Invisible a écrit :
>> So what's your weight now then, given that you've been 80 for years
>> and you've recently gained a load?
> This is the operative question...
Hey maybe you've not gained weight but just lost density :-)
Vincent
Invisible wrote:
> My diet is 80% cheese, 15% chocolate, and 5% other stuff. My lifestyle
> consists of spending hours sitting completely motionless in front of a
> computer, and also sleeping.
This is great to gain weight and loose metabolism, you go slowly and
silently down to a road of physical misfit. And from the above you eat a
lot of fatty food, change that, go to a Nutritionist to eat balanced and
healthy.
> Given the above, I ought to be an eighty tonne walrus like my other. But
> I've always been a stick insect. But now, suddenly, I'm getting fat. If
> I'd *changed* something I could understand. But I haven't. The only
> difference I can think of is that I now do dance classes...
This should be helping since is physical exercise.
> healthy.
Actually modern nutritionist knowledge is slowly changing the classical
notion of fats&cholesterol = bad.
It is becoming more and more clear that fats+carbohydrates, especially
when the latter is unhealthily abundant, is the killer combination. Fats
in themselves are not that bad, but when you combine them with tons and
tons of carbohydrates, that's when the body starts really storing the stuff.
The reason is simple: The main energy source for the body is carbohydrates.
When you eat a balanced diet, you get approximately the right amount of
carbohydrates for your energy needs, and your body then neither consumes
nor increases its fat reserves. When your weight is normal, this is the
optimal situation.
The problem with eating tons of carbohydrates is that now your body is
getting a lot more energy than it needs. This triggers the body to start
storing those fats. (Also some of the extra carbs are also *converted*
into fats and stored, besides the actual fats you are eating.)
If you eat tons of fat but only some carbs, your body is actually not
getting extra energy (the body converts fats into energy very slowly, so
eating tons of it is almost as if you were not eating them at all, assuming
you are not eating tons of carbs as well). Thus those extra fats are not
stored, but ejected by your body.
Of course this doesn't mean that eating tons of fat and no carbs is
healthy either. Fats can start building up on your artery walls and other
such nasty stuff, so it's not really a good idea to hog on tons of fat.
The other extreme: Not eating fats almost at all, is also not very healthy
because the body *needs* fats for many things.
Also eating meat/fats and no carbs (the so-called Atkins diet) has proven
to be unhealthy in the long run because the body needs carbs as well. So
the most healthy diet is always balanced: Some carbs, some fats, a good
amount of proteins, and a healthy amount of other nutrients.
The problem with the modern western eating culture is that most foods
contain tons and tons of processed carbohydrates which digest fast. Not
only does this overwhelm your energy needs (triggering the fat storing
processes of your body), but it gets you "sugar highs", getting you
basically addicted to these carb rushes. When you get addicted enough,
it will be *very* difficult to stop. This is the worst possible situation.
I saw an interesting documentary once about the diet of Eskimos. (As in,
native americans inhabiting places where it's always snowy.) Their only
source of food is fish, seals, and so on - basically fatty meat. One of the
investigators lived on such a diet for a couple of years and found very
little unhealthy effects.
This has been an interesting anecdote, not science. :-)
My fortune cookie said, "You will soon be
unable to read this, even at arm's length."
Invisible wrote:
>> If you prepare food
>> in the evening then make a little more and take it to eat cold the next
>> day if suitable (do you have a microwave at work?).
> Don't have a microwave. The only thing we have is boiling water for
> making tea.
Wow, we do have a microwave and I'm sure we're a way smaller company than
you :)
>>> I spent 2 years of my life cycling over 2 hours per day. It made NO
>>> DIFFERENCE at all.
>> Perhaps because you weren't having a weight problem back then?
> No, but you would have *thought* I'd get at least slightly fitter, no?
Maybe you avoided getting fatter? You say it made no difference, but this
time again, you don't know what would have happened if you *didn't* cycle.
Mueen Nawaz wrote:
> I was just like you. For about 8 years, my weight remained at 60-62 kg.
> I could eat whatever I wanted and it wouldn't make a difference.
The doctor says I'm underweight. With the amount of exercise I do (ha),
you'd expect I'd be a fat ball of fat!
The "digest fast" part is important too. Food that can get digested fast
makes your digestive system use less energy. Less energy = less carbs used.
> What can I say? White bread has a nicer texture. :-P
And I like eating chocolate better than vegetables, doesn't mean I eat it
the whole time though.
> Cold meat. Yay. :-/
What, you have never enjoyed a good ploughmans?
Can't you buy one, I got one for our office here, they're only like 40 quid
and can be easily put somewhere (no plumbing or gas required, just a mains
outlet).
I expect you did.
> (Let us not even go into the fact that 1.2 hours to travel 4.6 miles is an
> average speed of something like 5 MPH,
Hehe sounds like you weren't really pushing yourself then, dude people can
WALK 4.6 miles in 1.2 hours! In a bike, even if you're totally unfit you
should be able to do 4.6 miles in under 30 minutes, after a year of training
under 20 or even 15 minutes no problem.
> I think the key here is to find something that I can realistically stick
> at. I mean, currently I have barely enough time each evening to do the
> stuff I *want* to do! So cutting out a huge chunk of that time to do
> something mind-blowingly boring and probably futile isn't going to be
> easy.
Nobody said it was going to be easy.
> Well, my mum seems to eat nothing _but_ dead plants. And she's still
> huge...
How much exercise does she do per week?
> the investigators lived on such a diet for a couple of years and found
> very little unhealthy effects.
Hehe, everytime I go to Japan I always lose weight, a diet of fish and rice
seems to do the job for me!
>> Cold meat. Yay. :-/
I hate cold meat. It's just not very nice cold.
>> is an average speed of something like 5 MPH,
Every morning I arrived so exhausted I could barely stand up. How is
that "not pushing myself"?
> dude people can WALK 4.6 miles in 1.2 hours!
Er, yeah, right.
As I recall, last time we want on a school trip that was a 5 mile walk,
it took an entire day to walk it. (But then, that *was* 5 Mr Martin
miles...)
> unfit you should be able to do 4.6 miles in under 30 minutes, after a
> year of training under 20 or even 15 minutes no problem.
Yeah, well... my sister could probably do that. But not me.
>> huge...
Does whinging count as "exercise"?
