Warp wrote:
> What I find strange in this particular example is that several people
> at that company had the exact same misconception
This reminds me of a story told by my high school physics teacher about
a survey done to test people's understanding of basic science concepts
which contained the question:
"is there gravity on the moon"
A large number of people got this wrong, which is odd but maybe not so
surprising. What's more surprising is that the they were then asked:
"You've seen the videos of people walking on the moon, if there's no
gravity how do they do that?"
Some people changed their answer at this point, but aparently a large
number responded:
"Because they have heavy boots!"
I completely fail to understand the reasoning that would give rise to
such a conclusion.
Warp wrote:
> Can it be that even some elementary school math teachers don't themselves
> fully understand the generic rules, and instead just blindly repeat the
> examples of the textbooks?
I'm firmly convinced that is indeed the case. In the US at least, you get a
degree in "teaching", not in a specific subject. It's usually not until high
school that you even meet someone with an advanced degree in the field
they're teaching. (Of course, college and university is different.)
"Ouch ouch ouch!"
"What's wrong? Noodles too hot?"
"No, I have Chopstick Tunnel Syndrome."
> such a conclusion.
Movies where people walk in weightlessness using magnetic boots? And lacking
enough science to understand the boots are magnetic?
"Ouch ouch ouch!"
On Fri, 06 Feb 2009 21:43:37 +0100, Kevin Wampler
Of course, just not as much of it.
http://basicinstructions.net/?p=875
FE
When I was in high-school I had a friend who didn't quite understand
correctly the concept of forces, in particular the attracting force of
gravity. (Simpler times were those, in high-school, where the world was
purely Newtonian, but that's not important here...)
In particular, it seemed that he didn't quite understand that a force
acting on an object does *not* necessarily imply movement. After having
been taught in physics class that actually *all* masses attract each
other, no matter their size (only the magnitude of the attracting force
depends on it), he seemed to think that for example given that two
mountains attract each other, they will eventually collide.
No he was not a stupid person. In fact he was quite clever. It just
seemed that he didn't quite fully grasp the concept of forces and what
it actually means. (His reasoning would have been correct if the mountains
were in vacuum, but he seemed to seriously think that since mountains
attract each other because of gravity, they also move towards each other,
even though they are sitting firmly on the surface of the Earth.)
It's difficult to explain. It made much sense in the situation.
Warp <war### [at] tagpovrayorg> wrote:
> It probably is indeed a big problem that some people seem incapable of
> seeing the big picture, the generic rules behind the specific examples,
Then there's the other extreme of people, who are really good at it.
Like that mathematician (I forget his name, but one of the famous ones)
who was in grade school and the teacher told the students to sum all the
numbers from 1 to 100, to keep them busy for at least half an hour, and
practice summation. This guy gives the correct in far less than a minute,
and the teacher is amazed.
I suppose the kid's reasoning was something like: "Hmm, actually if I
take the *average* of all the numbers, and multiply it by the amount of
numbers, I should get the correct result, because summing the average
100 times should be the same as summing all the original 100 numbers.
Now, what is the average of all the numbers between 1 and 100? It must
be (100+1)/2. Now multiply that by the amount of numbers, ie. 100, and
we have the answer."
Unfortunately not many people have that kind of deduction power at
that age (or at any age).
I have a vague recollection that might be Galios. And the teacher set
the problem to keep specifically him quiet.
For what it's worth, I can never ever remember *exactly* what the
correct formula for that is. It's roughly half the square, but I can
never remember the exact figure.
http://blog.orphi.me.uk/
That would be Gauss if I remember correctly. This sort of ability to
correctly generalize things seems to be to be at the core of
mathematical and scientific ability. It's unfortunate that it seems to
be so difficult to fully teach it, although there certainly is an aspect
of innate ability that complicates it (I mean, Gauss' ability certainly
wasn't due to that teacher's excellence).
Well, he is called the "prince of mathematicians"
Wikipedia concurs:
http://en.wikipedia.org/wiki/Gauss
Oh well, I got a famous mathematician who's name starts with the right
letter! ;-)
I miss those times too. I still haven't managed to find an
interpretation of QM that I'm philosophically satisfied with, and it
makes it tricky to think about other philosophical problems when I'm
still not solid on something that fundamental.
Your friend's mistake actually makes sense to me from how you explain
it. I suppose he knew that F=m*a, and thus any force implies some
acceleration no matter what the mass, so his reasoning was actually
largely correct. Really, it seems that his main misconception was not
directly about what forces do, but more about failing to account for all
the places they can come form (for instance, the resistive force due to
the cohesion of the rocks), and that it's only the net force that matters.
Still, I can see how an intelligent person could make that mistake,
since it's rather surprisingly close to correct. That said, without
hearing the reasoning I would have been absolutely baffled by the error.
