POV-Ray : Newsgroups : povray.off-topic : My toy Server Time
4 Jul 2026 09:32:37 EDT (-0400)
  My toy (Message 21 to 30 of 85)
Subject: Re: My toy
Date: 3 Mar 2009 06:40:56
Message: <49ad1748$1@news.povray.org>
>> How strong is the metal? And how heavy? I mean, I guess it varies by
>> which particular alloy you use... Presumably somebody has already
>> tabulated this data?
> Of course.
Heh. Or do you look that up from the spec sheet of the guys selling you
the metal? ;-)
>> I imagine for a sufficiently small part, you can't physically apply
>> enough torque to it to actually bend it. (In normal circumstances, at
>> least.)
> Why not?  What is going to limit how much torque you can apply, you just
> get a machine with a beefier tool and press attached.
Sure. I'm thinking about when the part is in normal use. When you're
manufacturing it, you can use all kinds of machines to apply multiple
tonnes of force to it. But once you've bolted it to the car, somebody
isn't going to put 20 tonnes through it with their bare hands. You'd cut
your fingers for one.
But, if the part was larger, it might be easier to bend it with your
bare hands. And that's kind of what I'm getting at: does the thickness
of metal "necessary" to make a part "strong enough" for everyday use
depend on how large the part is?
>> Hmm. And now I'm wondering... how do you manufacture the tool you use
>> to manufacture the thing you actually wanted to make in the first
>> place? :-D
> Some guy sitting at a computerised milling machine I would imagine.
> And yes, how do you make that, etc etc I think at the beginning someone
> had to make something with their bare hands :-)
Sounds like bootstrapping a compiler.
Haskell's compiler is written in Haskell, so how do you compile it? ;-)
[I realise nobody gives a **** what the answer to that one is, but I'm
going to tell you anyway.]
To compile GHC, first you need a working Haskell compiler.
Realistically, a working copy of GHC itself, since the source code uses
so many GHC-specific features. But it is guaranteed to work with
anything newer than GHC 6.6, which is pretty old. (Apparently, the very
first GHC was written in ML.)
Anyway, you need *something* that can compile Haskell source code. This
is the "stage-0" compiler.
You then take the source code for GHC, compile it using the stage-0
compiler, and the result is called "stage-1".
This compiler, however, is linked against whatever Haskell libraries
your stage-0 compiler has. So the next thing you do is recompile all the
Haskell standard libraries using the stage-1 compiler. (This takes
drastically longer than compiling the compiler itself!)
You then compiler GHC all over again, using the stage-1 compiler and the
newly compiled libraries. This produces the "stage-2" compiler, which is
the final product.
[Optionally, as a stress test, you can recompile GHC using stage-2
yielding a stage-3 compiler. But the only purpose of this is to check
that stage-2 is working properly; you don't *use* stage-3 for anything.]
It should also be noted that stage-1 has a bunch of features disabled.
Stage-2 has everything enabled, because it's the "final" compiler.
Why not just compile the libraries with stage-0, compile GHC with
stage-0, and be done with it? Well, because libraries compiled with
different versions of the compiler are incompatible. So a library
compiled with stage-0 (which might be, say, GHC 6.6) won't be compatible
with stage-1 (which would be GHC 6.10.x). That's why you have to compile
stage-1, compile the libraries with stage-1, and then compile stage-2
with those libraries.
Subject: Re: My toy
Date: 3 Mar 2009 07:14:01
Message: <49ad1f09@news.povray.org>
> the metal? ;-)
Well there are standard steel and aluminium alloys that have well documented
properties, when a supplier sells you one of these types you know what you
are getting, and if it's not within the official standard then you can get
your money back etc.
Ah I see, you mean if a part is designed to have some force applied during
normal use, like a door handle or a key or something.  Well yes, obviously
then you figure out what is the maximum force likely to be applied during
normal use and simulate/test that it will not break under that load.
> Anyway, you need *something* that can compile Haskell source code. This is
But who wrote the stage 0 compiler?  Was it written in machine code?
Subject: Re: My toy
Date: 3 Mar 2009 07:44:09
Message: <49ad2619$1@news.povray.org>
>> you the metal? ;-)
> documented properties, when a supplier sells you one of these types you
> know what you are getting, and if it's not within the official standard
> then you can get your money back etc.
Ah, I see.
> during normal use, like a door handle or a key or something.  Well yes,
> obviously then you figure out what is the maximum force likely to be
> applied during normal use and simulate/test that it will not break under
> that load.
If you're making something like an LCD mounting bracket, do you actually
do a detailed simulation for that component? Or do you just do "OK, well
we're using 0.3 mm steel for the rest of the frame, so let's use 0.3 mm
steel"? (And change it if it turns out to be too weak...)
>> This is the "stage-0" compiler.
As I say, the "original" GHC was written in ML. (I have no idea what the
ML interpretter was written in...) These days, the stage-0 compiler will
just be an older version of GHC which is already compiled.
The fun thing is if you want to ran GHC on an unsupported platform. This
apparently involves asking GHC to compile itself into ANSI C, and then
using a suitable C compiler for the target platform to produce a working
binary. Apparently some nutter used this to get GHC to work on a mobile
phone powered by an ARM CPU or something random like that...
Aside from GHC, there are a few other Haskell compilers. AFAIK, Hugs is
written in plain C. NHC98, YHC, JHC, LHC and EHC/UHC are all written in
Haskell. Most of these are "experimental" compilers that can't be used
for production use. Only GHC is really "production-ready", and hence
when people say "Haskell compiler" they almost always mean GHC.
Subject: Re: My toy
Date: 3 Mar 2009 07:59:23
Message: <49ad29ab@news.povray.org>
Only if it's in a place where someone could grab hold of it and tug it.
Best example is when it's mounted sticking up from the top of the dashboard
like this:
http://image.motortrend.com/f/9217160/112_0611_03z+2005_bmw_x3+interior_dash.jpg
It has to be able to withstand somebody grabbing hold of it and pulling to
help themselves out of the car, in that case the metal is much thicker and
we run finite element simulations to check.  It's further complicated
because during an accident if someone hits the display it must collapse
backwards and not be rigid, so you kind of need 1-way strength :-)
> Or do you just do "OK, well we're using 0.3 mm steel for the rest of the
> frame, so let's use 0.3 mm steel"? (And change it if it turns out to be
> too weak...)
For most other things, yes, or just based on our experience from the 100
other LCDs we've made over the last 10 years.  On a recent project we had to
change from 0.3 to 0.4 mm metal after some clips that were designed by the
customer were not strong enough.  Nobody tested for this or simulated it,
but to be honest there is no need as things like that always show up in the
early samples before we get anywhere near making the mass production tools.
> binary.
And I guess the C compiler can be cross-compiled on a pre-existing platform.
Subject: Re: My toy
Date: 3 Mar 2009 08:14:28
Message: <49ad2d34$1@news.povray.org>
>> actually do a detailed simulation for that component?
Figures.
> to help themselves out of the car, in that case the metal is much
> thicker and we run finite element simulations to check.
How long does it take to do a computer simulation to check that
something won't break? How complicated is the process, and how much
computer time does it take?
> It's further
> complicated because during an accident if someone hits the display it
> must collapse backwards and not be rigid, so you kind of need 1-way
> strength :-)
So... corrugated? Or something.
>> the frame, so let's use 0.3 mm steel"? (And change it if it turns out
>> to be too weak...)
Heh, yeah. I guess if you've made something similar before it helps a
lot. ;-) I was just thinking, I imagine for "most" manufactured items,
the designers probably have a basic intuition about roughly what
thickness of metal is required. I don't suppose they do an exhaustive
mathematical derrivation of optimal thickness for every single component
ever designed.
> had to change from 0.3 to 0.4 mm metal after some clips that were
> designed by the customer were not strong enough.  Nobody tested for this
> or simulated it, but to be honest there is no need as things like that
> always show up in the early samples before we get anywhere near making
Right. So you take an educated guess, and if the prototypes fall apart,
you figure out which bit broke?
>> This apparently involves asking GHC to compile itself into ANSI C, and
>> then using a suitable C compiler for the target platform to produce a
>> working binary.
> platform.
Almost every platform known to man already has a C compiler - even if it
has nothing else. The C compiler is typically the very first thing that
gets built. ;-)
Itanium? Yep, that has a C compiler. UltraSPARC? Yeah, C compiler.
Subject: Re: My toy
Date: 3 Mar 2009 08:27:17
Message: <49ad3035$1@news.povray.org>
> How long does it take to do a computer simulation to check that something
> won't break? How complicated is the process, and how much computer time
> does it take?
That sort of simulation is very quick and easy, only a few hours for a
moderately complicated part and then you get back data about the stress at
every point.
The harder simulations are the ones where you want to actually simulate some
dynamic force (like your product being dropped on the floor) and then of
course the simulator needs to deal with collisions and deformations.  These
sorts of simulations can take a long time to set up and run for days just to
simulate a fraction of a second.
On the one I worked on we just bolted the base of the display to the car,
and then had two hooks at the back half way up that hooked into the car
mechanics (no screws).  That way when you pulled forward on the display the
hooks provided the strength and stiffness, and if you pushed back the hooks
did nothing so you were free to bend the bottom fixing points if you hit it
hard enough.
> Heh, yeah. I guess if you've made something similar before it helps a lot.
> ;-) I was just thinking, I imagine for "most" manufactured items, the
> designers probably have a basic intuition about roughly what thickness of
> metal is required. I don't suppose they do an exhaustive mathematical
> derrivation of optimal thickness for every single component ever designed.
It depends on the product and how critical it is, plus how many you are
making.  For something you are only making 1 of, like a bridge or a big
building, you will probably do a lot of calculations.  If you are planning
to make 10 million of something, you can probably just make a few hundred
test samples and have chance to optmise them if needed.
Yup, for car parts we usually have 3 rounds of prototypes before mass
production starts.
> gets built. ;-)
Someone still has to build it though in the first place.
Subject: Re: My toy
Date: 3 Mar 2009 08:43:28
Message: <49ad3400$1@news.povray.org>
> at every point.
Right. So not instantaneous, but not months of computer time either.
I take it there's more to it then just asking the computer "hey, will
this break if I put 25 N through it?"
> some dynamic force (like your product being dropped on the floor) and
> then of course the simulator needs to deal with collisions and
> deformations.  These sorts of simulations can take a long time to set up
> and run for days just to simulate a fraction of a second.
At what point does it become cheaper to just make the thing rather than
simulate it?
> car, and then had two hooks at the back half way up that hooked into the
> car mechanics (no screws).  That way when you pulled forward on the
> display the hooks provided the strength and stiffness, and if you pushed
> back the hooks did nothing so you were free to bend the bottom fixing
> points if you hit it hard enough.
Mmm, ingenious.
> planning to make 10 million of something, you can probably just make a
> few hundred test samples and have chance to optmise them if needed.
Well yeah, it's going to depend on how safety-critical it is. If you're
making a coathanger, probably not much need to test it. If you're making
a karabina... there are probably legal requirements for exhaustive testing.
>> apart, you figure out which bit broke?
> production starts.
One thing I always wondered... You see people doing all these crash
tests, right? So... where the hell do you get an endless supply of red
cars to crash into things?!
>> it has nothing else. The C compiler is typically the very first thing
>> that gets built. ;-)
Sure. But not the Haskell development team. ;-)
I would think it's by a cross-compiler though, yes. Indeed, some systems
are "too small" to run a C compiler natively, so you *must* cross-compile.
Subject: Re: My toy
Date: 3 Mar 2009 08:55:21
Message: <49ad36c9$1@news.povray.org>
Invisible wrote:
> myself. OTOH, I have yet to write a working Tic-Tac-Toe program, so...
> maybe not. :-/
I did that in grade school. :) It was unbeatable.
~Mike
Subject: Re: My toy
Date: 3 Mar 2009 09:01:35
Message: <49ad383f$1@news.povray.org>
>> maybe not. :-/
The hard part is figuring out how to draw the graphics on screen and
register the mouse clicks. Usually you have to mutilate your program to
fit the window manager's event loop...
Subject: Re: My toy
Date: 3 Mar 2009 09:44:19
Message: <49ad4243$1@news.povray.org>
Choose a language / IDE / API that gives you easy access to graphics?
>  and register the mouse clicks.
Ditto.
> Usually you have to mutilate your program to fit the window manager's
> event loop...
Don't see how, if you have written functions like:
MouseClicked(int xpixel , int ypixel)
RedrawScreen()
etc, you just need to call them in response to the correct window manager
messages.  Of course if you write the whole game as just a big long chunk of
code you are going to find it hard to fit it in with a window manager.
BTW why don't you just do a text based version?
