POV-Ray : Newsgroups : povray.off-topic : Tell me it isn't so! Server Time
15 Jun 2026 15:12:01 EDT (-0400)
  Tell me it isn't so! (Message 34 to 43 of 473)
Subject: Re: Tell me it isn't so!
Date: 22 Jul 2009 03:47:55
Message: <4a66c42b$1@news.povray.org>
> I really don't know the significance of the ".net" extension
> attached to a program name,
You don't really sound too qualified then to complain about the "needless
complexity" :-)
Date: 22 Jul 2009 04:04:25
Message: <4a66c809$1@news.povray.org>
>>   The whole idea of object-oriented programming is to make it *easier* to
>> write programs, especially compared to straightforward
>> imperative/structured
>> programming (as the SDL is currently).
> That I cannot believe!!
Why not?
Did you ever try to write a macro in SDL to position or rotate an object
relative to the camera?  You can't tell me that an OOP version wouldn't be
simpler!
Date: 22 Jul 2009 04:10:47
Message: <4a66c987@news.povray.org>
> (Laugh) I love it! What can be off-topic to off-topic?  What you mean, I
> think, is that
> this topic is forbidden! Or maybe simply unwanted.
No, it really is just the wrong group here.
If you look in the pov4.discussion.general group you will see that this
subject has already been discussed a lot, so please read through the posts
there, and if you feel you still have something to add then by all means
start a new thread.  Nobody is going to flame you for a forbidden topic, I
assume that the developers want input from as many users as possible when
deciding what to do for POV4.
Date: 22 Jul 2009 04:21:33
Message: <4a66cc0d$1@news.povray.org>
>> 2. What would be so bad about this being true?
> It would be too complex to be usable by ordinary folk (i.e. me).
I doubt it.
Just because Java is OOP done wrong, and C++ is a superset of an already
complicated language, doesn't mean that OOP is inherantly complex. It's
actually quite a food fit for scene description/construction/inspection.
>> 3. What the hell is EEP?
> Extremely Elite Programming (my coinage)
Yes, well, things like Java are *just a tad* over-hyped, yes... ;-)
Subject: Re: Tell me it isn't so!:Apparently it is!
Date: 22 Jul 2009 04:24:12
Message: <4a66ccac$1@news.povray.org>
clipka wrote:
> Yes, I personally do advocate going for strong OOP-support with POV-Ray 4 SDL. I
> do so as a POV-Ray user, and I do so as a contributing developer.
> Yes, I did present a serious proposal for a new, OOP-enabled SDL in the povray 4
> newsgroup some months ago.
> Yes, being active in the development of POV-Ray 3.7 I *may* happen to personally
> get my hands dirty on the code of POV-Ray 4's SDL engine.
So it is so after all
Date: 22 Jul 2009 04:35:18
Message: <4a66cf46$1@news.povray.org>
> be simpler!
Yes I have; maybe an OOP version would be simpler. The current SDL is
not without flaws.
Maybe OOP would magically fix them. I guess I'll find out if I continue
using Pov-Ray. As I
seem to be the lone objector to the Pov-Ray SDL going OOP, I don't
suppose there is much
point in my saying more. After all, I'm assured that such changes will
be for my own good.
Date: 22 Jul 2009 04:39:51
Message: <4a66d057$1@news.povray.org>
clipka wrote:
> Once you've embraced the OO paradigms, you'll no longer wonder whether it's a
> step back or sideways - you'll know that it's a step forward.
This is where I mutter something about functional programming being the
future, and everybody agrees with me...
Date: 22 Jul 2009 04:55:09
Message: <4a66d3ed@news.povray.org>
clipka <nomail@nomail> wrote:
> [-- text/plain, encoding 8bit, charset: iso-8859-1, 19 lines --]
> Warp <war### [at] tagpovrayorg> wrote:
> > David H. Burns <dhb### [at] cherokeetelnet> wrote:
> > > >   Do you really think a new programming paradigm would be developed and
> > > > get widespread if it was *harder* to use than older, ascetic imperative
> > > > approaches?
> > > Yes, (though I have no idea what  "ascetic imperative approaches" means)
> > > such things have
> > >   happened more than once!
> >   Yeah, sure. I'm now convinced that OOP became so widespread regardless
> > of being significantly harder than imperative programming.
> Hm - just as a side note here: I thouht *you* were trying to convince *David*?
> Just pointing out that his objection against your point makes a poor argument
> in favor of his point... that's a rather weak point in itself.
  It was just sarcasm. Whether the sarcasm is a strong or weak argument is
irrelevant at this point.
Date: 22 Jul 2009 04:55:26
Message: <4a66d3fe$1@news.povray.org>
> As I
I very much doubt that - but it will help your cause if you a) write about
it in the correct place (ie not this group) and b) explain yourself a bit
more rather than just "OOP makes things more complex" - because for most of
us here that is just the opposite of our experiences.
Do you have any alternative ideas for what the POV4 SDL should be like?
People will certainly discuss them with you in the pov4 group.
Date: 22 Jul 2009 05:05:33
Message: <4a66d65d$1@news.povray.org>
You may be right. The complexity that I see in C++ may derive mainly
from C. C,
in my experience, is a fascinating and addictive language, but it
apparently allows,
maybe encourages, writing code so complex as to be almost
undecipherable. Maybe
it bequeathed that legacy to C++ and other OOP languages and that it is
really foreign to
OOP. Of course it matters little if OOP is not "inherently" complex if
all existing instances
  are. The concept of an "object" which contains both data and functions
which can operate
on the data is itself a useful and valuable, but at present, I see
little of value in the additional
trappings of OOP. Its not O, but OP that I object to. And I don't really
see the logic in spending
months preparing to write a program that could be effectively written in
a simple language -- if such
had survived.
