POV-Ray : Newsgroups : povray.off-topic : Antique Server Time
15 May 2026 20:53:24 EDT (-0400)
  Antique (Message 1 to 10 of 40)
Subject: Antique
Date: 22 Apr 2009 05:07:19
Message: <49eede47@news.povray.org>
OK, so here's a question...
I have in front of my an S3 Trio3D/2X graphics card. What the hell kind
of slot does that plug into??
I assumed it was AGP, but when I put it up against the motherboard, the
key is in the wrong place.
So this card is neither PCI nor AGP, so... WHAT IS IT?? >_<
Subject: Re: Antique
Date: 22 Apr 2009 05:22:29
Message: <49eee1d5$1@news.povray.org>
AGP slots comes in several variants:
http://en.wikipedia.org/wiki/File:AGP_%26_AGP_Pro_Keying.svg
Tor Olav
http://subcube.com
Date: 22 Apr 2009 05:28:36
Message: <49eee344$1@news.povray.org>
I'm going to go out on a limb and hypothesize that I have a 3.3V card
and it won't fit in a 1.5V slot... From these diagrams, that appears to
be the case. (There's another key not shown, but the board has no
contacts on it, and the slot appears to be mechanical only.)
Either way, this doesn't help me... *sigh*
But hey, I won't let that dampen my mood. ;-)
Date: 22 Apr 2009 06:09:33
Message: <49eeecdd@news.povray.org>
Le 22.04.2009 11:28, Invisible nous fit lire :
The AGP kind is in the name of your card S3 Trio3D/*2X*, the card as a x2 AGP port.
Nowadays port (well, the latest before PCI-E) was AGP x4/x8
They are not compatible.
AGP x2 use 3.3V signaling. You need a motherboard with AGP x2... very old too.
your card might work with AGPx1 motherboard too.
The otherkey is just the fitting AGP-length connector, not all lines are used by your
card. It also avoid inserting in PCI slot (electrical damage expected).
Later, an additional key was made to lock the card in the slot, but it was not
mandatory
for the first AGP.
Another sad news expect you: the video connector... modern LCD have no more VGA
connector!
(and finding a good CRT is an impossible mission nowaday)
Last note for the card:
It's not even worth the postal stamp
http://www.priceminister.com/offer/buy/5367905/S3-Trio-3D-2X-4-Mo-AGP-2-x-Carte-graphique.html
Subject: Re: Unique Antique
Date: 22 Apr 2009 06:19:52
Message: <49eeef48$1@news.povray.org>
Actually, I have three of them. And you know what? They're all slightly
different...
If I compare any pair of boards, there is a difference. So it's not like
one board is different to the other two, they're ALL different!
- Boards B and C have two RAM chips on them. Board A has bays for two
chips, but only one is present. (All three boards are spec'd as "4 MB".)
- Board B has a different brand of RAM chip. (But *all* the boards have
different *models* of RAM chip.)
- Boards A and C have pins on the AGP connector which aren't connected
to anything. But on board B, those pins are physically missing rather
than just unconnected.
- Board B has less writing printed on it between the two RAM chips. The
actual components mounted there appear identical, but just fewer markings.
- Each board has some kind of 3-pin component with what looks like a
heat sink soldered to a very large metal pad on the board. Oddly, only
two of the three pins are connected to anything; the middle pin is cut
off at the base. On boards A and C, there are three metal pads on the
board that end in rounded tips, and the middle one appears to be a
continuation of the large pad the heat sink is soldered to. But on board
B, there is a gap between the pads the pins are soldered to and the
circles at the end, and there is no middle pad (but the circle is still
there).
- Some of the code numbers on both the S3 chip and the Holtek chip are
different on each board, while others are identical. (I'm guessing these
are serial numbers, or at least revision numbers.)
- Hello, I didn't notice this: Board B says "SP368G REV:2" on it, while
the other two boards say "SP368G REV:3" on them.
So there we are. *Clearly* I have too much free time...
Date: 22 Apr 2009 06:23:34
Message: <49eef026$1@news.povray.org>
Ah, is *that* what that means? I stupidly assumed it ment twice the 3D
power or something daft like that.
Heh. Well, these are old, old cards. I decided to keep them as spares,
but I guess there's pretty useless in that capacity now.
connector!
Ah, but they all seem to come with DVI-to-VGA converters. ;-)
How interesting... both of those photos look significantly different to
the product I have here.
Date: 22 Apr 2009 06:32:10
Message: <49eef22a$1@news.povray.org>
A photo would help.  If it's really old it might be ISA :-)
Date: 22 Apr 2009 06:37:07
Message: <49eef353$1@news.povray.org>
The Holtek chips say "HT27C512-70" followed by a number that's unique to
each chip. Apparently this part number is a "OTP CMOS 64K x 8-Bit EPROM".
http://pdf1.alldatasheet.com/datasheet-pdf/view/64437/HOLTEK/HT27C512.html
"The HT27C512 chip family is a low-power, 512K bit, +5V electrically
one-time programmable (OTP) read-only memories (EPROM)."
Um, wouldn't that make it a PROM rather than an EPROM? The E is for
*erasible*. :-P
...so I'm guessing this is the card's firmware then?
Date: 22 Apr 2009 06:38:51
Message: <49eef3bb$1@news.povray.org>
Wrong.
Board A has EliteMT, board B has ACTRAM, and board C has eFox.
Date: 22 Apr 2009 06:39:48
Message: <49eef3f4$1@news.povray.org>
LOL! No... ISA is much larger than this. It's the exact same physical
dimensions as the AGP slot on the motherboard, just with the key slot in
a different position.
