![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ah yes, another day, another piece of stupidity to sort out.
We have some equipment in our lab. It needs a computer to control it.
Unfortunately, the control software requires somebody to be logged in.
As soon as you log out, it quits the control program, halting the machine.
But don't worry. There is a straight-forward way to solve this problem.
We have some other software, which we are already using, which has the
facility to control this equipment. And *this* software runs as a
service, as it should, and has appropriate security access controls and
auditing and so forth. This will make our job vastly easier - even
easier than it is currently.
So we're _not_ going to use this feature. Why? Because the people at HQ
don't use this feature. Currently all the sites work slightly
differently, and the people in charge want to "harmonise" business
practice across all sites. In English, they want everybody to do exactly
what HQ does.
I should point out that when somebody asked HQ for the wiring diagram to
connect up a certain piece of equipment, their senior lab expert sent
back a diagram that includes, among other things, a paper clip to
complete the circuit. (We won't be following this practice. We elected
to use a junction block, like any half-sane person would...)
Getting back on track... How *are* we going to control this equipment
then? Well, the solution dictated to us by HQ is to use a seperate
laptop to run the control software. Which seems reasonable, if not
particularly optimal.
Ah, but here's the fun part: The equipment is controlled by RS-232. Now,
how many laptops do you know of which actually possess a serial port?
Exactly.
But it's OK, it's not a problem. All we have to do is purchase a USB to
serial converter and we're golden.
Except that the control software stubbornly, repeatedly *refuses* to
believe me that the USB serial port actually exists. Every other piece
of software I've tried can access it without issue. But not the one
piece of software that we *need* to access it. No sir. Not interested.
It can "see" the port, but it refuses to *select* that port. And nothing
I've done so far seems to convince it to work.
I also got sent three laptops from HQ which have built-in serial ports.
The reason for this is that they're ancient. One of them is already set
up and running. One of them won't turn on. The charging indicator comes
on when I plug it in, but it won't actually switch on. And the third...
well, I was hoping to set that up today.
I became worried when I saw the big "Designed for Windows 98" sticker on
it. The harddrive is a mess. It has every application, screensaver, game
and utility imaginable installed. It has files everywhere. My plan was
to erase everything and load Windows XP, except - and you can see the
horrifying inevitability of where this is going - the laptop is powered
by an AMD K6-II processor and sports 64MB of RAM.
Now there is no way in HELL that Windows XP is going to run like
anything faster than a glacier with 64MB of RAM. Hell, Windows 98 crawls
along on this PC!
Clearly improving the CPU is impossible, but maybe adding more RAM would
speed it up? Except... what the hell kind of RAM does a K6 laptop take
anyway? Wikipedia claims that the K6 has a 66MHz FSB, so... PC66 maybe?
Of course, that's no longer on sale. But Wikipedia claims PC100 is
backwards-compatible. Ah, but *that* isn't available either. But I can
buy PC133. Wikipedia claims PC133 is backwards-compatible with PC100,
but is that transitive? Will PC133 work in a PC66 laptop?
128MB is really not enough. But the biggest single-stick listing I can
find is for 512MB (which should probably just about work). Then again,
this is a *laptop*. How many tracks do you think Compaq bothered to
connect up? Can it actually address half a gigabyte of RAM??
Still, I have until tomorrow to sort all this out... no biggie.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <4a815b1f$1@news.povray.org>,
[...] LOL! I mean, sorry.
You know, the whole idea of working somewhere and having to accept
tyranical measures is wrong. Work is far too important to leave it up
to others. It is the very foundation of one's life.
I do know what to do in my case, but I don't know what to do in
everyone's case. I don't think I ever will. But I do think that one
must think about saving oneself from the tyranny of companies.
Particularly because we can. Or can't we?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The more I think about this, the more I'm losing the will to go on. All
this effort to jump through hoops to hook up an elaborate jerry-rig of
obsolete hardware to solve a problem which we ALREADY HAVE A PROPPER
SOLUTION FOR. The correct solution is right in front of our eyes, so
we're just going to ignore something and build something that's going to
cause us problems for years to come instead. WHY?! >_<
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
What happens if you use it anyways?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
HQ gets upset because you don't follow protocol. You get upset because they
require an unreasonable solution. They get more upset because you are now
deliberately disobeying orders. You get more upset they don't listen to
reason. They get upset because they can't simply apply one rule to all groups
and create a nice, perfect world. Meanwhile, both groups think the other is a
collection of complete idiots, too stubborn to just do the reasonable thing,
solve the problem, and move on.
At least, that's how it works around here. Now, it's an external contract so
it's a little different, but really it's basically the same. They used
incorrect physics to redesign the prototype so it can use a little less power.
We know it won't work and don't want to go down that road. We try to explain it
to them, but they just get upset that we refuse to help them. And it goes back
and forth.
- Ricky
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Indeed, my advise would be to find an (obscure) british rule about
quality control that could be interpreted to the effect that the HQ
solution being illegal. There may be a rule about using an OS that is
unsupported and therefore vulnerable to any new virus that comes out.
OSLT. Andy, use your knowledge, you know more about legal requirements
than HQ.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <4A8### [at] hotmail com>,
> than HQ.
That's good thinking. One could actually find in the law the support
needed to defend oneself from corporative despotism. I just hope you
can find something in the law... :-)
Also notice this can always get one fired. Disobedience is not at all
praised out there.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> praised out there.
Depends on the job and the company, and the reason why. If a company is
making you do something that could get you put in jail, disobedience is
the right course of action.
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The MHRA gets upset with us for using a software feature which we
haven't performed extensive formal testing on.
Now, we *could* devise and execute a test plan... but nobody here really
has the necessary expertise. HQ does. And they can't be bothered to go
down this route.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
What OS can the software run in? You might make use of virtualization
(VMWare, VirtualPC, etc.) to solve your problem.
You should be able to control the properties of the virtual machine and
tell it it has a serial port even if it doesn't. Running an old OS
within a virtual machine on a modern laptop should still be faster than
running the same OS on its native hardware.
-Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
