![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
clipka <ano### [at] anonymous org> wrote:
> It appears to me that there's even more potential in that piece than the
> classic church organ cliche - just listen to this:
> http://www.youtube.com/watch?v=Hg8Fa_EUQqY
Wow. I thought I was a heretic for getting into the whole Bach-on-a-piano
thing. I can't say I really enjoyed that interpretation, but at the same time
I don't see the whole point of strict interpretations. I was reading about
Sviatoslov Richter the other day. Among other things, he insisted on putting
an apology with a CD of the Italian Concerto for a single note he had missed
unnoticed for forty years. I mean those composers were pretty incredible, but
it seems wrong to elevate their works to that of unerring perfection. If you
have something to add, then why not?
That said, it is possible to go too far:
http://www.youtube.com/watch?v=dvpALlP_7lE
- Ricky
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That's quite impressive. I mean, anyone can do the handcuffs, but the
sack really is the coup de grace :)
...Chambers
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> Depends which stops. The bass pipes in particular tend to be slow to
>> speak, as do low diapasons. But reed pipes tend to speak very promptly.
> Never thought about that, interesting! So does that mean you have to take
> into account when to press the lower keys, that it takes longer and
> therefore you have to play them earlier than the higher notes and have to
> play quite "irregular" to get a "regular" sound"? That sounds very
> difficult to get right! And in fact, that could be a reason, why it
> sounds so awful in church sometimes ;).
In a well-maintained organ, all but the huge pedal pipes speak quite
promptly. I'm told you have to play the pedal notes fractionally early
(but only fractionally). Most of the other pipes have a delay short
enough for it not to matter too much. (It just means that, e.g., if you
play *really* fast notes, they don't come out very loud.)
Of course, a typical village church organ is another matter entirely... ;-)
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Orchid XP v8 <voi### [at] dev null> wrote:
> Don't be stupid. If it was a *quantum* organ, it would be completely
> silent until somebody goes into the room to listen to it - otherwise it
> would just be a superposition of all possible notes...
That may be only true if the Copenhagen interpretation of quantum mechanics
is true, which is not an accepted fact.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Isn't that a bit like saying that its not an accepted fact that the sky
is green due to large amounts of trees floating in the clouds? Its not
even "not accepted", its flat out wrong.
void main () {
if version = "Vista" {
call slow_by_half();
call DRM_everything();
call functional_code();
else
call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> mechanics
Quote from Wikipedia:
"According to a poll at a Quantum Mechanics workshop in 1997[7], the
Copenhagen interpretation is the most widely-accepted specific
interpretation of quantum mechanics"
So leaving aside that it /is/ apparently quite accepted (if only as a
theory instead of a fact), what makes you so sure that it is "flat out
wrong"?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> mechanics
>> sky is green due to large amounts of trees floating in the clouds? Its
>> not even "not accepted", its flat out wrong.
> wrong"?
The problem isn't the Copenhagen interpretation, its how it gets
misused. Observer, in the context of quantum physics, means, "What ever
happens to nudge the particle, causing it to change states." This
**can't** be a person, unless you can honestly think of some means to
invent an experiment where a particle(s) is held in a quantum state, and
you could get some fool to walk through the middle of them. So, no.. A
quantum instrument doesn't need someone "listening" to it to do
something. First off, such a thing doesn't exists *as* a device, unless
you have some mechanism by which you can change states *in* the device.
If you can do that, then the "observer" is already in the room, and you
don't need any conscious mind to be there for it to do anything. If it
lacks this capacity, then you could have one, 50, of 50 million, people
in the room, and its going to just sit their, doing nothing, because
"observers", as is commonly used to mean, "Something sufficiently
conscious to notice, and be aware of noticing, something else.", are not
even part of the equation. When the quantum tree falls in the forest, if
still makes a noise, because it hit something, not because something
where there to see hear it hit, same as a normal tree.
So, no, I am not griping about the Copenhagen interpretation, I am
griping about the inability of people to grasp that it doesn't mean what
*most* people interpret the interpretation to imply, vis a vie
consciousness. That isn't simply not implied by it, its outright
contradicted by it.
That said, sorry for the confusion. I had assumed that the term being
used applied to the poor reasoning derived from quantum theory and
people's misunderstanding of what "observer" meant, not the basic
principles of quantum physics, which invariably result in people
thinking that a "person" needs to be in the room for anything to happen.
void main () {
else
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
http://en.wikipedia.org/wiki/Bose%E2%80%93Einstein_condensate
Note that you can make these bigger than the room the equipment is in, so
theoretically you could walk thru it. :-)
> So, no.. A
> something.
This was, indeed, the whole point of the Schodinger's cat argument. Is the
cat alive enough to collapse its own waveform?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> take into account when to press the lower keys, that it takes longer
>> and therefore you have to play them earlier than the higher notes and
>> have to play quite "irregular" to get a "regular" sound"? That sounds
>> very difficult to get right! And in fact, that could be a reason, why
>> it sounds so awful in church sometimes ;).
Now, if you want a *real* problem... Try playing an organ where one of
the ranks of pipes is 200 feet above your head, so there's a split
second delay between hitting the key and hearing the note. ;-) Now try
that in a cathedral with a 7 second reverb time...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> the cat alive enough to collapse its own waveform?
Well, that would seem obvious. Its bigger than a single particle, so
yes. The point of the thought experiment was to describe the apparent
weirdness only, not to talk about macro level objects behaving as single
particles. ;)
void main () {
If Schrödingers_cat is alive or version > 98 {
else
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
