POV-Ray : Newsgroups : povray.off-topic : Now that's cool Server Time
7 Apr 2026 21:12:52 EDT (-0400)
  Now that's cool (Message 19 to 28 of 38)
Subject: Re: Now that's cool
Date: 26 Aug 2009 19:30:25
Message: <4a95c591$1@news.povray.org>
clipka wrote:
> Not really. If light slows down or speeds up as it approaches the earth
> (due to the "aether" exhibiting "local movement"), how could you
> possibly tell the difference?
They'd change apparent angles, methinks. I'm sure there's something clever
that could be figured out. :-)
> Now that's a puzzler to me: Isn't the electron known to have two
> "brothers" (muon and tauon) that differ from it only in mass?
Dunno. Probably.
> in which the propagation speed of
> disturbances must obviously be independent of the particular particle
> that caused them.
Don't ask me. I just know what the formula says. Or knew. IIRC.
I think the charge is based on probabilities of interactions between photons
and electrons. (I.e., the definition of "charge" is "how much the particle
interacts with the photon" or some such.)
   Understanding the structure of the universe
    via religion is like understanding the
     structure of computers via Tron.
Date: 26 Aug 2009 19:30:35
Message: <4a95c59b$1@news.povray.org>
clipka wrote:
>> Come to think of it, isn't the speed of any wave in an unchanging
>> unmoving medium
>> constant and dependent on the properties of the medium?
> It is [*]. But every medium (other than space) also provides a
> "standard" frame of reference: For instance, water waves on a stream
> will move at the same speed in all directions relative to an observer
> drifting on that very stream (the "standard" frame of reference), but
> relative to an observer on the bank they will move faster downstream
> than upstream.
> This is not so for light: No matter whether you're a stationary (hah!)
> outside observer or zipping along at near-lightspeed, you'll always see
> the light go at some 300,000 km/s relative to you.
We can't get out of the medium to observe light waves as we can with
water waves.
> [* Well, it is not /strictly/ true, unless the direction and
> polarization of the wave is also a given, as the speed of a wave may be
> anisotropic regarding these parameters; for instance, there are
> materials out there in which the speed of light depends on polarization,
> causing what is known as "birefringence"; but taking these constraints
> into account as well, you're right.]
I have heard the apparent decrease in the velocity of light is explained
by the interference of light
re-emitted by the material so as to give the appearance of a decrease in
velocity. But the "true" velocity
of the light remains that in free space. (I did not altogether
understand this and may have it wrong.)
>> I think two of his basic assumptions were (in my words):
>> 1) The speed of light is constant in all frames of reference.
> That was /the/ basic assumption of his theory of special relativity, yes.
>> 2) Other than that, the observations made from within any frame of
>> reference are valid
>> only within it.
> I'm not sure what exactly you mean by that. Maybe the "you can't tell
> whether your own frame of reference is being accelerated or at rest"
> assumption of general relativity?
That may be what I was getting at, but also the fact that the
"relativistic" effects
such as time dilation or increase in mass that I would observe in an object
(say a space ship) moving with 99.99% the speed pf light relative to me
are *not*
observed by its occupants and my observation is no more (or no less)
valid than theirs.
A lot of the paradoxes of relativity seem to arise from treating the
observations from two
or more frames of reference as if they were made from the same frame of
reference.
David
Date: 27 Aug 2009 01:35:25
Message: <4a961b1d$1@news.povray.org>
>> see the light go at some 300,000 km/s relative to you.
> water waves.
Well, then compare it with the perspective of a person actively
swimming: Despite obviously being inside the medium, from his point of
view water waves going in the same direction as he is appear to be
slower than those going in the opposite direction.
You don't even have that with light, no matter how fast you "swim".
Given that refraction normally occurs due to different /phase/
velocities of light in two materials, but at the same time there have
been experiments reducing the /signal/ velocity of light almost to a
standstill... no, I guess that's oversimplified.
> are *not*
> valid than theirs.
Which basically boils down again to saying that your /frame of
reference/ (which includes sort of a local definition of length) is no
more (or no less) valid than theirs.
Date: 27 Aug 2009 02:23:56
Message: <4a96267c@news.povray.org>
However, it must be pointed out that no human being has ever personally
managed a speed of any noticeable fraction of the speed of light to find
out.
I also have trouble with the notion that light emitted at the same time
from point x and point y, point x stationary to and point y moving
rapidly relative to point z, both beams of light will arrive at z at the
same moment, regardless of distance.  (Which was one of the bits
mentioned in a simplified explanation of relativity I read once.)
Tim Cook
http://empyrean.freesitespace.net
Date: 27 Aug 2009 03:05:35
Message: <4a96303f$1@news.povray.org>
The crucial thing here being "at the same time": Are you perfectly sure
what exactly constitutes simultaneity?
According to the theory of relativity, one can define simultaneity no
better than as "nearer in time than in space". For instance, an event
that happened a year ago (in /our/ frame of reference) two light-years
away is still happening "simultaneously enough" with whatever you're
doing right now.
If you were travelling at near speed of light, the spacetime region of
"simultaneity" does not change, even though you will percieve them as
happening at other spacetime coordinates - because you're using a
different spacetime coordinate system.
It's a bit like rotating objects in POV-Ray. Imagine POV's 3D space
representing a world of 2D space and 1D time. Pick any point and call it
"here and now". Let's say time is Y, and space is XZ. You can represent
"here" with a thin vertical cylinder, and "now" with a horizontal plane.
Now assume some object zipping through space at constant speed: It could
be represented by a slanted cylinder, right? So from that object's
perspective, "here" would be slanted.
But think about this: Your "now" is a plane perpendicular to your
"here". Why should that be different for the moving object?
Thus, accelerating an object does not mean to apply a /shearing/
transformation that would leave "now" untouched, but instead a
/rotation/ that redefines both "here" /and/ "now".
(With real spacetime, there is an additional quirk to it: For some
strange reason the "rotational" transformation associated with
accelerating an object appears to tilts its "now" plane in the
/opposite/ direction. Still, the above analogy may illustrate the
concept of a non-universal "now".)
Date: 27 Aug 2009 03:45:49
Message: <4a9639ad@news.povray.org>
clipka wrote:
>> time from point x and point y, point x stationary to and point y
>> moving rapidly relative to point z, both beams of light will arrive at
>> z at the same moment, regardless of distance.  (Which was one of the
>> bits mentioned in a simplified explanation of relativity I read once.)
Just a quick pedantic note to the otherwise good explanation -- since
the light beams in his example are arriving at the same point, z, he can
of course be sure what "arrive at the same time" means.
As far as Tim's concern here goes, you can actually resolve it perfectly
well without need for relativity.  Think of ripples in a pond.  If I
throw a pebble into the pond, or drag a stick through it, the ripples
from these two sources will move at the same speed, even though the
stick is moving with respect to the surface of the water and the pebble
is not (assume of course that the stick is moving slower than the
ripples do).  Viewing light in this way as waves propagating through a
medium (rather than particles as it seems you're thinking) is very close
to the pre-relativity view of light, and you can see how the speed of
light in this case would be independent of the speed of the source.
The surprising bit in relativity, of course, is that it's also
independent of the speed of the observer.  And in fact, as clipka has
alludes to before, this has actually been verified by experiment:
http://en.wikipedia.org/wiki/Michelson%E2%80%93Morley_experiment among
others.
Intuitively, the concept might be made more palatable by an analogy to
classical mechanics.  Let's say you're locked inside a train moving
straing at a constant speed with no windows on a perfectly smooth track.
  What experiment could you do that would tell you how fast you were
moving?  If you drop a ball you'll see that it always looks to you like
it falls straight down and gives no hit as yo your speed.  You'll find
that any mechanical experiment you concoct behaves the same way --
exactly as it would if it were at rest.  In some sense this isn't too
surprising since we hardly notice the the earth is racing through space
at thousands of miles per hour.
So on some level, it's intuitive that you can't do an experiment to tell
you what your "absolute" velocity is, you can only determine relative
velocities, for instance determining the velocity of the train relative
to the earth by looking out a window (if there were one).
The theory of relativity derives from assuming that this principle
*also* applies to experiments involving electromagnetic phenomena, such
as light, and that these too can't be used to determine your absolute
velocity.  It turns out that this being the case leads to a view of
space and time which is different from the naive one in a manner such as
clipka described, but omitting this counter-intuitive result the
postulates leading to it are actually quite sensible.
Date: 27 Aug 2009 04:36:38
Message: <4a964596$1@news.povray.org>
As for /arriving/ at the same time: Yes. As for being /sent/ at the same
time: No.
Date: 27 Aug 2009 04:53:07
Message: <4a964973$1@news.povray.org>
>> can of course be sure what "arrive at the same time" means.
> time: No.
Good point, I was implicitly taking x and y to be coincident at the time
of the light emission, but reading again this was an unjustified
assumption on my part.
Date: 27 Aug 2009 12:35:34
Message: <4a96b5d6$1@news.povray.org>
And, as I said, you can out-boat your wake. You can also fly supersonic,
which proves not only do the waves go different speeds relative to the
plane, the plane can actually outrun them.
Date: 27 Aug 2009 12:37:43
Message: <4a96b657$1@news.povray.org>
> out.
Of course they have.
You can put an atomic clock on Southwest Airlines and measure the error you
caused at the other end by being out of the gravity well and traveling at
velocity.
You can just leave one in the basement and one at the top of a skyscraper
for a couple months and measure the difference.
Assuming X and Y are both the same distance from Z when you start counting,
why wouldn't they? Even with regular waves, that'll happen.
