POV-Ray : Newsgroups : povray.off-topic : fun project - point clouds Server Time
15 Oct 2024 01:08:23 EDT (-0400)
  fun project - point clouds (Message 1 to 10 of 19)
Subject: fun project - point clouds
Date: 11 Feb 2009 15:34:42
Message: <49933662$1@news.povray.org>
Ok, so a project coming up may require that I deal with some very large
point clouds?
I've done a fair bit of research into this and have a few techniques and
tools in hand that aid working with large point clouds.
I am trying to get a feel for what else is out there that I might be
missing.
Anyone have any brain matter than they can throw out about how to work
with large point clouds?
Thanky....  Tom
Subject: Re: fun project - point clouds
Date: 11 Feb 2009 17:24:55
Message: <49935037$1@news.povray.org>
That depends quite a bit on what you want to do with them or use them for.
Date: 16 Feb 2009 13:55:40
Message: <4999b6ac@news.povray.org>
Man, I was curious!  I really am more than happy to help, it's just that
which algorithm you want to use depends on the application.  As a
general suggestion, spatial partitioning hierarchies (like octrees or
kd-trees) are good when you want to quickly do operations that are
localized around a small area in space, but that's about the most I can
say without knowing more.
Date: 17 Feb 2009 11:52:48
Message: <499aeb60$1@news.povray.org>
>>> work with large point clouds?
>> for.
Sorry about the delayed response - been VERY busy lately and have not
had much other time.  I guess given the economic climate this is a good
thing.
Essentially I am using a 3D laser based scanner to gather portions of
mine tunnels.  The scanner gathers data as points in a spherical format.
   I estimate that there will be ~150 separate scans totaling ~30
million points.
I currently deal with the scans only as point clouds.
I have methods to align the scans.
I can put all of the points into one large point cloud that has 30
million points.
What I am looking for is:
Methods or programs to 'simplify' the resulting point cloud so that it
still is a fair representation of the overall area, but has much fewer
points ~300k.
Methods or programs to create a single mesh of the resulting point cloud
that can represent tunnels.
I've 2D draped for a mesh before - that's no problem.  It's the 3D
meshing of arbitrary points that I have not experienced yet.
I'm pretty good about taking an approach (steps or algorithm) and
putting them into code.
If you would like more info just ask questions and I will provide what I
can.
I might be able to dig up some past work that is similar to what I am
trying to do.
Tom
Date: 17 Feb 2009 14:44:48
Message: <499b13b0$1@news.povray.org>
> points ~300k.
That's a nifty problem! I might have some ideas, but first I have a few
questions about it:
* I'm talking it that each scan was done from a different location, so
while each individual scan can be represents a `spherical' cloud of
points the union of the scans does not?
* I assume that the final goal is the mesh and that the first task is
just needed so that the resulting mesh is relatively small?  I ask
because if so then it might be reasonable to generate a large mesh and
then simplify it later, which would allow different algorithms.
* In terms of simplifying the point cloud/mesh, what are the accuracy
requirements of the simplification with respect to the density of the
point cloud from the scans?  In other words, if the scans are very dense
but you don't actually need that sort of accuracy in the mesh/simplified
cloud then you can probably get away with simpler algorithms than if you
need really high resolution in some areas and can only get away with
discarding points which don't contribute anything useful to the
geometry.  For instance, would it be sufficient to simplify the point
cloud by simply discarding all points which are within, say 10cm, of
each other?
* Have you tried existing approaches for generating a mesh from a point
cloud?  If so, did they not work because you have too many points for
them to operate effectively?
Date: 17 Feb 2009 16:54:45
Message: <499b3225$1@news.povray.org>
Am Tue, 17 Feb 2009 11:44:49 -0800 schrieb Kevin Wampler:
Maybe you are looking for something else (and I didn't understood the
question), but I think, I was wondering about this problem 7 years ago
(56K modem - wow it has been some time :))
http://news.povray.org/povray.newusers/thread/<3c62e3dc%
40news.povray.org>/
Date: 17 Feb 2009 16:59:20
Message: <499b3338$1@news.povray.org>
Am Tue, 17 Feb 2009 11:52:47 -0500 schrieb Tom Austin:
Have you thought about Voronoi tesselation? That could give you a basic
mesh, if you cut away the outer layers.
Date: 17 Feb 2009 17:40:30
Message: <499b3cde$1@news.povray.org>
>> points ~300k.
>> cloud that can represent tunnels.
> questions about it:
It's actually pretty fun - if only I had lots of time to work on it!
Yes - exactly
a possible final result is a mesh
I may use an AutoCAD 3D solid or just the simplified points themselves.
I am still interested in what may work on meshes as opposed to points as
the final product may be a mesh.
> each other?
That's some of what I've been thinking about - simplifying where
possible, and providing some more detail where the *object* is more complex.
I would like to figure out a relatively simple method of simplifying the
mesh so that the actual work involved is low - even if processing time
is high.
Honestly, I have not worked with anything to make a 3D mesh out of a
*unified* pointcloud of several scans.
I have made meshes out of 2D point clouds (terrain) made from several scans.
I have made 3D meshes with only 1 scan (somewhat easy).
I'll try to make some time tomorrow to post a video of what I have done
in the past so that you can get a better idea.
Tom
Date: 17 Feb 2009 18:24:56
Message: <499b4748$1@news.povray.org>
It will almost certainly be simpler to avoid attempting to reconstruct a
mesh unless you want to use some third-party software or you have a lot
of time to work on it (which as I understand you don't).  Fortunately
there is some free software you can try. Although I've never used any
myself and haven't looked into the licensing requirements I suspect most
are only available for personal use.
This one is pretty recent, and should be able to handle large number of
points pretty efficiently:
http://students.cs.tamu.edu/jmanson/programs_wavelet_reconstruct.html
This one is based on some relatively recent work from from MSR and
should also be able to manage large numbers of points:
http://research.microsoft.com/en-us/um/people/hoppe/proj/mlstream/
The software here is a bit older but might be useful (links at bottom of
page):
http://grail.cs.washington.edu/projects/scanning/
> complex.
> is high.
The conceptually simplest way to do this would be to generate a
high-detail mesh from the points and then simplify the mesh, so if you
can get a third-party mesh reconstruction algorithm to work that's a
good possibility.
I'll still see if I can think of a good mesh-free simplification
algorithm in case you can't generate a mesh.
Date: 17 Feb 2009 21:21:56
Message: <499b70c4$1@news.povray.org>
> 40news.povray.org>/
I actually remember that conversation and was wondering about it!  The
problems that are being solved are very similar, but it fortunately
looks like there's more software available now for constructing the meshes.
