POV-Ray : Newsgroups : povray.off-topic : Who says .NET is slow...? Server Time
16 May 2026 02:19:48 EDT (-0400)
  Who says .NET is slow...? (Message 11 to 20 of 27)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: Who says .NET is slow...?
Date: 22 Feb 2009 14:32:52
Message: <49a1a864@news.povray.org>
Nicolas Alvarez wrote:
> Mike Raiford wrote:
>> 1024x768 frame buffer...
> I estimate I'm getting 0.5fps.
Wow... are you running Vista, by any chance..? On my WinXP machine, I
was getting about 20fps..
I found that on my Vista machine it runs significantly slower.
Date: 22 Feb 2009 14:39:55
Message: <49a1aa0b$1@news.povray.org>
Darren New wrote:
> Mike Raiford wrote:
> OK. I'm just saying ... what makes you think it's not "down to the wire"
> in this case?  It doesn't look like you're doing anything in the inner
> loops of the tick that you couldn't do equally well in C, so why
> wouldn't the JIT generate equivalently efficient code?
Maybe it is, but everything is still managed code. The JIT should
produce efficient code, for sure, and it does. I was just happy to see
that an effect like this can be achieved, and with a relatively large
frame buffer. That's all I guess. Some seem to think that the .NET
framework, or that JIT environments are too slow for these sorts of
tricks, or effects.
I think, didn't someone port Quake to Managed C++?
> Cool. I've only done large-scale manipulations, not drawing
> pixel-by-pixel, so I guess I never ran into that problem.
Right, the GDI+ functions are generally pretty good for most drawing
situations.
Date: 22 Feb 2009 15:48:46
Message: <49a1ba2e$1@news.povray.org>
> tricks, or effects.
True. People who never really think about the issues tend to just listen to
the FUD.
Yes, but I'm not sure they ported the "hard parts". As in, it was something
like a few hundred lines of code written over the course of a handful of
hours to "port" it. I don't think they (for example) moved all the data
structures into managed space, other than perhaps the screen and keyboard I/O.
> situations.
I thought the transformation matrix approach to color control was pretty
cool. Probably pretty common across toolkits, I'd guess, tho.
   My fortune cookie said, "You will soon be
   unable to read this, even at arm's length."
Date: 23 Feb 2009 02:35:45
Message: <49a251d1$1@news.povray.org>
Running Vista here, I estimate about 10-20 fps (assuming it goes up one line
per frame).
It's only using 1 of my cores though .... :-)
Date: 23 Feb 2009 02:37:00
Message: <49a2521c$1@news.povray.org>
> I would think there's relatively little need to be slow in a program like
> this, where it's all manipulation of fundamental structures.
I think the GPU would be faster at this sort of program than the CPU :-)
Date: 23 Feb 2009 06:56:14
Message: <49a28ede@news.povray.org>
> line per frame).
Then why the hell is my Vista box always so freaking slow?!!
Yeah, I didn't get all fancy and multi-threaded.. I suppose it could be
easily parallelized, though.
Date: 23 Feb 2009 07:16:20
Message: <49a29394$1@news.povray.org>
>> line per frame).
Ooh I just tried it on my XP laptop, and by the time the red has got to the
top it's only 80% of the way there on Vista.  My Vista box is about 10x
faster than my laptop so who knows what is going on.
Does it make a difference under Vista if you take out the
"ControlStyles.OptimizedDoubleBuffer" flag?
Also you are locking the bitmap for quite a long time (relatively), you
should literally lock, memcopy, unlock. Any processing should be done
outside of that on a separate buffer.  Maybe it is holding up Vista somehow
when it's trying to copy the bitmap to the graphics card?
Date: 23 Feb 2009 12:00:00
Message: <49a2d610$1@news.povray.org>
>> like this, where it's all manipulation of fundamental structures.
http://www.nzone.com/object/nzone_cascades_videos.html
Date: 23 Feb 2009 16:16:43
Message: <49a3123b@news.povray.org>
I'm running it via Mono, on Linux.
Date: 24 Feb 2009 04:06:29
Message: <49a3b895$1@news.povray.org>
I'm *still* irritated that you can't run Cascades without Vista...
