![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Darren New wrote:
> On a related note, and I'm sure I could track this down with enough
> googling, but I only spent about 10 minutes on it and didn't find
> anything that looked likely: Can "apt" use "yum" repositories?
> Specifically, if there's a repository with software for "open suse", can
> Ubuntu manage packages from that easily? How about RPM repositories?
> Most of the third-party repositories I see offer those two.
APT definitely works with RPM (according to Wikipedia).
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I don't think Apt can use RPM repos (which the openSUSE repos would be).
You can convert packages using alien, which I have done with some
success, though library names might be different (they were for a video
converter I was pointed at) so it takes a little work to get the package
working.
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> can Ubuntu manage packages from that easily? How about RPM
>> repositories? Most of the third-party repositories I see offer those
>> two.
Seen, this is what happens because I don't use Debian-derived systems. :-)
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'll investigate more, but I don't know if the fact that something works
with RPM files means it also works with RPM repositories. I don't know if
they're the same kind of thing. (By "works with repositories", I mean
things like give you the TOC, keep updates updated, etc.)
My sysadmin guru says to use Ubuntu for servers these days, but I've been
using openSuSE, so ... I need to figure out where to get the packages I use
in a way that Ubuntu likes. This is what happens when you start getting
incompatible competition in Linux releases. :-)
"Ouch ouch ouch!"
"What's wrong? Noodles too hot?"
"No, I have Chopstick Tunnel Syndrome."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
out of curiosity, what are his reasons for that recommendation?
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Last time I asked him to configure some sophisticated stuff in OpenSuSE, it
was more desktoppy than servery, apparently. Like, the configuration of the
IP address and stuff sticks to the MAC address in SuSE, but to the card slot
in Ubuntu, so if you want to configure a disk you're going to mail to
someone to stick in a machine in a different city, it's harder with SuSE.
That was the bit that bit me, for example. Binding two network cards in a
fail-over configuration was apparently not as easy as it could be too.
I'm not real sure I got all his reasons, but he's been a UNIX guru since
well before Solaris was called SunOS, and he seemed to think it was
unnecessarily difficult to set things up there. So I asked "where do you
download RedHat from, or what do you use instead." He said Ubuntu. <shrug>
"Ouch ouch ouch!"
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> it was more desktoppy than servery, apparently. Like, the configuration
> of the IP address and stuff sticks to the MAC address in SuSE, but to
> the card slot in Ubuntu, so if you want to configure a disk you're going
> to mail to someone to stick in a machine in a different city, it's
> harder with SuSE. That was the bit that bit me, for example. Binding two
> network cards in a fail-over configuration was apparently not as easy as
> it could be too.
> <shrug>
Thanks. Network config is something that I've heard works very
differently, and even on SLES8 (granted, two major versions ago), it was
tied to MAC addresses which made imaging very difficult (especially as it
retained the old address and used it when the MAC changed - which I
thought was really odd).
I remember SunOS as well. :-)
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
http://ars.userfriendly.org/cartoons/?id=19990303
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
(chortle!) Sent along, just in case.
"Ouch ouch ouch!"
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Orchid XP v8 wrote:
> As another guess, I think KNOPPIX is defaulting to using the "unstable"
> branch rather than the "stable" branch, meaning it picks packages that
> depend on whole new versions of libc and other critical infrastructure.
> Telling it to pick the newest package from "stable" seems to make
> everything work beautifully. I wonder why KNOPPIX is set this way?
Because...
> OTOH... I asked for GHC, and I got version 6.6. That's *years* old
> (current version is 6.10.1 - although note they skip odd-numbered
> versions). Maybe that's why?
... stable is ment to be stable, so all the software getting to Debian
Stable is in testing -phase for a long time. Unstable is more like
bleeding edge.
-Aero
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
