POV-Ray : Newsgroups : povray.off-topic : This is the sort of brokenness... Server Time
31 Jul 2026 00:22:12 EDT (-0400)
  This is the sort of brokenness... (Message 15 to 24 of 164)
Subject: Re: This is the sort of brokenness...
Date: 18 Mar 2009 03:51:05
Message: <49c0a7e9@news.povray.org>
nemesis <nam### [at] gmailcom> wrote:
> More than that, Common Lisp has CLOS:
> http://en.wikipedia.org/wiki/Common_Lisp_Object_System
"Like the OO systems in most dynamic languages, CLOS does not enforce
encapsulation. Any data member (or slot) can be accessed using the
slot-value function or via (optionally auto-generated) accessor
methods."
  Your definition of object-oriented programming may vary, but in my view
data hiding, ie. modularity, is an integral part of OO programming. If the
internal structure of the object is exposed to the outside, you lose most
of the benefits of modularity.
  I think that the typical impossibility or difficulty in data hiding in
languages which do not have specific support for modularity is a sign that
the "OOP" is, after all, just a kludge.
Date: 18 Mar 2009 12:44:25
Message: <49c124e9$1@news.povray.org>
It's pretty easy to fix in LISP if you really care - just make all your
local names gensyms.  (If we're still talking about minimal support for lots
of paradigms, you could do this with some pretty simple macros, methinks.)
CLOS doesn't do this, because people who use LISP are usually pretty good
programmers.
> If the
Like, in unsafe languages, where a stray pointer can change private
variables without going thru the class methods? :-)
By this factor, I know of almost no actual OO languages besides Smalltalk
and Ada. (And Ada has OO features without being what I'd call an OO
language.) And I'm not sure you can't cast pointers inappropriately in Ada,
either. I'll look it up some day when I'm bored. :-)
C# and Java both have reflection that let you get to private members from
outside. C++ not only lets you return pointers to private members (which
isn't particularly bad in *my* opinion, see below, but you might disagree)
but also allows unsafe (in the technical sense[2]) access to private members
via undefined operations. It's pretty trivial to bypass all the modularity
in C++ since you need to be able to see the class declarations of the
private parts in order to access the class[1]. Python has the __dict__
element (et al) even if you had private variables.  Pretty much anything
designed so you can serialize it has external access to private members.
Now, ya see, I see the point of modularity is to let me reason about the
code. If I have a private integer X, and the only things I set it to are 0,
1, or 2, then I should be able to have a switch with those three cases and
never miss one. Or, for a better example, if I have a buffer, and my class
is the only thing that writes to the buffer, I can ensure I never have a
buffer overflow. This isn't the case in C++ any more than it is in LISP or
Python. The only difference is, in LISP it's much harder to break by
accident.  I don't see the advantage of making variables private if the
privacy isn't enforced well enough to give me more guarantees about the
program's execution. It's like having type declarations that aren't checked
at compile time or runtime - what's the point?
It would seem to be no harder to track down a bug caused by someone
accessing a private variable in a LISP object inappropriately than it would
be to track down someone overflowing a public array and clobbering a private
member in C++, especially since in LISP you'd actually have the name of the
private member somewhere in the source code module causing the trouble.
What do *you* think modularity is good for, that simply saying "stuff that
starts with an underline is private to the class" isn't adequate? I'm
seriously asking, because I'm wondering if I'm missing something.
[1] For example, you could declare an identical class with a different name,
except with all the privates public, then cast a pointer to the private
class into a pointer to the public class. Don't even need to depend on
compiler-specific knowledge about element layout and such. Or just declare a
child class that is happy to change any of its private variables.
[2] "Unsafe" means there are features with undefined behavior which may
affect the future state of the program, such that you can put values of the
wrong type into variables. That is, you can put values that don't belong to
the type into a variable of that type, or access values inappropriately
(such as accessing private variables from outside the scope you're supposed
to access them from).
   My fortune cookie said, "You will soon be
   unable to read this, even at arm's length."
Date: 18 Mar 2009 13:16:34
Message: <49c12c72@news.povray.org>
Darren New escreveu:
> lots of paradigms, you could do this with some pretty simple macros,
> methinks.)
> good programmers.
Yes.  Straight-jackets are generally viewed as a limiting "feature" by
people who actually know how to program rather than being a low-paid
drone.  What really amazes me is when very smart programmers actually
enjoy being in the jacket and ask for more. :P
The best I've ever read on the subject comes from Larry Wall:
"The trend over the last 25 years or so has been to design computer
languages that enforce a state of paranoia.  You're expected to program
every module as if it were in a state of siege.  Certainly there are
some feudal cultures where this is appropriate, but not all cultures are
like this.  In Perl culture, for instance, you're expected to stay out
of someone's home because you weren't invited in, not because there are
bars on the windows."
http://books.google.com.br/books?id=oh8lz4A3sUsC&pg=PA289&lpg=PA289&dq=larry+wall+house+invited&source=bl&ots=NcO4joArZd&sig=SaR-z_PriPfBbQaxNRAHpBfD_gc&hl=pt-BR&ei=dynBSYutLNuvtwfE0MXSCg&sa=X&oi=book_result&resnum=3&ct=result
Of course, such attitude would not stand the barbarism going on in
enterprise by thousands of code monkeys typing a bad rerun of
Shakespeare, but for one guy or 2 in the know alone working on a private
project, giving up all bureacratic measures for you not to shoot your
own foot may lead to an increased productivity with no sensible bug issues.
Date: 18 Mar 2009 13:30:28
Message: <49c12fb4$1@news.povray.org>
I think by the time you get people so disconnected from each other that you
have to literally defend your code against them, you also have a
sufficiently big management structure that you can afford code reviews and
things like that. And if someone *does* need to bypass your API and access
the private variables, chances are you can either (1) get them to change the
implementation of the public API, or (2) if the author is (say) in another
company, it's a good thing you can bypass the lack of ability to do what you
need. :-)
Date: 18 Mar 2009 13:35:24
Message: <49c130dc@news.povray.org>
> methods."
BTW, this is only true in CLOS. If you actually implement OO using closures,
this isn't the case.
As a sort of C++ equivalent, consider C++'s upcoming lambda expressions. If
you write something like
{ int x, y;
   x = 3; y = 4;
   std::function pdq = [x,y](z) {return x+y+z;}
   x = 8; y = 9;
   // What here could you write to get the "4" that's in y inside pdq?
(Assuming I'm close on the syntax, and I think I'm saying pass x and y by
value to the pdq lambda thingie.)
Building OO via closures is like that, except the x and y serve the purpose
of instance variables. (C++ doesn't have actual closures, so the analogy is
flawed here, of course, but if you don't see how closures can make objects,
that should clarify it.)
If you could pass x and y by reference, declared several std::functions that
used them by reference, and then return collection of those functions
without actually losing the stack frame those referneces referred to, you'd
have objects-on-closures, with no access to internal instance variables.
Date: 18 Mar 2009 13:43:54
Message: <op.uqz0vkjo7bxctx@e6600>
> name, except with all the privates public, then cast a pointer to the
> private class into a pointer to the public class. Don't even need to
> depend on compiler-specific knowledge about element layout and such. Or
> just declare a child class that is happy to change any of its private
> variables.
Except that the compiler is not required to generate the same layout in
those two cases, so you would still depend on compiler-specific knowledge.
FE
Date: 18 Mar 2009 15:28:02
Message: <49c14b41@news.povray.org>
> programmers.
  No. Crappy programmers (self-taught "hackers") want everything exposed and
can't understand the reasoning behind data hiding. Good programmers understand
this reasoning and for that reason use data hiding and abstraction.
> > If the
  No. The reasoning behind data hiding in modular thinking is completely
independent of the language used. It has to do with program design.
  If you expose the internal structure of a module to the outside, then
there's a big chance that outside will start making *assumptions* about
this internal structure. As an example, a module describing the concept
of a "color" might have four integral variables as members, one for each
color component. If this fact is exposed to the outside, then there's a
big chance that some code somewhere will assume that the "color" module
has four integral member variables with certain names.
  If this happens, then you can't change the internal implementation of
this module without breaking existing code. For example, if you wanted
to change the color components to floats, or you would want to pack the
color components into one single integral value, you will most probably
break existing code (especially probable in the latter case, as the
amount and names of the member variables will change drastically).
  If you can design the absolutely perfect module which will never change
its contents and will suffice for years to come, then by all means make
all members public. Us mortals will try smarter techniques.
> outside.
  Thus it's one reason why the design of these languages is badly broken.
  Only if the class itself explicitly does so. You can't get to the private
members *from the outside*. (Well, at least not without some serious
hacking.)
  It's usually considered bad design in C++ to return pointers to members.
  I don't understand what you are saying. If a class in C++ does not expose
a member array, then you can't get to that member array from the outside,
and if the class' own functions are properly designed, no buffer overflow
is possible (precisely because you *can't* access the array from the
outside).
  You might be able to control your *own* code from not misusing public
variables (and you might never make mistakes), but it's more difficult to
control someone else.
  If you need to tell someone else "don't access member variables whose
name start with an underscore", that's just plain stupid. You should be
able to tell that by making the *compiler* enforce it.
Date: 18 Mar 2009 15:33:07
Message: <49c14c73$1@news.povray.org>
I'm sorry, but that simply doesn't follow.  If the guy is stupid enough
to use things not in the interface I give him, it's his problem if he's
f*cked down the road.  But I agree with you:  dumb programmers like that
should wear a straight jacket, no doubt.
Date: 18 Mar 2009 15:33:53
Message: <49c14ca1@news.povray.org>
> drone.
  No, data hiding is seen as "limited" by self-taught hackers who don't
know jack s**t about programming. Those people just can't understand what's
the idea, and want everything to be accessible.
  I enjoy being able to create modules which I can safely improve later
without the fear of breaking existing code. And I'm talking from actual
experience, rather than theorethical handwaving.
  What a load of BS.
  Increased productivity... until the day that you actually need to heavily
change some module because of new requirements or improvements, and you end
up breaking thousands of lines of code which are carelessly using public
members as they please.
  Of course rather than admit their design mistake, they will just use some
fancy term for this, such as "refactoring".
Date: 18 Mar 2009 15:41:12
Message: <49c14e58@news.povray.org>
  Why not? Having the compiler check for breaking of agreements (eg. "don't
access these variables") is much better than oral agreements. The compiler
is much better at catching mistakes than you are.
