POV-Ray : Newsgroups : povray.off-topic : Weekly calibration Server Time
2 Jul 2026 15:19:24 EDT (-0400)
  Weekly calibration (Message 47 to 56 of 106)
Subject: Re: Weekly calibration
Date: 21 Apr 2009 04:49:03
Message: <49ed887f@news.povray.org>
scott <sco### [at] scottcom> wrote:
> >  So exactly at which point are the works forced to appear, to fulfill
> > the probability of 1?
> In the limit of N --> infinity.
  That's, in fact, the exact same thing as saying "never".
  And that's how it is: Each *individual* round of popping up values from
the RNG has a smaller-than-1 probability for the works to appear. Thus at
no point are the works *forced* to appear.
> >  The answer is: They are never forced to appear.
> ...unless N is allowed to be infinite, which the original problem states
> quite clearly.
  So at which point are the works forced to appear?
> Or do you also disagree with 0.99999... with infinitely many 9's equals 1?
  Do you disagree that a probability of zero does not mean that the event
will never happen?
Date: 21 Apr 2009 04:58:58
Message: <49ed8ad2$1@news.povray.org>
http://everything2.com/title/If%2520you%2520have%2520enough%2520monkeys%2520banging%2520randomly%2520on%2520typewriters%252C%2520they%2520will%2520eventually%2520type%2520the%2520works%2520of%2520William%2520Shakespeare
http://everything2.com/title/Monkey%2520Shakespeare%2520Simulator mentions a
site that I'd come across a while back that simulated this, but it's since
vanished.
Tim Cook
http://empyrean.freesitespace.net
Date: 21 Apr 2009 05:25:43
Message: <49ed9117@news.povray.org>
Ermm, no, it's saying that the probability will get as close to 1 as you
want, and in the limit it will *equal* 1.  Exactly the same as saying
0.999999... can get as close to 1 as you want, and in the limit is actually
*equal* to 1.
For a finite number of tries, no.
>> 1?
No go on, please answer this one, because it's the same thing.  At which
point does 9/10 + 9/100 + 9/1000 suddenly equal 1?  Answer: when you extend
the series to infinity.
> will never happen?
A probability of zero means an event does not happen by definition, however
if you try an infinite number of times it might not necessarily never
happen.
A good example has already been mentioned, of choosing an exact number
between 0 and 1.  The probability is zero for any specific number, but if
you sum up the infinite number of probabilities between say 0.2 and 0.3, you
will get a non-zero probability.
Date: 21 Apr 2009 05:35:03
Message: <49ed9347@news.povray.org>
> >> 1?
  I really can't understand why you are so fixated with that question.
I never doubted or denied its veracity. My reply clearly implied that it
is indeed so.
> > will never happen?
> happen.
  You don't have to try an infinite number of times to get a value from
a continuous range. You only have to try once. And the value you get had
a probability of zero of being chosen. Yet it was chosen.
  You are not choosing a range of values. You are choosing *one* value at
random.
Date: 21 Apr 2009 06:21:55
Message: <49ed9e43@news.povray.org>
> is indeed so.
So you would also agree then that 1/2 + 1/4 + 1/8 + ... equals 1 with
infinitely many terms?  You see where this is going?
You are trying to equate the probabilities of 1/infinity with 0/infinity,
they cannot always be treated as the same (in some situations they can be).
Imagine choosing numbers between 0 and 1.  Getting exactly 0.5 (or any other
number between 0 and 1) has a probability of 1/infinity, getting exactly 1.5
has a probability of 0/infinity.  "Normally" they would be the same, but if
you say something like "what is the probability of getting *any* value
between 0 and 1" or "what is the probability of getting exactly 0.5 after
infinitely many tries" then they are not the same.
Date: 21 Apr 2009 06:42:52
Message: <49eda32c@news.povray.org>
> > is indeed so.
  I agree with it, and no, I don't see your point.
  I honestly don't understand.
Date: 21 Apr 2009 06:57:23
Message: <49eda693@news.povray.org>
That the sequence is also the probability of a head being tossed after N
tries of throwing a coin.  After 1 try it's 1/2, after 2 tries it's 1/2 +
1/4, etc.  So after infinitely many tries the probability is *equal* to 1.
Now simply replace "head being tossed" with "this sequence of characters
being the works".
If you are choosing numbers in the range 0...1, 0.5 has an infinitesimally
small probability of being chosen, 1.5 has a zero probability of being
chosen, they are not the same probability.  (In some situations you can call
the probability of 0.5 being chosen "zero", but you must remember that the
zero came from 1/infinity and not "real" zero incase you use it in later
calculations).
Date: 21 Apr 2009 07:22:23
Message: <49edac6f$1@news.povray.org>
The Internet has already proven that a multitude of monkeys would not
duplicate the works of Shakespeare, regardless of the amount of time
allowed.
John
Date: 21 Apr 2009 07:45:24
Message: <49edb1d4@news.povray.org>
> being the works".
  You talk as if I had said somewhere that in the infinite case the
probability does *not* equal 1. I don't remember saying such a thing.
> calculations).
  Now it's you who sounds like saying that 1/2+1/4+... does not equal 1.
Date: 21 Apr 2009 08:06:20
Message: <49edb6bc$1@news.povray.org>
>> being the works".
Never is a probability of exactly 0, yet you've just agreed that the
probability is actually exactly 1.  Make your mind up :-)
