POV-Ray : Newsgroups : povray.off-topic : Truly epic failure Server Time
22 Dec 2025 00:15:13 EST (-0500)
  Truly epic failure (Message 1 to 8 of 8)
Subject: Truly epic failure
Date: 23 Jun 2009 11:02:02
Message: <4a40ee6a@news.povray.org>
OK, so check this out...
I have a HP nx7300. I want to reload the OS. So I go to HP's website and
download all the drivers.
I ran the installer for the SATA driver, and it unpacks some files onto
a floppy disk. (It's one of these dealies that makes you actually put a
disk into the drive, and then writes it track by track.)
Guess what? An nx7300 doesn't *have* a disk drive! :-D
FAIL.
(Seriously... why the hell would HP issue a driver that you can't use?
That's just silly.)
Subject: Re: Truly epic failure
Date: 23 Jun 2009 11:15:42
Message: <4a40f19e@news.povray.org>
> FAIL.
Ah yes... but the Windows installer insists that all drivers must be
supplied on a disk inserted into drive A:
Even on a PC that doesn't possess one.
Fail^2.
Reading the documentation for the driver, it appears you have to build a
custom Windows CD with unattended setup instructions to insert the SATA
driver... *sigh* I have better things to do with my time.
Date: 23 Jun 2009 11:52:37
Message: <4a40fa45@news.povray.org>
No, an epic failure would be scrubbing the old OS and *then* finding out you
needed a floppy drive to reinstall.
   Insanity is a small city on the western
   border of the State of Mind.
Date: 23 Jun 2009 21:41:11
Message: <4a418437@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:4a40fa45@news.povray.org...
> you needed a floppy drive to reinstall.
POTW!!!
Cheers Dre
Date: 24 Jun 2009 09:25:18
Message: <4a42293e$1@news.povray.org>
> FAIL.
> That's just silly.)
I recently ran into that one and ran across
http://www.nliteos.com/
You can pre-install the driver into windows - then no floppy needed.
Tom
Date: 24 Jun 2009 09:36:55
Message: <4a422bf7$1@news.povray.org>
>> FAIL.
It seems they're just talking about building a customised Windows boot
disk that already contains the necessary driver files. (The driver
README tells you how to do this manually; copy some files, edit the
UNATTEND.TXT file, etc.) This still means I have to faf around with
burning a special CD just for this one laptop. (Assuming I can find a CD
burner somewhere...)
Date: 24 Jun 2009 09:44:31
Message: <4a422dbf@news.povray.org>
>>> FAIL.
Yes, you have to burn a special CD.
If you so choose you cal also preinstall SP3, IE, and a whole lot of
other things.
It is a pain, but after all, you are working with 'legacy' software that
MS can't bother to update when you install XP.
I suggested nlite because it can actually be simple - given that you can
find a burner.
Tom
Date: 26 Jun 2009 05:09:01
Message: <4a44902d$1@news.povray.org>
Invisible wrote:
> FAIL.
> That's just silly.)
Well, Acer went one better.
When you go to their website and select the model of laptop you have,
they give you THE WRONG DRIVERS. o_O
Select "Notebook". Select "TravelMate". Select "250"... oh, it isn't
there. Enable "Show all models". Now it's there. Select it, and there
are all the drivers.
Wait. The TravelMate 250 doesn't have an ATI graphics card. It's Intel. WTF?
Turns out you have to do something silly like select the TravelMate 270
to get the right graphics driver. And then select the TravelMate 240 to
get the correct LAN driver. And then select some other model to get the
correct audio driver.
In other words, the catalogue of which driver belongs to which laptop is
basically screwed. Thanks Acer, that's really helpful.
Now I'm nerdy enough to know what I'm doing, but I wonder how many poor
clueless n00bs are completely baffled by the fact that the driver
they're given BLATENTLY DOESN'T WORK...
Also, I was stupid enough to try to make the wireless card work. BIG
MISTAKE! You see, while Windows Update was able to install the correct
wireless driver, it can't detect any networks. "Make sure your wireless
card is turned on" it says. So I press the wireless button on the laptop.
And nothing happens.
In particular, the button doesn't light up. So it looks worryingly like
this is controlled in software rather than hardware as it should be.
Which means I need to somehow figure out which friggin' driver controls
it, and which model its misclassified under on the Acer website...
Or I could just plug in an Ethernet cable. :-P
