POV-Ray : Newsgroups : povray.off-topic : Today's venom: Acrobat Server Time
14 Oct 2024 11:14:35 EDT (-0400)
  Today's venom: Acrobat (Message 1 to 10 of 83)
Subject: Today's venom: Acrobat
Date: 29 Jun 2009 06:44:19
Message: <4a489b03$1@news.povray.org>
Ah, Adobe Acrobat.
Of course, you can obtain Acrobat Reader for free. (What good is an
authoring tool without a ubiquitous platform to deploy for?) But the
But what the hell do you actually *get* for your money?
Of course you get the ability to generate PDF files. But you know what?
Any number of freeware tools can do this also. (E.g., Ghostscript can
transform PostScript to PDF. All you need is a PostScript printer driver
- and Adobe just happen to have one available for free download - print
your document to a PS file, and then have GS convert it to PDF. Done.)
My goal today was very simple:
1. Take a PDF file and remove the headers and footers.
2. Overlay one PDF file over another.
achieve this trivial goal.
As far as I can tell, Acrobat can rearrange pages, delete pages, insert
pages from other files, and this split or merge seperate PDF files. It
can rotate pages, and it allows you to edit metadata and security
restrictions.
What it does *not* appear to allow is modifications to the actual
contents of the pages. You can add [extremely limited] additional
graphics and text, but you *cannot* remove what is already there. Which
is obviously absurd. You also can't copy content from one page and paste
it onto another page, completely preventing the overlay I want to do.
In short, I've got two digital files in front of me and the premium
editor program for that file format, yet I cannot achieve my trivial
aim. I am actually going to have to PRINT THIS STUFF OUT and play with
glue and scissors. How pathetic.
Subject: Re: Today's venom: Acrobat
Date: 29 Jun 2009 07:04:46
Message: <4a489fce$1@news.povray.org>
I always thought of PDFs as the digital version of print-outs.  Think what
you would do if someone gave you two printed out sheets and asked the
above...
BTW, you might be able to find some software that renders a PDF to an image
file, then use some paint program to do what you want.
Date: 29 Jun 2009 07:07:01
Message: <4a48a055$1@news.povray.org>
Before doing this, you can also simply use the copy tool (the one with
the camera icon). Copy and paste the parts of the documents you need
into a grapical program (or combine them as povray image_maps :-). nd
you're done without scissors.
Thibaut
Date: 29 Jun 2009 07:53:06
Message: <4a48ab22$1@news.povray.org>
They are. Except that unlike a PostScript page description (which is an
unstructured arbitrary Turing-complete program which may or may not
produce an image as a side-effect of its execution), a PDF file contains
sufficient metadata to be easily manipulatable. (E.g., it's not
Turing-complete, it's easy to locate a specific page, it has a bounding
box included, etc.)
> Think
> what you would do if someone gave you two printed out sheets and asked
> the above...
Yeah, well, if digital printouts have only the same functionality as
real printouts, then they're rather pointless. We may as well just use
> image file, then use some paint program to do what you want.
Both Ghostscript and Acrobat will happily transform PDF into a bitmap
image. (Though Acrobat will only produce Windows Bitmap - the most
braindead image format in widespread use.)
The trouble is, then the pages would be bitmap images. That means that I
can manipulate then with IrfanView. On the other hand, it means they'll
either be vastly lower resolution than the original vector graphics, or
they'll be absolutely huge files...
Date: 29 Jun 2009 08:47:01
Message: <4a48b7c5$1@news.povray.org>
> Yeah, well, if digital printouts have only the same functionality as real
Except I can send a "digital printout" to 50 different people in 5 different
countries within a few seconds from my desk, try doing that with real
printouts :-)
What's your printer? 600dpi?  Just convert them into bitmaps using that
resolution and do your work on it, then save them to PDF again.  It's quite
common to work on A4 size at 600dpi on a normal PC these days...
Or, presumably, if you are meant to be modifying these documents, then you
can just ask the original author for the original files to modify?  That
might be easier in the end.
Date: 29 Jun 2009 08:55:51
Message: <4a48b9d7$1@news.povray.org>
> different countries within a few seconds from my desk, try doing that
> with real printouts :-)
Sure. But you don't need Acrobat for that, just Acrobat Reader. We paid
a shedload of money for the full Acrobat Professional package on the
expectation that it would allow us to, you know, *modify* PDF files. :-P
>> I can manipulate then with IrfanView. On the other hand, it means
>> they'll either be vastly lower resolution than the original vector
>> graphics, or they'll be absolutely huge files...
> quite common to work on A4 size at 600dpi on a normal PC these days...
Mmm, A4 at 600dpi. That's going to be a few megapixels...
In the end, I ended up just double-printing the damned thing. Which
meant I had to print it three times before I figured out the paper path,
scaled everything so the new headers don't overprint the document
content, and so on and so forth. All of which would have been *so* much
easier with some suitable software... but hey, Adobe has our money. Why
should they give a damn?
> you can just ask the original author for the original files to modify?
> That might be easier in the end.
Right. Because BackupExec *totally* has options for customising the
header and footer on the job logs it prints out. ;-)
Date: 29 Jun 2009 09:03:49
Message: <4a48bbb5$1@news.povray.org>
Just when you thought your day couldn't get any worse... it does.
I now have to phone a lady who doesn't speak propper English and make
her PC work. Oh, did I mention? She's in a different country...
Yay, me. :'{
Date: 29 Jun 2009 09:12:09
Message: <4a48bda9$1@news.povray.org>
> Yay, me. :'{
I'm almost glad the number doesn't work... :-P
Still, I don't suppose there's any way I can realistically get rid of
this person.
Date: 29 Jun 2009 09:12:13
Message: <4a48bdad@news.povray.org>
Of course.
> We paid a shedload of money for the full Acrobat Professional package on
> the expectation that it would allow us to, you know, *modify* PDF files.
> :-P
Did you read the "features" page of Acrobat Professional?
http://www.adobe.com/products/acrobatpro/features/
I make it 35MP, about 3x what consumer digital cameras are up to now,
shouldn't be a problem to edit a file this size.
> Right. Because BackupExec *totally* has options for customising the header
You mean it only gives you job logs in PDF format?  That's a bit pants.
Date: 29 Jun 2009 09:19:07
Message: <4a48bf4b$1@news.povray.org>
On my old wreck of a PC? It's not going to be much fun...
Actually they're XML files with a custom schema. My guess is that it's
using the Internet Explorer rendering engine to print them. Suffice it
to say, this is a backup program. It has a button marked "print", and
that's basically it. You have no control over formatting. I did,
however, manage get it into PDF format.
(Print to a PostScript printer, send to file instead of the printer, use
Ghostscript to convert PS to PDF. Yay, I have a working PDF file now.)
I stupidly assumed that since we have PDF editing software, it would be
easy to, you know, edit the PDF file.
