![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: I haven't read the entire paper yet, but the analogies are rather apt
Date: 9 Dec 2010 13:04:00
Message: <4d011a10$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
http://www.maa.org/devlin/LockhartsLament.pdf
~Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: I haven't read the entire paper yet, but the analogies are rather apt
Date: 9 Dec 2010 14:50:14
Message: <4d0132f5@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That reminds me vividly of something which I have noticed and realized
all by myself: I have never seen *anywhere* the *logical* explanation of
how you can easily calculate, for example, the sum of all the integers
from 1 to 100. It's *always* just the raw and sterile formula, and that's
it. No explanation, no intuitive nor logical way of deducing it. Just the
formula and that's it.
The raw formula is rather useless by itself when you don't understand
where it's coming from. If you change the problem slightly, for example
to "sum of all integers from 1 to 200", most people will still be able
to *guess* how to change the formula to get the result (ie. you just
change the '100' to a '200'). However, change it eg. to "all the even
integers between 50 and 250" and most people are left completely baffled.
No idea whatsoever. Why? Because they don't understand where the formula
is coming from.
A more logical approach to actually deducing the formula is to think
that summing all the integers between 1 and 100 is the same as summing
the average of those numbers with itself as many times as there are
numbers in that range. (In other words, the product of the average and
the amount of numbers, ie. 100 in this case.) This can be intuitively
demonstrated graphically (if you visualize the integers as vertical
bars of the length of the integer, forming a triangle construct, you
can split this construct in half and mirror the upper half to get a
rectangle).
Knowing this makes it easy to deduce the answer to a whole lot of other
similar problems. For example "sum of all the even integers between 50
and 250" can be done with the same principle: The average of all those
numbers times their amount. (The average is, obviously, (50+250)/2, and
the amount of values is (250-50)/2 + 1.)
(Of course you need to be careful to not to apply this idea too far.
For example it cannot be applied to "sum of all squared numbers between
1 and 100". If you visualize it graphically like earlier, you'll see why.)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 9 Dec 2010 15:29:02
Message: <4d013c0e$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I can't say I've had the same experience. I've seen plenty of
explanations of that formula, probably more so than any equation other
than the Pythagorean theorem.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: I haven't read the entire paper yet, but the analogies are ratherapt
Date: 9 Dec 2010 16:06:16
Message: <4d0144c8@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 09.12.2010 21:29, schrieb Kevin Wampler:
Same here. Maybe I was lucky in having maths teachers who loved maths
just as much as I do; maybe it's the difference in educative system;
maybe it has changed over time.
In my case, our teacher did...
- show us how to deduce the formula for that sum;
- give us historical background of how the basic idea behind the formula
was discovered by later mathematician Carl Friedrich Gauss when he was a
kid, to the surprise of the teacher who had thought he had found a way
to keep his pupils busy; and
- use it as an introductory example for mathematical induction, which
they then trained us to apply to other problems (and by that I mean
types of problems, not just the same problem with different parameters).
So I think I did get a truly mathematical education. I might add that
this was German Gymnasium in the 80's. I'm pretty sure pupils at
Hauptschule weren't that lucky; maybe even today's Gymnasium pupils
aren't either, but I hope things haven't changed that dramatically.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 9 Dec 2010 16:35:12
Message: <4d014b90$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
FWIW, I learned virtually nothing in music class and nothing at all in art
class. Art class, such as it was, consisted of the teacher trying to come up
with rules about what you drew to ensure it occupied the entire 45-minute
class to draw it.
And while I took and understood a great deal of math, it wasn't until
physics class that I suddenly said "Oh, *that* is what an integral is for!"
Serving Suggestion:
"Don't serve this any more. It's awful."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 9 Dec 2010 16:37:20
Message: <4D014C10.7060202@gmail.com>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
mildly related http://www.cs.utexas.edu/users/EWD/ewd05xx/EWD538.PDF
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 9 Dec 2010 16:38:44
Message: <4D014C65.30402@gmail.com>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> art class. Art class, such as it was, consisted of the teacher trying to
> come up with rules about what you drew to ensure it occupied the entire
> 45-minute class to draw it.
or trigonometry after encountering POVray
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 9 Dec 2010 16:57:15
Message: <4d0150bb@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Geometry, trigonometry and in some cases even calculus has been quite
useful in graphical-heavy and game programming.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 9 Dec 2010 17:57:40
Message: <4d015ee4$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
But in a sense, that's because you're simulating physics. None of those
apply to programming a board game, for example.
Serving Suggestion:
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
tl;tr all yet.
but this:
someday."
seems to describe very well a serialist composer working on the sheet alone...
yes, perfect analogy to math education today.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
