On Mon, 03 Aug 2009 19:23:55 -0700, Chambers
<Ben### [at] gmailcom_no_underscores> wrote:
>clipka wrote:
>> Q: How does this sequence continue?
>> M D M D _ _ _
>> A: No, it's not "... M D M", it's "... F S S".
>I've seen plenty of tests that ask you for the pattern, and I get
>seriously annoyed that the writers of the test didn't think of *my*
>pattern. After all, *mine* is perfectly logical, and describes the
>demonstrated sequence exactly... so why *isn't* it the correct answer?
It is a correct answer but one that the point giver gives zero points for. Thus
showing the meaninglessness of IQ tests.
Regards
>>> M D M D _ _ _
The question is about the particular sequence MDMDFSS. Not 'any
sequence that begins with MDMD'. So anything other than 'FSS' is not
*the* correct answer. It is, however, their fault that the sequence
does have other obvious continuations. A bit like saying "1, 2, 3, ...,
what comes next?", it could be 4, it could be 5, it could be 10...
Saying that that shows the meaninglessness of IQ tests implies that IQ
tests are composed entirely of questions where there are multiple valid
(and more obvious) answers. They're not. They *are* generally geared
towards the culture of the person taking them, however. Perhaps they
just need greater specialisation for particular sub-sections of
cultures? ^_^
Tim Cook
http://empyrean.freesitespace.net
I beg to differ; the question is about tricking people and showing the absurdity
of improperly defined tests. You might say that the "_ _ _" indicates that there
are only three more letters in the sequence. But the similarity between "_ _ _"
really diferentiate IMO. As you point out.
"FSS" is the "correct answer" for one set of circumstancies.
>cultures? ^_^
Again I dissagree with what you wrote. When you say that "They *are* generally
geared towards the culture of the person taking them" that is the reply to the
critisim that IQ tests are culturely dependant. It does not take into account
education and different types of brain development. I believe that IQ tests are
a flawed concept. If it were not then you would not be able to better your score
by any significant amout, again IMO.
I suspect that you don't really disagree (-_o)
Regards
On 4-8-2009 0:40, Stephen wrote:
> On Mon, 03 Aug 2009 22:03:00 +0200, andrel <a_l### [at] hotmailcom> wrote:
>> Or perhaps you are not as bad as my wife, she is able to really quote
>> verbatim (or at least that is what she claims). Quoting both herself and
>> the other person literally without any indication that it is a quote and
>> by whom. Which means that if she uses 'you' she can mean either that
>> other person or herself if she is quoting that other or me if she has
>> ended the quote. I find it rather confusing at times.
> Ah! A mere male. :) Thus is a common condition for us ;)
Yes a mere male. I can do 4D visualization in my head, but I can't
handle insufficient or conflicting information.
>> Also sometimes confusing, but what happens to more people, is mentioning
>> only a first name and leaving to the other person which one of the Johns
>> you both know is meant.
> But you know that Jan Wit would never do that and Jan Zwart is doing it all the
> time so it must have been Jan who said it. Yes or no? :-)
Well no, more like 'Jean called...' and I have a cousin called Jean who
might have called, she has a brother with that name as has of our
neighbours and a close collaborator or two. All might have called and it
is up to me to figure out which one. You can only do that if at some
point she refers to something you already know. In which case there was
no point in mentioning it (for a male). Luckily she is a woman so there
is a good change that somewhere she mentions a couple of things she told
a few times before. Then you only have to hope that it is specific
enough and you can figure it out before she figures out you don't have a
clue who she is talking about.
On 08/03/09 21:21, Chambers wrote:
> That, at some point, you have to make a decision about who gets which
> treatments, taking into consideration all the relevant factors (age,
> other conditions, likelihood of success, and cost). Excluding any one of
> those factors - even cost - would be irresponsible.
> Once you admit that there's a cutoff point somewhere, then it no longer
> becomes a question of whether or not certain people will be denied
> treatment, but only a question of where that cutoff point is.
So, what's the cutoff point in Canada, the UK, and France? Citations
should be included.
And, BTW, are you suggesting that insurance companies don't emulate
cutoff points?
On a Taxidermist's window:
"We really know our stuff."
On 08/03/09 21:24, Chambers wrote:
> Neeum Zawan wrote:
>> On 08/02/09 22:57, Chambers wrote:
>>> I've seen interviews with several people from his staff who talked of
>>> the pressure exerted on them to present information that fit in with the
>>> higher-up's views (though it's not clear if the pressure came from Bush
>>> himself, or if Cheney was trying to keep him misinformed).
>> Oh sure. However, that doesn't translate to "deluded".
> OK, then, maybe "deluded" is a bit strong. "Misinformed," perhaps? Or
> even just "biased?"
I have to disagree. He/they weren't insisting that intelligence reports
say what they wanted them to say so that they could
misinform/bias/delude themselves, but so that they could
misinform/delude the public.
> should be included.
Why? I'm simply saying that you should consider all factors, not that
any particular cutoff point should be used.
> cutoff points?
Not at all - I think insurance companies do a great job of figuring out
when it's feasible to pay for something and when it isn't.
I was responding to what you wrote:
"3. Most of the people I hear from who are against universal health care
don't claim the US is near the "best". They claim that people who "work
hard and earn a lot" should get some sort of priority over deadbeats who
don't. (Not my view, but thought I'd point out that it's not about being
the best). Effectively, the argument is that access to health care is
not a human right"
I was basically saying that health care is NOT a universal right, but
rather is a privilege which is awarded when money is available. I'm not
saying anything about how often it should be awarded, or how much money
we should make available.
Chambers
Stephen wrote:
> I believe that IQ tests are a flawed concept.
I agree. Any meaningful test needs to have a much more specific focus.
Chambers
I, for one, don't agree. What's wrong with the concept of a generalised
test to determine an individuals approximate level of mental development?
Of course, I also vehemently disagree with my ex-landlord's position
that anything said by someone who is mentally impaired is invalid
explicitly because they're mentally impaired. That would mean if they
were able to say "one plus one equals two", regardless of understanding,
that must then be treated as false. Which is absurd. (That whole can
of worms had been opened by my incidental use of the phrase "can't we
all just get along," which I still think was in use from the 1960s at
least, not coined by Rodney King, even if he popularised it.)
*cough* Sorry. Ex-landlord had a lot of notions which were of dubious
veracity. Like thinking it'd be better to launch satellites from the
polar regions due to lesser gravity (Earth being an oblate sphereoid)
and thinner atmosphere, instead of as they are, from as close to the
equator as possible to get the momentum boost from the rotating Earth.
And the US Navy's nuclear submarines being able to be completely
remote-controlled if you send them the right access codes (since it was
in some movie). And the US having low-yield nukes (specifically nukes)
that don't produce radiation, or if they do, it decays within days,
instead of a century or so. And file permissions and user accounts in
UNIX being an add-on module that you had to specifically compile,
separate from the filesystem, with (modern) UNIX systems having
programmer-embedded backdoors at the OS level to permit complete access
to everything in case the admin forgot their password...and claiming
that a friend decompiled Windows and, by removing commented code,
decreased the recompiled executable and library size significantly.
Tim Cook
Well, that one's true. It's called "single-user mode." ;-)
"We'd like you to back-port all the changes in 2.0
back to version 1.0."
"We've done that already. We call it 2.0."
