and a few percent higher clock
>> speed.)
> "you don't have to unrack the server to change the drive." Thank you.
Both servers have drive bays at the front that you can easily pull the
drives out of. But only one is marked as "hot-swap". I'm presuming that
means one has to be turned off before you pull drives. (Although
*obviously* if I were going to actually reach into my pocket, I'd check
first...)
Why in the name of God would you do that? And who has a database that
big anyway??
>> most bang for your buck.
I don't follow.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You really need to read something other than porn and Haskell blogs online.
For that matter, why would you even post something like this without at
least looking it up with a simple google hit?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Two points:
One, it's probably labeled however the drive manufacturer labeled it. It's
not like HP makes disk drives.
Two, even if you can pull the drive in and out without turning off the
power, if the electronics don't let you reinitialize the bus, you're still
screwed. Guess what's true about SATA?
Speed.
> And who has a database that big anyway??
Wall Street. AT&T. British telecom. Heck, twitter's db is probably an order
of magnitude bigger than that.
Hell, AT&T has seven large databases, the biggest of which is something like
330 terabytes.
> I don't follow.
HP *computers* are generally pretty crappy. HP test equipment is good, but
the computers themselves are just assembled from whatever cheap parts they
can buy.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Who the hell *reads* porn?
(For that matter, who reads Haskell blogs apart from me? Yes, I knew
somebody would throw this one in...)
Given that it took MS something like 8 years to produce Vista, and
almost nobody has upgraded to *that* yet, I'd be rather surprised if
Windows 7 turns up any time soon, that's all.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> But only one is marked as "hot-swap". I'm presuming that means one has
> Two points:
> It's not like HP makes disk drives.
Really? So what's the deal with the full-page "HP original HDs" listing
then?
> still screwed. Guess what's true about SATA?
And let us not forget the software of course... But yeah, there's a
whole heap of components that need to support this. I presume that
people who design and build servers know a tad more about this than I do.
> Speed.
Pretty damned expensive though, don't you think? You'd have to be, like,
*really* desperate for speed to go to such lengths.
> order of magnitude bigger than that.
I doubt they're going to buy an off-the-shelf HP out of a catelogue.
Presumably they have an entire datacenter full of custom hardware to run
that stuff.
Still doesn't explain what your "average" customer is going to want this
for.
> but the computers themselves are just assembled from whatever cheap
> parts they can buy.
Oh. Really? I haven't had any problems - but then, I haven't used them
much, so...
All our printers are HP, and they seem to work quite well. (Unless some
skinflint decides to put a SOHO printer in a busy office... no surprises
that that doesn't work.)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> then?
Dunno. Maybe they make some of the parts. There's only like two factories in
the world that make ram chips, for example.
That too.
Not especially expensive, no. Just from a quick calculation, it's about
$2000 for that much fast RAM here. If that lets you make financial trades
that save you $100K/year, why wouldn't you?
> that stuff.
Sure.
> for.
For anything between a 5GB database and a 300terabyte database. :-)
The printers are good, yes.
Actually, like all such companies, the quality fluctuates with the amount of
bad press they get.
> (Unless some
Exactly. By the time you move up to the HP machines that are reliable enough
to run a business on, you're spending more than the competition.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Wow. Keep digging.
Try this: go to google and type in "Windows 7 download".
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
