POV-Ray : Newsgroups : povray.off-topic : This is great Server Time
1 Apr 2026 18:23:07 EDT (-0400)
  This is great (Message 55 to 64 of 94)
Subject: Re: This is great
Date: 24 Aug 2009 05:18:57
Message: <4a925b01$1@news.povray.org>
> I take it you've never seen a program written for a cell phone, a
> set-top box, or an MP3 player?
No.
I have also never seen a program written to control a nuclear reactor.
I'm guessing that for such a program, machine efficiency is irrelevant
(if we need a faster PC, we'll just buy one), and program correctness is
the *only* criteria of any significance. I bet people writing such
software don't just accept random hangups and crashes as an unavoidable
fact of life. They fix them. All of them.
Anyway, embedded programming and safety-critical programming are both
very specialist. I doubt many people will ever see such code in their
lives. And I guess you could argue that games programming is pretty
specialist too... "Most" programs, after all, are either desktop
applications or web applications, and most of them just push data around.
Date: 24 Aug 2009 05:22:31
Message: <4a925bd7$1@news.povray.org>
Sabrina Kilian wrote:
> It looked like the problem was that the voidp was being free()ed in the
> event handler, and the data they wanted to pass into the event handler
> was something that couldn't/shouldn't be sent to free(). Maybe copying
> that data out to a malloc block would have taken too much time, since it
> was for controller inputs.
The way I read it, they had a structure with two integers and a void
pointer. "But we couldn't just add an extra integer field, because we'd
have to change a few thousand other functions." I'm not seeing why
changing a structure to have a new field which is only used in certain
places is a problem.
Then again, we're talking about a large, complex codebase. Maybe there's
something relevant they forgot to mention or something...
Date: 24 Aug 2009 08:41:31
Message: <4a928a7b$1@news.povray.org>
> No, what I'm saying is "if adding debug code alters all the bugs, how
> does that not make it scientifically impossible to remove all the bugs?"
It's virtually impossible to remove them all anyway (heck, you won't
even /notice/ some of the bugs).
And of course one develops an instinct where such Heisenbugs /really/
originate.
It's also the type of bugs where doing a long weekend (or sometimes a
long week) of "extreme debugging" will usually get you somewhere.
The worse problems are those where the error mechanism is plain obvious,
but is inherent in the software design, and fixing it invariably creates
a bug somewhere else, which can only be fixed by introducing a third
one, which in turn can only be fixed by re-introducing the first one...
seen such things happening; with such bugs "oscillating" for a month or
so before people decided to get back to the drawing board, and redesign
that part of the application. That was an embedded system - in a large
software project for an insurance company I was briefly involved in,
some bugs had allegedly been oscillating between "fixed" and "broken"
for years already.
Fortunately that kind of bugs doesn't suit my working mode: Repetitive
tasks - i.e. anything I encounter more than once - typically prompt me
to invest a lot of time and energy into making sure I never have to
spend any significant time on them a third or even fourth time.
Date: 24 Aug 2009 08:45:44
Message: <4a928b78$1@news.povray.org>
Sure. But if you know there's a bug there, but it vanishes every time
you try to fix it, then even though you know it's there, it must surely
be impossible to actually fix.
> originate.
Well, yeah, there is that. If you don't *do* crazy stuff with pointer
arithmetic in the first place, you're less likely to have problems.
In other words, the design of your application doesn't let you solve the
problem properly, and the only way to get it to work is with a hack that
doesn't work properly, which then introduces more problems that can only
be fixed with hacks... until eventually you figure out that it's less
work to redesign your application to work right in the first place.
[Can you tell how many large programs I've worked on?]
Date: 24 Aug 2009 08:47:49
Message: <4a928bf5$1@news.povray.org>
No. *Those* people make sure random hangups and crashes *never ever*
happen in the first place.
Well, at least I hope so...
Then again, nuclear reactors are designed in such a way that they don't
necessarily need a computer at all.
Date: 24 Aug 2009 09:03:01
Message: <4a928f85$1@news.povray.org>
It wasn't a structure: It was a callback function signature.
That is, there was some module to dispatch events; other modules would
ask this dispatcher module to call particular functions, as in "if a
controller button press comes in, please call me back; my address is XYZ".
Of course the dispatcher function would have to know what parameters to
pass to the function stored at address XYZ. For this purpose, all such
callback functions would conform to the same set of parameters - in this
case two integers and a pointer.
Something along these lines.
Date: 24 Aug 2009 09:14:33
Message: <4a929239$1@news.povray.org>
"Less likely" hits the nail straight on the head, in every sense.
Exactly! Except that typically some other bloke did the original design,
has already left the company, and first thing you need to figure out is
whether there was any reason he chose that braindead approach...
 From what statements I read from you so far, I'd guess they amount to
something like, roughly, let me think, about.. um - zero?? ;-)
Date: 24 Aug 2009 09:28:06
Message: <4a929566@news.povray.org>
>> we'd have to change a few thousand other functions." I'm not seeing
>> why changing a structure to have a new field which is only used in
>> certain places is a problem.
Oh, right. I thought it was a C struct.
If you're got to actually change function prototypes then, yeah, that's
not going to happen...
Date: 24 Aug 2009 12:02:10
Message: <4a92b982$1@news.povray.org>
Code inspection. You know as well as the computer does what the computer is
doing, so you can sit and pay lots and lots of attention to the problematic
code and figure out exactly what's going on.
Which is what amazes me about medical progress, where you *don't* know
exactly what's going on, but people manage to figure out (for example) what
DNA replication actually *looks* like, and how fast it goes, and etc.
   Understanding the structure of the universe
    via religion is like understanding the
     structure of computers via Tron.
Date: 24 Aug 2009 12:09:33
Message: <4a92bb3d$1@news.povray.org>
scott wrote:
> I guess they didn't bother with such things in the iPhone :-)
The bit I like best is where they count the number of bytes they received
before they turned off the receiver and then adjust the wake-up time they
program into the hardware, on the basis that the heat from running the
receiver will have made the crystal run at a different speed for the next
1.28 seconds they're asleep, and you don't want to wake up too soon or too
late. :-)  Scary stuff going on inside there.
I also found out that while my car has a bluetooth headset feature built in
that lets me make hands-free calls from the car without taking the phone out
of my pocket, lots of cars in Europe use the "SIM profile" of bluetooth. So
there's an entire phone built into the car that just wirelessly accesses the
SIM chip, pulling in the phone book of whoever is in the car and everything.
Very cool.
