![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Darren New wrote:
> Patrick Elliott wrote:
>> My personal thought on the matter is
> Did you ever study this stuff formally? Or are you guessing?
>> conditions, the vibrations introduced by thermal variance, and
>> possibly other sources of energy, introduce a situation where its no
>> longer possible for all particles to be in a single state.
> I'm not even sure what that means, but since I can observe the effects
> of quantum mechanical superpositions at the macroscopic scale (without
> even having any sophisticated equipment) I find this an unlikely
> explanation.
This isn't saying that you can't produce special conditions where the
general rule is violated, just that, outside those conditions, it does.
Much like Newton applying in a general sense, relativity in others, and
there being some cases where that doesn't *quite* apply either, given
the correct conditions.
And, no, I can't say that I have studied it extensively, but I am not
guessing either. We know, unless we are seeing things, that every atom
in a room doesn't spontaneously *leap* to one corner. There has to be a
reason for it, and the best reason available is that, under normal
conditions, interactions between particle, weak or otherwise, prevent
it. This is why you have to create conditions where some of those are
"not" happening. The question isn't if, but what is doing it, and why
the macro level states you manage happen at all, when they shouldn't,
based on observation of everything else. Why can you intentionally
violate the rules, when normally nothing, including the intent to do
something, like walking through a wall, which would be a similar
violation, is normally never happening? Enlighten me. What else, other
than freeform interaction, without something specifically designed to
"create" conditions where a violation of the normal rules can happen,
stops it from happening all the time?
void main () {
If Schrödingers_cat is alive or version > 98 {
if version = "Vista" {
call slow_by_half();
call DRM_everything();
call functional_code();
else
call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> There has to be a
> it.
Yes, of course. The only point I'm contesting is the assertion that a single
interaction with a single particle is enough to collapse the waveform and
serve as an "observation".
Who says they shouldn't?
Probability. You *can* walk thru the wall. The odds against it happening are
just 1^-1000.
Just like you *can* randomly shuffle a deck of cards and come up with Ace
thru King in each suit in order when you're done. It's just so phenomenally
rare that you'd never expect to see it happen.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> There has to be a reason for it, and the best reason available is
>> that, under normal conditions, interactions between particle, weak or
>> otherwise, prevent it.
> single interaction with a single particle is enough to collapse the
> waveform and serve as an "observation".
>> Enlighten me. What else, other than freeform interaction, without
>> something specifically designed to "create" conditions where a
>> violation of the normal rules can happen, stops it from happening all
>> the time?
> are just 1^-1000.
> Ace thru King in each suit in order when you're done. It's just so
> phenomenally rare that you'd never expect to see it happen.
Hmm. The problem with such probabilities is, much like winning the
lotto, no matter how rare they are, someone is bound to observe
"something" that is doing them, given the number of total attempts
(i.e., the number of objects, just on this planet, and the number of
fractions of a second that are available, even in a human life time). To
not happen, the odds would have to be so unlikely that they could only
transpire like.. twice in the entirely history of the universe? I am not
convinced.
void main () {
else
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
If that. Probably closer to 10^-100 times in the entire history of the
universe. If you're talking about something like all the atoms in a room
suddenly all going left and right, leaving you in the middle suffocating.
Remember, there's some 10^22 atoms of nitrogen in each gram of atmosphere in
your room. If each one is 25% likely to be going the right direction, what's
the likelyhood a kilogram of them will all go the right direction?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
