POV-Ray : Newsgroups : povray.off-topic : A tricky rendering problem Server Time
14 Oct 2024 19:19:09 EDT (-0400)
  A tricky rendering problem (Message 1 to 10 of 23)
Subject: A tricky rendering problem
Date: 8 Apr 2009 05:48:12
Message: <49dc72dc$1@news.povray.org>
I wrote a program that takes a connection list such as
     (1, n [b 2, b 3, b 4]),
     (2, n []),
     (3, n [b 5, b 6, b 7]),
     (4, n []),
     (5, n []),
     (6, n []),
     (7, n [b 8, b 9, a 1]),
     (8, n []),
     (9, n [])
and generates an image such as the one attached.
Trouble is... it's not a very good graphic, is it? :-/
Download 'test3.png' (10 KB)
Preview of image 'test3.png'
Subject: Re: A tricky rendering problem
Date: 8 Apr 2009 07:19:02
Message: <49dc8826$1@news.povray.org>
You might take a look at GraphViz if you haven't done so already:
http://www.graphviz.org/
I bet you'd find in their papers plenty of ideas to make a better
rendering... Assuming you want to do it by yourself and not just use
existing tools.
Vincent
Date: 8 Apr 2009 07:53:59
Message: <49dc9057@news.povray.org>
> existing tools.
I did take a look at the "dot" tool - but it tends to produce utterly
horrid graphs. I mean, *astonishingly* bad graphs.
So I set about attempting to write my own. But, while it does strictly
speaking _work_, it leaves a lot to be desired. (A particular problem is
overlapping lines.)
The trouble is, I want to draw some graphs. Building a graph drawing
engine is only a secondary goal; the major goal is building the program
that produces the graphs in the first place. So I'm trying to do it
quickly... but I want it to look reasonable. Hmm.
Date: 8 Apr 2009 08:09:05
Message: <49dc93e1@news.povray.org>
Perhaps it would be wise, before writing such statements, to ensure that
your own tool reaches at least an equivalent quality ;-)
Vincent
Date: 8 Apr 2009 08:13:33
Message: <49dc94ed@news.povray.org>
Well, thus far my tool has succeeded in not putting nodes on top of each
other, and so their labels are at least readable. That's an improvement,
if only a small one.
Date: 8 Apr 2009 10:47:22
Message: <49dcb8fa$1@news.povray.org>
>> that your own tool reaches at least an equivalent quality ;-)
Except I have no such problem with dot...
Example:
digraph "" {
node [shape=ellipse, color=lightblue, style=filled, fontname="Times-Bold"]
p1 [label="1"];
p2 [label="2"];
p3 [label="3"];
p4 [label="4"];
p5 [label="5"];
p6 [label="6"];
p7 [label="7"];
p8 [label="8"];
p9 [label="9"];
edge [color=black]
p1 -> p2
p1 -> p3
p1 -> p4
p3 -> p5
p3 -> p6
p3 -> p7
p7 -> p8
p7 -> p9
edge [color=red]
p7 -> p1
gives the image attached. Probably not the most terse way since I
adapted it from a computer-generated dot file.
What's wrong?
Vincent
Download 'example.png' (4 KB)
Preview of image 'example.png'
Date: 8 Apr 2009 10:57:08
Message: <49dcbb44$1@news.povray.org>
>> each other, and so their labels are at least readable. That's an
>> improvement, if only a small one.
> Example:
> digraph "" {
> p1 [label="1"];
> p2 [label="2"];
> p3 [label="3"];
> p4 [label="4"];
> p5 [label="5"];
> p6 [label="6"];
> p7 [label="7"];
> p8 [label="8"];
> p9 [label="9"];
> edge [color=black]
> p1 -> p2
> p1 -> p3
> p1 -> p4
> p3 -> p5
> p3 -> p6
> p3 -> p7
> p7 -> p8
> p7 -> p9
> edge [color=red]
> p7 -> p1
> What's wrong?
That's interesting. I never managed to get a result to look that nice.
(Although a little AA certainly wouldn't hurt!)
What happens if you try it with this?
digraph ""
   n1 [label="fib"]
   n2 [label="(:)"]
   n3 [label="1"]
   n4 [label="(:)"]
   n5 [label="1"]
   n6 [label="zipWith"]
   n7 [label="(+)"]
   n8 [label="tail"]
   n1 -> n2
   n2 -> n3
   n2 -> n4
   n4 -> n5
   n4 -> n6
   n6 -> n7
   n6 -> n2
   n6 -> n8
   n8 -> n2
I eventually managed to get this to look half reasonable with my own
tool, but still not great.
Date: 8 Apr 2009 11:18:09
Message: <49dcc031@news.povray.org>
Yes, thankfully dot can output vector graphics so that's easy to settle.
Actually maybe the antialiasing in newer versions is better with the
direct png export...
This (antialiased by converting from ps to png with ImageMagick).
Vincent
Download 'example.png' (5 KB)
Date: 8 Apr 2009 11:27:18
Message: <49dcc256$1@news.povray.org>
OK, that settles that then.
OK, well that's pretty smooth looking. Certainly neater than what my
program produced.
The only thing I can think of is that maybe last time I tried dot out
while I was trying to do really complex mind maps and the vast number of
nodes and dense interconnections upset the layout algorithm. Certainly
your examples seem to be laid out just fine.
One small issue is that for the graphs I'm interested in, the ordering
of the edges is significant. That is,
   n25 -> n82
   n25 -> n133
means something different to
   n25 -> n133
   n25 -> n82
But dot will of course render them identically. I'm wondering if there's
a way to work round that. Maybe add some smaller nodes to label the
edges? (Presumably you can do that?)
Date: 8 Apr 2009 11:49:44
Message: <49DCC79A.6000906@hotmail.com>
>     (2, n []),
>     (4, n []),
>     (5, n []),
>     (6, n []),
>     (8, n []),
>     (9, n [])
My first suggestion would be to use a metapost or latex package. Not
sure if that is an option.
