POV-Ray : Newsgroups : povray.off-topic : New Computer Server Time
15 May 2026 16:29:57 EDT (-0400)
  New Computer (Message 11 to 20 of 79)
Subject: Re: New Computer
Date: 13 Aug 2009 14:47:30
Message: <4a845fc2@news.povray.org>
In article <web.4a8416c5481dd0af6dd25f0b0@news.povray.org>,
Bill Pragnell wrote:
> Has anyone ever run the benchmark on an abacus?
Taking this seriously, an abacus is not comparable to a computer. The
abacus is like... just the RAM memory. We need a processor.
Date: 13 Aug 2009 14:56:16
Message: <4a8461d0@news.povray.org>
  Actually an abacus is more like one single integer register (or a few,
if you split the "bits" among several "registers"). It could only be used
to store and manipulate one value (or a couple) at a time. You would not
only need a processor to actually execute the raytracing opcodes, but you
would also need some external "RAM" to store intermediate results. The abacus
by itself is certainly not enough for any of this.
  (Not to talk that an abacus probably wouldn't have enough "bits" to do
any kind of sensible raytracing anyways.)
Date: 13 Aug 2009 15:00:44
Message: <4a8462dc$1@news.povray.org>
In article <4a8461d0@news.povray.org>,
Hm. I don't really know how an abacus works. I only have a vague idea,
which is (or was): you move those beads to remind you of numbers. :-)
So I said: well, that's just RAM.
Anyway, I could go out on the web to find out how it works, but if you
feel like, why not explain it to a slow person?
Indeed. But we can imagine a huge one?
Date: 13 Aug 2009 15:29:36
Message: <4a8469a0$1@news.povray.org>
Mike Raiford schrieb:
>> Beta 33 renders the benchmark with 4 threads in 1m58s :) :) :)
> My Core2 Quad system rendered it in 1m47 s :-D
> But then, my processor is a 2.8 ghz.
So you think 10s less is a big win? Then dig this - Core i7 Quad 920,
2.67 GHz (probably running at 2.8 GHz though, too):
	1m 15s !!
Gee, I guess I love this machine :P
Date: 13 Aug 2009 15:52:29
Message: <4a846efd$1@news.povray.org>
> Except it's not a bit faster than it was in 1999 when you go to render a real
> scene.  It just looks a little better.
LOL - indeed :-)
Date: 13 Aug 2009 15:57:04
Message: <4a847010$1@news.povray.org>
Nah, I was surprised that it was so close though. The 1m57s time seemed
really fast.
>     1m 15s !!
Yep, the i7's are speedy little beasts, from what I've seen. Does
hyperthreading help at all?
~Mike
Date: 13 Aug 2009 16:05:49
Message: <4a84721d$1@news.povray.org>
TC schrieb:
> It would be interesting to know PovRay benchmarks on different OS - like 32
> / 64 bit Windows XP / Vista, Linux, etc. Just to get a feeling how much of a
> brake the OS is, and how great the influence of DRAM type, speed and
> frequency is.
As already posted: 75 seconds on a Core i7 920 @ effectively 2.8 GHz, 6
GB DDR3-RAM (I'll look up the speed next time I boot), running Windows
XP Prof. x64 Ed. (using the 64-bit binary of POV-Ray of course).
Subject: Could you try to run the benchmark with 32-bit binaries?
Date: 13 Aug 2009 16:51:09
Message: <4a847cbd@news.povray.org>
Could you run the benchmark with 32-bit PoyRay binaries? It should not take
too much time to download - and less then two minutes for you to run. ;-)
I really would like to know if there is any influence and how much of it.
When I built my new PC I toyed with the idea of an i7 but found it a bit too
expensive in relation to the benchmarks I saw. Then I pondered the idea of a
64-bit XP instead of the 32-bit I am currently using. Decided against it
because of possible driver-problems and because I had no idea if it really
would be a lot faster. I did not really see much sense in using 64-bit
Vista - I hate the Vista OS from the bottom of my heart.
Then, of course, the i7 is the better processor anyway.
"clipka" <ano### [at] anonymousorg> schrieb im Newsbeitrag
news:4a84721d$1@news.povray.org...
>> 32 / 64 bit Windows XP / Vista, Linux, etc. Just to get a feeling how
>> much of a brake the OS is, and how great the influence of DRAM type,
>> speed and frequency is.
> As already posted: 75 seconds on a Core i7 920 @ effectively 2.8 GHz, 6 GB
> DDR3-RAM (I'll look up the speed next time I boot), running Windows XP
Date: 13 Aug 2009 17:49:53
Message: <4a848a81$1@news.povray.org>
>>     1m 15s !!
Yep.
Running on a single thread, the benchmark takes 6m 10s = 370 seconds;
therefore, even under ideal conditions, without hyperthreading it could
run no faster than 93s. So although hyperthreading doesn't halve this,
at least it reduces the render time by another 20%.
So in terms of computing power, for the sake of raytracing it's roughly
equivalent to adding a 5th core.
I guess it depends on the main memory speed though: I guess HT mainly
serves to reduce the idle time while the CPU is waiting for data from
the main memory; so for machines with slower RAM (speaking of latency),
it may be even more of a benefit.
I also heard tell there may also be differences between OS. I'm running
XP Pro x64, maybe Vista or Win7 do an even better job at making use of
HT. Don't know about this though.
Subject: Re: Could you try to run the benchmark with 32-bit binaries?
Date: 13 Aug 2009 18:10:45
Message: <4a848f65$1@news.povray.org>
When I bought the i7, I had the dealer install Windows 7 on it, having
heard that its UI fixed a lot of annoyances in Vista (which I never
tested, btw).
Two days later I had them order XP Professional x64 Edition for me.
Works like a charm.
BTW, 64 bit is not mainly about speed, but support for more memory. You
know, when rendering scenes with 8 GB of texture data and such...
