POV-Ray : Newsgroups : povray.off-topic : Video games Server Time
14 Sep 2025 02:21:02 EDT (-0400)
  Video games (Message 1 to 10 of 18)
Subject: Video games
Date: 26 Jun 2009 01:25:59
Message: <4a445be7@news.povray.org>
To anyone who has written a game...
Question: Did you enjoy playing it yourself? Games I wrote, I knew too much
about to enjoy playing them myself, other than testing they were right.
Indeed, sometimes the more I knew about a game, the less fun it was. (Like,
once I learned the production rules in detail for M.U.L.E., it was less
exciting.)
Premise: Infinite spawning of enemies on a level leads to less replayability
in a complex shooter game with lots of ways to win. This is because the
player cannot set arbitrary goals such as "clear the level using nothing but
the wrench/crowbar/whatever".   How fun would Thief be if the loot spawned
randomly when you weren't in the room?
Minor curiosity: Bioshock - is it qualitatively different on different
difficult levels, like Thief is, or is it just a rebalancing of hit-points
and damage levels?
   Insanity is a small city on the western
   border of the State of Mind.
Subject: Re: Video games
Date: 26 Jun 2009 06:23:42
Message: <4a44a1ae@news.povray.org>
> and damage levels?
  I think the vast majority of games with different difficulty settings use
just "fake difficulty", ie. some really cheap tricks such as giving the
enemies more HP and/or reducing the damage of your weapons (some games
simply spawn more enemies at higher difficulty levels, Doom being the most
obvious example), rather than going so far as adjusting the enemy AI.
  The most blatant fake difficulty I have seen is in Doom 3. (Or was it
in Quake 4? I always confuse the two because I have both and they are
so similar in so many ways. Well, it's not all that important.) In the
hardest difficulty level your health is always drained to half (or was
it even to one third?), even if you get it temporarily higher with health
packs. This feels like a really cheap trick.
  I suppose that the reason for this is rather simple: Adjusting the game AI
to consistently correspond to some kind of difficulty level is probably a
really hard problem, and the game developers have their hands full of work
already with everything else that needs to be done by the deadline and under
the given budget to worry about such irrelevant things.
  About the only game type where difficulty level directly correlates to AI
strength are board game programs, chess programs being the most prominent
example. (There might be other examples in some sports and strategy games.
I don't play many of those, so I really don't know.)
  Of course difficulty can sometimes be adjusted by other means, such as
in the Thief games: In harder difficulty levels you have to achieve more
(eg. collect more loot), and you are given rational limitations (eg. don't
kill anybody, which is a very logical limitation in a stealth-based game).
While these feel less like "cheating" from the part of the game designers,
it still doesn't mean it's not a cheap trick.
Date: 26 Jun 2009 07:10:44
Message: <4a44acb4$1@news.povray.org>
news:4a44a1ae@news.povray.org...
AI
under
AI
> example.
I might be wrong but all chess games I used to play used analogous fake
difficulty / cheap tricks too, in that instead of using a different,
"smarter" engine, they use the same engine but allowed it longer time to
calculate ahead (alternatively, they artifically limit the calculation
time/level for lower difficulty levels). Coding multiple chess engines for
different difficulty levels doesn't make any more economic sense than coding
multiple AI's in action games. Of course the parameters to tweak are
different in action games than in board games, but I don't think it's fair
to say that longer times (or more properly, more processor cycles) allocated
for a given task makes the AI stronger.
Date: 26 Jun 2009 07:50:49
Message: <4a44b619@news.povray.org>
  That's precisely fine-tuning the AI parameters to match the difficulty
level.
  There's not really such a thing as a "smart" engine. There's only number
crunching: Crunch more numbers and the program will be a stronger opponent.
Crunch less numbers and it will start making more mistakes and poorer moves
for the simple reason that it's not seeing far enough. Not completely unlike
human players: A beginner will see only one or maybe two moves forward, and
this for only a few pieces. A pro will see a dozen or more moves forward
(more for the relevant pieces, less for the irrelevant ones).
  There are a few chess engines out there which at easiest difficulty
levels will make deliberate mistakes. In other words, rather than blindly
choosing the best move it has seen so far, it deliberately at times chooses
a slightly worse one, just to lower the difficulty level. This is also
adjusting the AI (in a way that it sometimes ignores better moves as if it
had never even seen them).
  I never talked about multiple AIs. I talked about tuning the AI strength
according to the difficulty level.
Date: 26 Jun 2009 07:55:05
Message: <4a44b719@news.povray.org>
In most cases, yeah.
(It's kind of crazy playing Quake II on the highest difficulty level.
You run up to some fleshy cyborg on put 4 depleted uranium slugs into
him and he's not dead. WTF?)
I think the original HalfLife did this fairly well. On the lower
difficulty levels, the enemies tend to just run at you, while on higher
difficulty levels they seem to behave more tactically.
For example, the headcrabs. On Easy, they just wander towards you until
you're in jumping range. On Hard, they tend to scuttle into corners and
wait for you to walk past, and then ambush you.
Similarly, the marines on Easy just shoot at you a lot. On Hard, then
throw grenades, duck behind things, and try to run round and flank you.
(I must say, I didn't find anything "revolutionary" about the game AI -
one of the things that was highly touted. It was good, but not fantastic.)
Of course, even in HalfLife, they still used the main principle of
increasing the hitpoints of all the enemies, which is dull and annoying.
But at least where they add extra enemies, they put them in strategic
places. Indeed, walking round the level on Easy, you can tell where the
extra enemies are probably hiding. "Oh look, a useless corner that
doesn't go anywhere. I wander what *that* might be for?"
Having struggled to complete HalfLife 2: Episodes 1 and 2 on the very
lowest difficulty setting available, I'm not sure I want to know what
it's like on Hard. :-/
In particular, most of the hard things about HalfLife 2 and the two
episodes are overwhelming forces. It started with Ravenholm, an entire
level teaming with zombies and almost no ammo. Sure, killing zombies
with only a crowbar is pretty damned hard. But it's not exactly
"enjoyable" replaying the same 15 seconds of game hundreds of times over
until you manage to get past.
In short, a game that's too easy is boring, but so is a game that's too
hard, and Ravenholm was absurdly hard.
In HL2:EP1 we find Lowlife, a similar premise really. Except somebody
thought it would be funny to turn off all the lights. It's not big, it's
not clever, and it's not even remotely enjoyable. It's repetative and
tedious, actually.
And of course, HL2:EP1 rounds off with a battle with an almost
unkillable Strider. I mean, seriously. How many rocket hits does it
take?? What the hell is it MADE OF?!
This isn't a challenge, it's silly.
HL2:EP2 is somewhat similar with the two antlion guards. It's basically
a big soft squidgy thing which you never the less have to dump ludicrous
amounts of ammo onto before it will freakin' DIE. Several times I played
that section and actually ran completely out of ammo. As in, the only
thing I had left was the crowbar. I had to go run outside like a crazy
thing hoping there might be some ammo around somewhere...
Still, at least HL2:EP2 managed to be challenging in more interesting
ways. Right up until the battle for White Forest... *sigh*
Date: 26 Jun 2009 08:11:59
Message: <4a44bb0f@news.povray.org>
  The final battle of Episode 2 is HARD. Really HARD. Even when you get
the idea of what you have to do, it's still really hard.
  But it can be beaten.
Date: 26 Jun 2009 08:40:47
Message: <4a44c1cf$1@news.povray.org>
Oh, I beat it eventually. It took about 2 months though.
It wouldn't surprise me if they released a game update to turn down the
difficulty, and that's why I beat it. :-P
(I actually sent an email to Gab### [at] valvecom about it. Not that I
suppose Gabe actually reads those...)
The car is... uncontrollable. It accelerates very slowly, yet hitting a
twig or a pebble is sufficient to bring it to a complete halt. At top
speed, it handles exactly the same way as in first gear (i.e., it will
still make 90 degree turns without hesitation). In short, the physics
are completely fschk'd up. The stearing controls are of course almost
unusable
And then, we have hunters. They're wickedly manuverable, and every time
you meet one earlier in the game, you have to almost exhaust your entire
ammo supply to kill just ONE of them. But out here, you suddenly have
dozens of the running around, AND NO AMMO ANYWHERE. (Sure, a few of the
huts have tiny quantities of ammo. But once they've been blown to hell,
that won't help you too much.)
The number of times I've tried to ram a hunter with the car, only for it
to nimbly sidestep me at the last second is nobody's business. And then
of course the car hits a pebble and comes to a total halt, and it takes
10 minutes to execute a 2,000-point turn and get back on the move.
Assuming you're not dead by this point from the multiple hunters and
strikers attacking you.
On top of that, it's almost impossible to figure out where the hell the
enemy is. And on top of THAT, to kill a strider you've got to select the
gravity gun, pick up a bomb from somewhere, throw it, go through your
inventory, select the pistol, aim at the strider... oh, wait, too slow.
Sorry. Try again.
When I *finally* destroyed the last strider (which, by the way, was
inches from the base at this point), everybody started cheering. I was
so certain that there was going to be another wave... but, as it turns
out, there wasn't.
Similarly, as they launched the missible, I was certain that a bunch of
combine soldiers would suddenly jump out or something, or the G-Man pop
up and say "I'm s-ssorrry Dave, I c-can't llet you dooo that..."
But no, it' launched, and it seemed to work. (Again I was half-expecting
it to go wrong and teleport me and Alyx back to the Xen homeworld or
something weird.)
And then... well, you've all seen it, right? ;-)
Date: 26 Jun 2009 12:17:22
Message: <4a44f492@news.povray.org>
Hmmm. Well, I liked that you could not meet all of the goals in the hard
level of thief by playing on the easy level. There was loot you had to
collect on the hard levels that just weren't *there* in the easy level. The
door to the hall that led to the part of the castle with loot #3 was a blank
wall on difficulty #1 or #2. You literally couldn't play the easy mode and
see the whole level.
That doesn't seem like too much of a "cheap trick" to me. But then the AI
wasn't really what you'd call stunning.
Plus, of course, there were things like not needing to get back out again
once you got the loot, on the easy levels. And you had less health, and the
bad guys had better hearing, and so on, on the hard levels, as expected.
Date: 26 Jun 2009 12:19:03
Message: <4a44f4f7$1@news.povray.org>
Actually, I saw a research paper where they did focus group tests, and when
all they did is turn up the number of HP the computer opponents had, players
thought the AI was smarter, even tho it was exactly the same code shrugging
off more bullets.
Date: 26 Jun 2009 13:13:57
Message: <4a4501d5@news.povray.org>
Darren New escreveu:
I never did, but I guess being Sid Meier, Kojima, Miyamoto or Peter
Molyneaux would suck too much wasn't it for the vast amounts of money
they get.  I mean, not being able to enjoy such masterpieces because you
are too spoiled already??!
> replayability in a complex shooter game with lots of ways to win. This
> is because the player cannot set arbitrary goals such as "clear the
> level using nothing but the wrench/crowbar/whatever".   How fun would
> Thief be if the loot spawned randomly when you weren't in the room?
How about people who just enjoy mindless shooting carnage for the sake
of it rather than specific goals? :P
a game sig: http://tinyurl.com/d3rxz9
