![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Darren New wrote:
> gregjohn wrote:
>> Whoa. I've listened to a whole year of Astronomy Cast, and I thought
>> that the
>> Big Bang *was* about the creation of matter.
> The big bang is postulated because everything is moving apart. If you
> reverse time, everything is moving back together again. Much like people
> knew what temperature was "absolute zero" long before they could get
> anywhere close to making it in the lab.
> > It is precisely not, as once
>> described by Cal Thomas, a scenario you seem to agree with, "the
>> explosion of
>> an eternally existent cosmic egg."
> You can have an explosion of an eternally existent cosmic egg without
> creating matter. Indeed, if it's eternally existent, that's precisely
> the point I'm making.
>> Big Bang = Gen 1:1
> Well, no. That's exactly my point. In the beginning was *everything*.
Everything within the bounds of what we can test, based on a "time
based" theory of events. Problems is, we have no way to be sure if the
properties of this universe are "derivative" of earlier conditions, or
what exactly. And... trying to shoehorn any part of Genesis onto the
mess is absurd. Even more so since I am "pretty sure" his version of 1:1
bears no resemblance to the original wording, and even if it did, the
rest of it is all ***wrong*** from the standpoint of every damn thing
that happened after.
Its like someone saying:
"A well, first I starting by breaking some eggs." - Ok, sure.
then following with:
"Then I pored the batter into a pan, followed by mixing in the flower,
and then I put it in the oven. Oh, and after that, I added flavorings
and baking powder, took it out to cool, and finally, turned the oven on."
The first line is *maybe* an OK starting point, but the rest just shows
that the moron writing it neither knows anything about baking
"anything", but didn't even bother to go about thinking to hard as to if
any of the entire process even made any damn sense in the first place.
But, this is what Bible believers think "correctly" describes the
process, even if they are still arguing over if days are days, and if
not, how many years, centuries, millennium or billions of years it
happened in?
The closest Genesis 1:1 comes to getting the Big Bang is that they had
to start with something, and some stoned sheep herder looked around at
night, saw a huge, vast, something, with a bunch of dots on it, and
went, "Hell, lets say that was the first bit. I mean, its just a big
sheet with holes, or something, and god had to start with the real
'simple' stuff first, just like people do, right?" Sadly.. Its the most
frakking complicated thing that happened first, and everything else is
matter trying to make **simple** order out of the resulting near
infinite chaos.
void main () {
If Schrödingers_cat is alive or version > 98 {
if version = "Vista" {
call slow_by_half();
call DRM_everything();
call functional_code();
else
call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Darren New wrote:
> clipka wrote:
>> Darren New <dne### [at] san rr com> wrote:
>>> Altho, thinking on it more, I'm pretty sure you're going the wrong
>>> way. If
>>> time slows down near the black hole, and *you* are near the black hole,
>>> everything else will seem to speed up. :-)
>> Yeah, but for "everything else"
> Yep. But if you're talking about the Big Bang, there *is* no "everything
> else". ;-)
Only from our perspective. It doesn't preclude other universes, one big
one that fragmented, or even a mass of energy that reached *its* version
of singularity, but lacking the far more limited constraints of our
dimensionality, produced pocket universes, instead of black holes. Its
one of the major problems that string theory has. How do you prove the
math, when the math allows for trillions of possible configurations, but
you are only interested in testing it against your *specific* one.
Basically... You can't expect math that deals with "general" probability
of any random game of chance, to *correctly* predict only the behavior
of games using 3 dice. Why not? Because the equations are talking about
everything from roulette wheels to games with 10,000 dice. All you can
say with certainty is a) when you found the parameters that match *your
game* well enough that you can use it to make solid predictions, and b)
what the limits and constraints on those statistics are, such that some
configuration cannot exist "outside" those bounds. For example, you
might find that, in a chance game, for some odd reason, the math doesn't
allow for 10,000 dice **and** a Roulette Wheel *at the same time*, or
something to that effect.
This doesn't help you at all though to know the *correct* parameters for
your game, automatically, nor to know what the result of every game that
has 1 dice and wheel, or 3 wheels and 5,000 dice, or 1 wheel and 9,999
dice. In other words, confusing as hell, unless you already know enough
to figure out what variables *must* be plugged in to get the result, at
which point, only then, can you start figuring out, "Why?".
void main () {
else
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I appologize in advance, but I just can't resist the overwhelming
temptation to post a quick link to my favourite Bible reading where
Ricky Gervais reads from Genesis:
http://www.youtube.com/watch?v=E_EXqdJ4L7I&feature=related
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I honestly didn't understand what was supposed to be so funny. I suppose
I just didn't get the jokes.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well it's not really joke-based humour. It's largely based on an ironic
counterpoint to the sort of upbringing that was common here at one time;
with the gospel being taught as if it were the gospel truth (beyond
question) and with people being left in relative isolation to work out
that there might be something about it that doesn't quite ring true. I
suppose the humour does therefore derive from quite a particular set of
experiences.
(Not that it ever really works to analyze or to try to explain humour)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
