POV-Ray : Newsgroups : povray.off-topic : This is the sort of brokenness... Server Time
23 Mar 2026 11:13:21 EDT (-0400)
  This is the sort of brokenness... (Message 91 to 100 of 164)
Subject: Re: This is the sort of brokenness...
Date: 19 Mar 2009 15:59:47
Message: <49c2a432@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> >   Could you give a concrete example of a compiler, of any OO language,
> > which will only *warn* (rather than give an error message) if you try to
> > access a member variable specifically marked as private from the outside?
> Sure. C# or Java. You get this warning that says "this won't compile."
  Wait. The compiler gives a *warning* which says "this won't compile"?
If it's just a warning, and not an error, it means that it will compile
it anyways? Isn't that contradictory?
> Another example is, as I've been saying, C++. The compiler warns (and won't
> compile) if you access the private variable by name
  I get no warning if I try to access a private member. I get an error.
There's a big categorical difference.
>, but not if you
> intentionally or accidentally access the private variable by address.
  You can't access the private variable by address. Not according to the
standard. If you can, then that can be considered a non-standard compiler
extension.
  And trashing memory, triggering UB, is not the same thing as "accessing
a member variable". The effect may be the same as accessing in one compiler,
but might not be in another. You are not *really* accessing it. You are
just abusing compiler and system specific undefined behavior.
Date: 19 Mar 2009 16:01:19
Message: <49c2a48f$1@news.povray.org>
Warp wrote:
>   The question here is: Are compiler-enforced private member variables a
> good thing in programming or not?
>   Your argument why they are not: In C++ you can accidentally access them
> regardless of the compiler checks.
Actually, let me ask this. Since you seem to be saying that reflection means
that an OO system is a "kludge" because it breaks modularity, can you tell
me what language *you* think isn't a kludge in this respect? Since the
discussion mentioned "private:" and you defended the practice, I may have
wrongly assumed that indicated that you thought C++ wasn't a kludge OOPL in
this respect.
I don't know of any language that actually enforces modularity to the extent
where it's impossible to write code that depends on private variables of
another class, especially one to which you have the source. Every
language[1] where the trivial ways of doing this (e.g., reading the source
and using private names from outside the class) are enforced also has the
ability to bypass it without too much trouble (either by using reflection or
pointer arithmetic).
I don't know of any languages that make it trivially easy to *accidentally*
confuse private and public member variables, except *perhaps* PHP and Perl,
both of which I'll happily admit are kludges. :-) They might not make it
trivial, I don't remember, but if they do, I'm not surprised.
[1] except perhaps Ada - I'd have to go look closer to see if unchecked
conversions can do that sort of thing on tagged records.
   My fortune cookie said, "You will soon be
   unable to read this, even at arm's length."
Date: 19 Mar 2009 16:06:24
Message: <49c2a5c0@news.povray.org>
> Warp wrote:
> >   I still can't comprehend what's so bad in the compiler doing the check
> > that you don't access the private members.
> If it's actually enforced (as in an error rather than a warning), it makes
> lots of things harder than they need to be, because the running code winds
> up with less information than the compiler had. You're throwing away half
> the work the compiler did once you generate the code, so you wind up with
> lots of boilerplate to enter into code things the compiler already knows.
  That's the whole idea in modular thinking: You don't know what's inside
the module, and you *don't care*. You don't need to care.
  As soon as you start worrying what's inside the module, you are already
breaking module boundaries and abstraction.
> If it's half-enforced, as in the compiler complains and won't compile the
> code, but there's ways to get around it anyway (on purpose or by mistake),
> then it's IMO the worst of all possible worlds. You'll spend hours or days
> trying to debug code that's already right because the client is convinced
> the other code they've written is bugfree and it's easier to blame you than
> to find the wild pointer in their own code. The whole idea of class
> invariants goes out the window.
  No you'll explain to me how a naming convention of public variables helps
this problem.
> Incidentally, I see little wrong with breaking encapsulation if you maintain
> the invariants. It makes it harder to upgrade in the future without changing
> the client, but that's the price you pay for it. If you can automate the
> access to where it doesn't hurt to change the client, it seems like a
> win-win to me.
  IMO if anyone feels the need to break your interface and access private
members directly, then your class design sucks and should be redesigned.
  If your class design is good, nobody will need to access anything
directly.
Date: 19 Mar 2009 16:25:27
Message: <49c2aa37@news.povray.org>
> 1) They're enforced 100%. Nobody outside the class is capable of writing to
> or reading from a private variable. This provides maximum isolation at the
> expense of not having available at runtime lots of stuff the compiler knows
> at compile time that you might want to know (e.g., reflection type stuff).
  If you need to know the private members of the class from the outside,
then that class has been badly designed.
  With a well-designed class you don't *need* to know, nor care.
> 2) They're enforced 100%, but people outside the class can read but not
> write them. This is a little more fragile to change
  It breaks modularity badly. The whole idea of data hiding is that the
private part should be completely opaque to the outside. The second it
isn't, outside code will start making assumptions, and you can't change
the implementation of the class anymore.
> but still capable of
> being debugged in isolation, because other parts of the code can't break
> your invariants. Eiffel does this, but it's the same syntax (x.y) to
> reference the y member of x as it is to invoke the nullary member function y
> on x, so you don't need to do more than recompile the client code. (I think
> you can also say a variable is completely private, IIRC.)
  Some people argue that accessors to all private members, especially if
they are automatically generated, is almost as bad as having all the
members public. It exposes the internal implementation, and thus outside
code will start making assumptions about it, making it harder to change
the implementation later.
  Some accessors may be justifiable, but you should not go overboard.
> 3) They're enforced, but there are explicit mechanisms to bypass them, such
> as reflection. This is my personal preference, because it's easy to find the
> places in the code that might be breaking your invariants or might rely on
> your internal implementation, while providing the power of metadata. This is
> the C# and Java model.
  If you don't have access to the code which is making assumptions about
your class' internal structure, you can't change your class without breaking
that existing code.
  Sure, this situation might not be extremely common, but it can happen.
And it's something which might have been avoided with a good interface
design and a completely opaque private implementation.
> 4) They're enforced by the compiler but not by the runtime. This removes
> *both* the ability to debug your module in isolation *and* the ability to do
> metaprogramming that eliminates boilerplate by using the information the
> compiler has already calculated.
  Why would you want runtime checks if access rights could be fully checked
at compile time?
> 5) They're not enforced by the compiler or the runtime, but there are
> conventions and/or standards that make it obvious to everyone when you're
> breaking the data encapsulation, and the runtime ensures that you can only
> do this "on purpose". That is, the unenforced conventions (or enforced but
> bypassable mechanisms) ensure that the only way of breaking encapsulation is
> on purpose. This is almost as good as #3, except it may be harder to track
> down who is violating your invariants.
  Again, if you must keep "reverse compatibility", for a lack of a better
term (in other words, you as a library developer must maintain compatibility
with existing code which uses your library, and you don't have access to
this existing code nor can change it), it can be a problem if the existing
code can make assumptions about your library and does so.
> >   I think that your problem is that you have some kind of holy war against
> > C++, and every single discussion about programming is always somehow turned
> > to bashing C++.
> Nope. Someone brought up C++ by talking about the compiler enforcing
> "private:". I was just pointing out that the compiler only enforces it in
> some ways, and not in the ways that I thought was also important for modularity.
  You immediately assumed that it must be talking about C++, of course,
and immediately jumped at the opportunity of bashing it.
> >   I'm honestly getting tired of your C++ tirades. Every single subject
> > related to programming must somehow include C++ bashing, regardless of
> > the subject. That's getting tiresome.
> I'm really not trying to bash C++ here. If pointing out that C++ allows you
> to corrupt member variables with a bug is "bashing", then I guess I'm bashing.
  In a discussion about the modular programming paradigm and data hiding you
succeeded in creating an lengthy thread about how you can trash memory in C++.
It's not exactly like you avoided the subject.
> OK. I'm just trying to communicate here. That's why I'm asking the question.
> It seemed to me that you preferred a language with unsafe behavior and
> compiler-enforced checks to one with safe behavior and no compiler-enforced
> checks.
  That "you preferred a language with unsafe behavior" is 100% your own
invention. I have nowhere said that.
  What I have said is that I prefer enforced modularity over non-enforced
one (which IMO is not modularity at all). That "unsafe" bit is all your
own twisting.
> I've never heard you call C++ a kludge OO language. I assumed you were
> excluding C++ from that criticism when you said a language that allows
> access to private members is a kludge OO.
  At least you admit you are making assumptions.
Date: 19 Mar 2009 16:31:09
Message: <49c2ab8d@news.povray.org>
nemesis <nam### [at] gmailcom> wrote:
> You can see from this thread that while it began with CLOS, it ended in
> C++ because of its tons of private, protected, friend and other
> schizophrenic access mechanisms leading to complicated interfaces and
> behavior for modules.
  No. You just listed the excuses, not the real reason. The real reason
is that some people here really like to bash C++ at every possible
opportunity they can get. It's like a hobby to them. Or an obsession.
  I certainly didn't bring up C++. It's only after the bashing started
that I got dragged into the discussion about it.
Date: 19 Mar 2009 16:38:03
Message: <49c2ad2b@news.povray.org>
> >> I'm saying that C++ does not enforce that you don't change private instance
> >> variables from outside the class.
> >   And this has exactly what to do with whether (compiler-enforced) data
> > hiding is a good thing or not?
> Because there's two reasons for data hiding: (1) allow more flexibility in
> implementation, (2) allow easier debugging.
> If you can violate my encapsulation, I don't see the data as especially
> encapsulated, is all.
  You didn't answer my question.
  "Is enforced data hiding a good thing or a bad thing?"
  "In C++ you can bypass the encapsulation, so it's a bad thing."
  That doesn't make any sense. Exactly how is C++ related to the subject?
You are badly derailing.
  But of course. As long as you get to bash C++...
> >   Every single discussion about programming with you turns into C++ bashing,
> > no matter what the subject.
> I'm happy to bash any other unsafe OO language you might want to name. :-)
  It's getting really tiresome and old.
Date: 19 Mar 2009 16:50:32
Message: <49c2b017@news.povray.org>
  In fact I said that trying to emulate OOP in a language which has no
direct support for OOP is a kludge. The only thing I said about reflection
is that IMO it breaks modularity and thus you lose many of the benefits of
modular design.
Date: 19 Mar 2009 16:54:00
Message: <49c2b0e7@news.povray.org>
> Actually, I thought it ended in C++ because that's the only unsafe OOP
> language I know of.
  I can't understand if that means "I haven't studied unsafe OOP languages
other than C++" or "to my knowledge there are no other unsafe OOP languages".
> It's the only language I know where the compiler
> attempts to enforce modularity but in practice fails to do so, by declaring
> violation of modularity "undefined" or "compiler-specific" rather than
> catching all cases of broken modularity at compile time or runtime.
  Then you don't know much, do you.
> I was trying to figure out how well-documented modularity breaking is a
> "kludge" but poorly documented unsupported modularity breaking isn't.
  The connection between my usage of the word "kludge" and your usage
of the words "unsafe" and "reflection" is purely your invention.
Date: 19 Mar 2009 17:00:33
Message: <49c2b271$1@news.povray.org>
No. That's why I'm saying you have to look at it from a slightly different
perspective. It's a compiler error to access the private variable the *easy*
way, just like in C++. It's not a compiler error to access the private
variable in the *difficult* way. Hence, you are *warned* when accessing the
private variable that you have to go out of your way to do it a different
way.  The modularity isn't enforced at compile time.
To you. Not to me. There are compiler flags that change warnings to errors.
Does that mean they're not warnings any more?
>> , but not if you
> extension.
// So....
class xyz {
  int i;
} pdq;
memset(&pdq,23,sizeof(int));
// That's illegal C++ code?? I thought C++ is compatible with C?
// Surely the compiler has enough info there to refuse to compile
// it if it's illegal? Doesn't a class with no virtual members have
// to have the same memory layout as in C? How do you pass a struct
// to read(2) or write(2) if you can't take its address?
> a member variable".
I'm not saying I'm "trashing memory". I agree it's triggering UB, but that,
IMO, means C++'s encapsulation is as much of a "kludge" as CLOS's is. I
mean, if you're agreeing that C++'s OOP is a kludge also due to lack of
encapsulation, then sure, every OOP I know of is a kludge under those
definitions. They're just kludgey in different ways.
I'd rather have the kind where you have to intentionally violate
encapsulation in a way that is portable and makes it easy to see who is
doing it, than have the kind that a simple bug can violate encapsulation in
a module utterly unrelated to where the bug is.
And it's not about C++ vs other things, it's about safe vs unsafe languages.
The only reason I brought up C++ is it's the only language I know that
*doesn't* give you a well-defined way to work around the modularity in times
of need.
What OO language besides C++ do you think doesn't have a kludgey modularity
system? Any?
And using reflection isn't *really* accessing it? Or is it? (That's a
question of your opinion, not a rebuttal.)
As I said, I see what you're saying. I'm trying to generalize a bit more.
Unsafe languages don't provide encapsulation of modules, IMO. The best they
do is to prevent you from accessing private variables in a straightforward
easy to understand way, without preventing you from accessing them in a
contorted and non-portable way.   And since you're accessing the internals
of someone else's code anyway, you've already decided to take on the problem
of changing your access routines when the module changes, so the fact that
it isn't portable when you change compilers doesn't seem like that much of a
drawback to me, if the need arises.
It seems to be perfectly valid to use memcpy to copy the contents of an
Alpha class into an array of characters that's sizeof(Alpha) and then pull
out from that the values of any variables I need without violating the
standard. It's non-portable, because I need to change the access routines
when I change compilers, but ... I know that.
I wouldn't do that sort of thing if I had a choice. Certainly I wouldn't
publish source code that intentionally takes advantage of this sort of
undefined behavior. :-)  But then, I wouldn't publish source code that
depends on the internals of someone else's CLOS code either.
Maybe here's something we can both agree on: Violating modularity can be a
kludge. That doesn't mean that mechanisms to allow that give you a kludgey
language. I'll grant that a language that makes it hard to know you're
violating encapsulation is a kludgey language in that respect. I'll grant
that any program that accesses private C++ variables or private CLOS
variables from outside their class is a kludge. I think we'll have to agree
to disagree on whether the mechanisms that *allow* such access (such as
reflection) are inherently kludges.
IMO, it also doesn't mean that every violation of modularity is a kludge. If
your violation of modularity doesn't violate the class invariant and it
automatically adjusts to new releases of the class you're violating without
further programming, I don't consider that a kludge. (Otherwise, for
example, debuggers would be "kludges" by definition, and I don't think
that's a reasonable assessment.)
Date: 19 Mar 2009 17:23:43
Message: <49c2b7df$1@news.povray.org>
It also prevents code from *inside* the module from doing certain things in
an easy way.
Not if you're doing it from inside the module.
> this problem.
The naming convention doesn't help that. The safety of the language helps
that. In other words, what helps it is not the naming convention, but the
fact that code that accesses private variables *must* use the naming
convention to do so.
Then you can take the Python code you're running, and look for the string
"._framenumber". If you don't find that, nobody outside your class is
changing the framenumber, even by accident. (Simplified of course, but
that's the idea.)
In the CLOS case, you can just look for the name of the private variable
that you suspect is getting changed from outside. Or you can change the
source code you have to consistently rename that private variable and run it
again and get a useful indication of exactly where in the outside code it's
violating your encapsulation.
In an unsafe language, I can have code that was compiled before I even wrote
my class accidentally violate my class's encapsulation, and it'll be almost
impossible to figure out what is going on if the program's big enough or if
I don't have the source to that code.
I'm just less worried about intentionally violating modularity than
accidentally doing so. When I do it on purpose, I know the cost/benefit
trade-offs. Doing so may be a kludge, but there's reasons kludges get
implemented in the commercial world.
(I've had server code written in unsafe languages where it would dump core
on a segfault, and the providers wanted to blame it on the fact that the Xen
kernel was on the machine. We weren't booting Xen, but they wouldn't even
look at their code until we uninstalled that kernel. Just as an example of
how people can avoid admitting their own bugs might be part of the problem.
Another time, the "calculation" part of the program did its work, clobbered
memory, wrote on the screen "now generating report", tried to create the
data file for the report generator, and crashed out in a way that locked up
the machine. As the author of the report generator, I got to spend several
*weeks* trying to figure out what it was before I discovered it was just the
calc routines not knowing their own calling structure and hence returning to
the wrong place on the stack at some point. This included printing out *all*
of the code I'd written, about a 5" stack, and going thru line by line
looking for bugs. (Found one, which wasn't the problem. :-) Another problem
that wouldn't have happened in a safe language.)
If you're in a particularly hostile environment, the best way is to have
well-defined class contracts in a safe environment that prevents the abusers
from bypassing those contracts. If you're not in a hostile environment, you
just get the author to agree to support revealing the private information
you need.
I agree.  That's why I say that CLOS allowing you to get to private members
from outside the class *if* you read the source code to the class and know
what they're called isn't, in practice, a problem.  The only time someone
would do that is if for some reason they can't *change* the source (because,
perhaps, they're expecting an update), but they can't get the author to make
an update that provides the interface that someone needs. At which point the
only choice is (1) toss the entire module (rewrite, buy different version,
etc), or (2) take on the burden of staying compatible with updates (which
may be infrequent enough that it's in practice not a problem). It's a
cost/benefit sort of thing.
> directly.
I also agree. Or, at least, nobody will access anything directly without the
author's "permission". If I say "it's OK to serialize this object, send it
over the wire, and reconstitute it in another address space", I'd still say
that's a good class design. If I'm worried about it getting stored for
longer than the lifetime of the declaration of the class (i.e., the "stored
in database" example), I'll write code to deal with it, or to convert the
old versions to new versions.
