POV-Ray : Newsgroups : povray.off-topic : A tricky rendering problem Server Time
12 Sep 2025 22:05:14 EDT (-0400)
  A tricky rendering problem (Message 11 to 20 of 23)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: A tricky rendering problem
Date: 8 Apr 2009 11:51:09
Message: <49dcc7ed$1@news.povray.org>
Invisible a écrit :
> One small issue is that for the graphs I'm interested in, the ordering
> of the edges is significant. That is,
>   n25 -> n82
>   n25 -> n133
> means something different to
>   n25 -> n133
>   n25 -> n82
> But dot will of course render them identically. I'm wondering if there's
> a way to work round that. Maybe add some smaller nodes to label the
> edges? (Presumably you can do that?)
Oh, you can even add labels to the edges directly withput having to add
a node :-)
If edge order is important apparently adding ordering=out at the graph
level will draw the outgoing edges of each node in the order they are
encountered. Of course this will possibly create more edge
interesections than necessary...
Anyway, I'm not saying that GraphViz can do absolutely anything you
might need. But you should look into it deeper than just "it broke down
the day I fed it an enormous graph with all the options at their default
value" :-D And the documentation seems good enough...
I wonder what your own tool would do with the graphs you tested dot on
originally, by the way ;-)
Vincent
Date: 8 Apr 2009 11:59:06
Message: <49dcc9ca$1@news.povray.org>
> a node :-)
That's interesting. I'll have to take a look at that.
Break horrifyingly. My new tool is designed speicifically for the one
particular graphing problem I'm trying to solve today. I've got it to
work modestly well so far...
Download 'length8.g.png' (3 KB)
Preview of image 'length8.g.png'
Date: 8 Apr 2009 11:59:38
Message: <49dcc9ea$1@news.povray.org>
LOL! Attached the wrong damn imaged...
Download 'index1.g.png' (10 KB)
Preview of image 'index1.g.png'
Date: 8 Apr 2009 16:07:46
Message: <49dd0412@news.povray.org>
>> add a node :-)
This is the best I've managed to come up with so far using dot. It's
still not perfect, but it's just about readable.
http://blog.orphi.me.uk/
Download 'fibs3.png' (21 KB)
Preview of image 'fibs3.png'
Date: 8 Apr 2009 16:28:41
Message: <49dd08f9@news.povray.org>
Invisible wrote:
> OK, well that's pretty smooth looking. Certainly neater than what my
> program produced.
> The only thing I can think of is that maybe last time I tried dot out
> while I was trying to do really complex mind maps and the vast number of
> nodes and dense interconnections upset the layout algorithm. Certainly
> your examples seem to be laid out just fine.
Case in point: see attachment.
It appears that the problem is that neato produces ridiculously bad
layouts. The dot program seems to actually do quite well, generally.
Download 'haskell1.jpg' (110 KB)
Preview of image 'haskell1.jpg'
Date: 8 Apr 2009 16:42:36
Message: <49dd0c3c$1@news.povray.org>
> You might take a look at GraphViz if you haven't done so already:
> http://www.graphviz.org/
> I bet you'd find in their papers plenty of ideas to make a better
> rendering... Assuming you want to do it by yourself and not just use
> existing tools.
I'm currently looking through
http://www.graphviz.org/Documentation/TSE93.pdf
which describes the layout algorithm for dot.
Amusingly, many of the algorithmic steps appear to be identical to what
I came up with myself. Specifically, cycles in the graph are broken
internally, nodes are arranged into "ranks" (rows), and then the
positioning algorithm decides where to put them. All of this is
*identical* to my own program. What I don't have is a special
algorithmic stage to rearrange the nodes (since I explicitly don't
*want* their horizontal positioning rearranged for these particular
graphs), and a stage for properly routine the edges (which is why they
keep intersecting things).
It's... encouraging to know that I accidentally managed to get so much
nearly right.
Date: 8 Apr 2009 21:50:01
Message: <web.49dd53e5c22165a3bbbb20030@news.povray.org>
[snip]
> nearly right.
Well, algorithmic ideas for many problems are almost always intuitive and
straightforward enough and only implementations differ.
The real question is:  is it in Haskell? :)
Date: 9 Apr 2009 04:17:11
Message: <49ddaf07$1@news.povray.org>
>> nearly right.
I don't know about that.
You have a tree of nodes. You need to place them so they don't overlap.
How do you do that?
It wasn't at all obvious to me how to do that. In fact, my layout
algorithm takes each subtree and draws an invisible box around it, large
enough to contain the entire subtree. This results in many nodes being
shoved too far left or right - much further than actually necessary.
There's probably a way around that, but I haven't found it yet.
Well *duh*! :-P
Date: 9 Apr 2009 09:26:14
Message: <49ddf776@news.povray.org>
> I came up with myself. What I don't have is a special
> graphs), and a stage for properly routing the edges (which is why they
Mmm, how ingenious. They add extra "invisible" nodes to each row that an
edge passes through, and then jiggle the invisible nodes around as a
means for deciding how to route the edge.
Of course, they then apply a complex algorithm to decide exactly how to
produce the best possible spline path through the general area reserved.
I doubt I'll go to that much trouble. But I could certainly use
invisible nodes to avoid unecessary intersections...
Date: 9 Apr 2009 09:42:20
Message: <49ddfb3c@news.povray.org>
OK, now *that* is interesting... I'm using a newer version of GraphViz
at work, and the same input gives a radically different result:
Download 'fib1.png' (25 KB)
Preview of image 'fib1.png'
