POV-Ray : Newsgroups : povray.off-topic : World Community Grid Server Time
4 Jul 2026 08:30:33 EDT (-0400)
  World Community Grid (Message 11 to 20 of 103)
Subject: Re: World Community Grid
Date: 8 Mar 2009 20:27:38
Message: <49b4627a@news.povray.org>
On 3/8/2009 4:25 PM, Nicolas Alvarez wrote:
> I was once able render POV-Ray animations on a thousand computers using the
> same software World Community Grid uses.
I remember you talking about that before; how did it go?
...Chambers
www.pacificwebguy.com
Date: 8 Mar 2009 21:57:00
Message: <49b4776b@news.povray.org>
>> the same software World Community Grid uses.
Went great; then I lost the time, motivation, and free hosting.
Some day, when I don't have so many things going at once, I may resurrect
it, starting from POV3.7 code and/or MCpov.
Date: 9 Mar 2009 01:13:50
Message: <49b4a58e$1@news.povray.org>
Orchid XP v8 wrote:
> ...on the other hand, my PC uses a *maximum* of 650W. It cannot use any
> more power than that. Most of the time, it uses more like 100W. So,
> about as much as a single light bulb. You wanna guess how many light
> bulbs there are in this house??
	Switch to compact fluorescents. A 26W one should provide as much light
as a 100W one.
> And let us not forget, running the kettle uses THREE THOUSAND FIVE
> HUNDRED WATTS. So, at much as 35 light bulbs. I am unable to measure the
	Yes, but the kettle is on for a few minutes.
> Seriously. A PC is not a real high-power device. If you want to lower
> your bills, look for anything that makes stuff hot. (Lighting, heating,
> washing, etc.)
	True - a PC is usually not the first place to reduce energy consumption.
OK, so what's the speed of dark?
                   /  \/  \ u e e n     /  \/  a w a z
                       >>>>>>mue### [at] nawazorg<<<<<<
                                   anl
Date: 9 Mar 2009 03:57:00
Message: <49b4cbcc@news.povray.org>
> as a 100W one.
LEDs are the way forward, they are more efficient (and getting more
efficient the whole time) and more environmentally friendly (they don't
contain mercury) and fix almost all of the disadvantages CFLs have.  Just
wait...
Date: 9 Mar 2009 05:35:08
Message: <49b4e2cc@news.povray.org>
>> as a 100W one.
> Just wait...
I don't know about CFLs, but our house has several "energy saving"
lighting units. The problem is, there's a 20 minute delay between
turning them on and being able to see where you're going...
LEDs are indeed efficient, but the main problems currently seem to be
making "white" light with them, and illuminating large areas.
Date: 9 Mar 2009 05:37:37
Message: <49b4e361@news.povray.org>
andrel wrote:
> Are you cooking electric? How do you heat your house?
Both of those are gas.
The microwave oven, however, is electronic. I haven't measured it, but
it's rated at 900W. (I have no idea whether that means it uses 900W of
juice, or just that it produces 900W of microwave energy.)
> Anyway, there is this problem that your PC may be on for periods much
> longer that the washing machine.
Like I said, playing CSS (which you're presume is a reasonably intensive
task) for 2 hours solid used a fraction of one kWh. I don't know what it
uses if I run the computer for an entire day (presumably it varies by
the task I set it to do), but I imagine running the washing machine
several times per day - or accidentally leaving the lights on - uses far
more power.
Date: 9 Mar 2009 06:29:10
Message: <49b4ef76$1@news.povray.org>
> lighting units. The problem is, there's a 20 minute delay between turning
Yup, and not having studied them carefully, I hear they make a slight
buzzing noise which can be annoying in a quiet room (eg while trying to
read).
There's no problem with making white light, the most efficient way is just
to put a mixture of different coloured LEDs in one "lamp" to give whatever
white temperature you want.  The other way is to put a yellow phosphor
infront of a blue LED, but that's not as efficient electrically (it means
you can get white from a single LED though).
The biggest problem is keeping the LED temperature low enough during use,
the designs I've seen have been mainly heat sink, but they seem to have
overcome that for 60W and 100W equivalent bulbs:
http://www.metaefficient.com/leds/led-light-bulbs.html
Date: 9 Mar 2009 06:41:00
Message: <49b4f23c$1@news.povray.org>
> read).
I haven't found that to be a problem yet.
The main problem for me is that they're just not bright enough. I
actually can't tell what colour my clothes are in the morning because I
don't have 20 minutes to stand there waiting for the thing to get bright.
> just to put a mixture of different coloured LEDs in one "lamp" to give
> whatever white temperature you want.  The other way is to put a yellow
> phosphor infront of a blue LED, but that's not as efficient electrically
> (it means you can get white from a single LED though).
OK, I rephrase: I personally have yet to see a "white" LED that wasn't
actually pale blue.
> use, the designs I've seen have been mainly heat sink, but they seem to
> have overcome that for 60W and 100W equivalent bulbs:
Well, I'm sure the technology won't stand still. IIRC, my dad has some
small LED ligth fittings illuminating the stairs. But they're not very
bright. (Despite containing about a dozen LEDs each.)
Date: 9 Mar 2009 07:35:10
Message: <49b4feee$1@news.povray.org>
> actually pale blue.
That's because you're used to "normal" light bulbs that are very very yellow
(just try taking a photo indoors with the camera on "outdoor" setting and
you'll see what I mean).  It's not that LED manufacturers can't make this
colour, it's just there is no demand for it (backlights for LCDs need a much
bluer white than normal light bulbs).  If you want to make a yellower colour
yourself then you can make your own yellow phosphor to put on a blue LED, or
just place some yellow LEDs around the white ones :-)
Date: 9 Mar 2009 07:42:25
Message: <49b500a1$1@news.povray.org>
>> actually pale blue.
> yellow.
How about sunlight? Is that yellow too? (I mean, by the time it reaches
the ground.)
> can't make this colour, it's just there is no demand for it (backlights
> for LCDs need a much bluer white than normal light bulbs).  If you want
> to make a yellower colour yourself then you can make your own yellow
> phosphor to put on a blue LED, or just place some yellow LEDs around the
> white ones :-)
Heh. The trouble is the light in my room ("energy saving bulb") gives
off such a pinky yellowy colour that I can't actually tell whether an
item of clothing is blue or black. :-P
