POV-Ray : Newsgroups : povray.off-topic : This is great Server Time
14 Mar 2026 15:09:29 EDT (-0400)
  This is great (Message 91 to 94 of 94)
Subject: Re: This is great
Date: 26 Aug 2009 18:07:50
Message: <qgcb95hdn97smtd7qk036te5pu4jl39i2l@4ax.com>
On Wed, 26 Aug 2009 23:40:55 +0200, clipka <ano### [at] anonymousorg> wrote:
>Darren New schrieb:
>>> My SIM card apparently can only hold 100 entries, and the entries are
>>> only just 1 name and 1 number.
>> Odd. That wasn't how I understood SIM cards to work in general.
>That's just the way it is - that's how they were standardized, back in
>the old days, when nobody ever thought about storing more information
>than just a person's phone number.
>Later, phone manufacturers found that the SIM card standard not only
>sucked at flexibility to store other things than phone numbers, or
>storage capacity, but also at retrieval speed.
Just over a year ago I got a new mobile (cell) phone. I had to get an upgraded
SIM as my original SIM was over 10 years old and several functions on the phone
would not work with it.
Regards
Date: 26 Aug 2009 18:19:44
Message: <4a95b500@news.povray.org>
The wonders of premature standardization.  Not that it seems better than the
alternative, mind.
Sure. I was under the impression that when you put the SIM card in, the
phone would read and cache the values for you in faster flash ram. I thought
there was more in there than just a simple one-number address book, but I
can see how that might happen, yes, with nobody agreeing on what else to put
in there, and nobody wanting (or being allowed to) specify
manufacturer-specific fields.
   Understanding the structure of the universe
    via religion is like understanding the
     structure of computers via Tron.
Date: 27 Aug 2009 03:25:17
Message: <4a9634dd$1@news.povray.org>
> It's possible your car grabs or grabbed the address book via the "transfer
> address book entries" when you first associated the phone to the car.
I think it grabs them each time the car/phone see each other (ie when I get
in the car and turn on the ignition).  It definitely shows entries that I've
added since pairing, but when I tried to add a contact while the car was on
it didn't show up in the car.
> Or... it could be using the SIM bit, if you have a SIM-based phone. (I
> don't.)
Everyone here has a SIM based phone, even my first Motorola brick had a SIM
card.  I have never seen a phone without a SIM card.
I can configure the address book on my phone to show or hide contact on the
phone and contacts on the SIM card.  Both sets show up in the car regardless
of the settings on the phone (I know this because they put a few
pre-programmed numbers on the SIM card when I got it which never show up in
my address book on the phone).  The contacts on the SIM card are useless
because you can't add any extra info to them, I don't know of any modern
phones that use the SIM for storing contacts by default.
> That I couldn't guess. Maybe lock your phone, then try to call from the
> car?
If you mean lock the keypad, then my phone almost always has the keypad
locked (in my pocket) when I'm in the car.  There is no problem making or
receiving calls.  I just checked on my phone and the pairing for the car is
called an "Audio Device", so I guess it just uses the protocols for
initiating and picking up calls, transferring the audio, and for
transferring the address book.  Works ok for me, I don't use the phone for
long enough to usually have to worry about the battery running out (I think
it has about 6 hours talk time and will last for about a week if I don't use
it much).
Date: 27 Aug 2009 12:27:30
Message: <4a96b3f2$1@news.povray.org>
> SIM card.  I have never seen a phone without a SIM card.
Verizon, on adopting CDMA, decided they didn't want to pay the extra
$3/phone or whatever for a SIM slot. :-/
> or receiving calls.  I just checked on my phone and the pairing for the
> car is called an "Audio Device", so I guess it just uses the protocols
> for initiating and picking up calls, transferring the audio, and for
Yeah, that's how my phone works, except it won't make a call if the phone is
locked. (Different from keyboard being locked - I can't even answer a call
if the phone is locked. It's a security thing, not an avoid-pocket-dialing
thing.)
