POV-Ray : Newsgroups : povray.off-topic : FFT Toy Server Time
16 May 2026 04:53:47 EDT (-0400)
  FFT Toy (Message 11 to 20 of 20)
Subject: Re: FFT Toy
Date: 29 Jan 2009 12:04:57
Message: <4981e1b9$1@news.povray.org>
Mike Raiford wrote:
> Boy did that post look suspicious.. lol.
I was gonna run it in a VM, myself. :-)
   "Ouch ouch ouch!"
   "What's wrong? Noodles too hot?"
   "No, I have Chopstick Tunnel Syndrome."
Date: 1 Feb 2009 06:46:49
Message: <49858ba9$1@news.povray.org>
Mike Raiford wrote:
> Invisible wrote:
>> I don't have any .NET components installed at all. And I don't plan on
>> changing. ;-)
> Why?
>> OTOH, if you think that's bad, try convincing Windows users to
>> download and install the GTK+ runtime so they can run your cool toy. o_O
> I'll install GTK+ if you install .NET :)
My home PC has Visual Studio installed, which *insists* on installing
the .NET runtime for some reason. So I had a go with your toy...
It's quite similar to this:
http://www.falstad.com/fourier/
Not without the sound. ;-)
(CAUTION: If you turn the sound on, turn your speakers down first! It
comes out at maximum volume.)
You may also find this interesting:
http://www.falstad.com/dfilter/
http://blog.orphi.me.uk/
Date: 1 Feb 2009 13:13:30
Message: <4985e64a@news.povray.org>
Shockingly :) Except I show the whole complex system.
Very fun toy to play with :)
I like this the best.. Such fun messing with the filters. FWIW, I now
know why the Chebyshev cab be called resonant.
Date: 2 Feb 2009 04:45:46
Message: <4986c0ca@news.povray.org>
> know why the Chebyshev can be called resonant.
And WHO SAID that physics is borig, eh? ;-) Seems pretty fun to me...
I'll have to throw together a toy for displaying the transfer function
in 3D. ;-)
Date: 2 Feb 2009 08:24:18
Message: <4986f402$1@news.povray.org>
> in 3D. ;-)
I quite enjoy falstad's Java applets...
Interestingly the IIR filters can also be created with an analog circuit
(using the very same poles and zeros, in fact) . I think I seriously
annoyed my wife with the filtering applet. ;)
Its kind of nice knowing enough to predict what will happen when moving
a pole or a zero on the chart (Custom IIR)
Interestingly modern computers are fast enough to run an arbitrary FIR
filter with little (actually no) trouble. Though I imagine the reason
the MT32 emulator went IIR is twofold: 1. It approximates rather closely
the original analog filter in the real device, 2. 32 channels of audio
need to be filtered simultaneously in real time. IIR is vastly faster.
Why do I keep bringing up the MT32 emu? It was the first DSP project I
ever played with the source code to. I'm familiar with it, and I
understand the hardware.
~Mike
Date: 2 Feb 2009 08:42:12
Message: <4986f834$1@news.povray.org>
>> in 3D. ;-)
Yes, there's some good stuff there! :-D
> (using the very same poles and zeros, in fact).
Yes. That's where the whole IIR design theory comes from in the first
place, from *long* before we had electronic computers...
Of course, it's not quite the same. With electronics, you have to
remember that your "10 Ohm" resisters are actually 10 Ohm +/- 10%. ;-)
And also, it seems you cannot make a digital IIR with *exactly* the same
frequency response as the corresponding analogue IIR - although it's a
pretty close match. But analogue IIRs are designed in the s-domain,
which is a different "shape" to the z-domain. It's quite easy to map
coordinates from one domain to the other, but the resulting function
doesn't behave in exactly the same way.
> I think I seriously
Oh yeah - you have a wife, don't you?
[I'm not jelous. Much.]
I tried to build a unit for Reaktor that does this, but without much
success. (Again, the mathematics isn't "hard", it's just fiddly. And
Reaktor isn't terrifically flexible...)
Yes, the DSP guide talks about using IIRs to avoid needing slow FIRs,
but today computers are that much faster that even a Java applet running
on a JVM emulator runs easily fast enough to do a naive 2,000-point
convolution directly. If you wanted faster, an FFT-convulation should
easily give it to you.
Yes.
If you want a digital filter to precisely disect a signal (e.g., for
technical analysts), you want the most accurate filter you can get. But
if you just want to make interesting noises, precision is not important.
Indeed, resonance, ripple, and other "artifacts" that are usually to be
avoided suddenly become useful and interesting! :-D
Ever heard of the Kurplus-Strong algorithm?
Date: 2 Feb 2009 09:20:53
Message: <49870145@news.povray.org>
Right, unless you have 1% resistors.
That was one of things that threw me, if you look at poles and zeros
diagrams, many of them are in the s domain, so you have to remember to
wrap them around a unit circle. when you look at them.
>> I think I seriously annoyed my wife with the filtering applet. ;)
Oh, don't be. I have a son, too. :) He's getting to the "human parrot"
stage, now.. Gotta watch myself. He's great fun now. Can't wait till
he's old enough to take an interest in some of the things I do.
>> moving a pole or a zero on the chart (Custom IIR)
I thought about downloading the demo to play around with. What was
interesting was dragging a pole ever so slightly out of the unit circle
at certain angles (frequency) would cause it to give a screeching
feedback then go unstable. Of course a pole beyond the unit circle is
obviously not a stable configuration. It was interesting to see just how
far I could push it before the applet would decide not to render.
The JVM has come a long way, too. If I understand correctly much of the
code in the VM gets translated to native machine code for the platform
its on. CLR is much the same way.
>> Though I imagine the reason the MT32 emulator went IIR is twofold: 1.
>> It approximates rather closely the original analog filter in the real
>> device, 2. 32 channels of audio need to be filtered simultaneously in
> Yes.
Of course. Much like guitarists discovered an interesting artifact of
their amplifiers. Turn up the gain so the signal starts clipping makes
the guitar sound much more interesting. :)
Dunno why, synthesizers have always fascinated me. More the
waveform-based, rather than sample-based. Twisting tones into
instruments is just cool. :)
Nope :) I'm sure wikipedia has. It has, and looks like I read the
article, so Yes. :)
Very much the IIR plucked string in the applet.
~Mike
Date: 2 Feb 2009 09:37:17
Message: <4987051d$1@news.povray.org>
Even then, you have to be careful that your design won't malfunction
wildly if one of the two "identical" resistors isn't quite "identical",
for example.
With digital IIR, you just have to be careful about numerical stability.
>> same frequency response as the corresponding analogue IIR - although
>> it's a pretty close match. But analogue IIRs are designed in the
>> s-domain, which is a different "shape" to the z-domain. It's quite
>> easy to map coordinates from one domain to the other, but the
>> resulting function doesn't behave in exactly the same way.
Yeah, it's tricky. There are several possibly ways to map the s-domain
to the z-domain - including advanced techniques where one specific
frequency maps exactly while the rest are all approximate. (E.g., so you
end up with a correct cutoff frequency even if the rolloff angle is
different.)
Yeah, I think I have a picture somewhere on my harddrive of him doing
his "it's time to ****ing FEED ME!" expression. Except that, of course,
you can never tell if he means "feed me" or something else - just "I'M
NOT FRIGGIN HAPPY!"
I just hope he doesn't grow up to be an idiot. Because, man, that would
be seriously upsetting as a parent, I imagine... o_O
What, Reaktor?
> What was
The numerical stability depends on the exact kind of arithmetic you use.
(Integer, fixed-point, floating-point, single-precision,
double-precision, denormals...) A Chebyshev LP filter with high-order
basically involves turning the feedback path gain up higher and higher,
and the input gain lower and lower (to keep the passband at unit gain),
until the whole thing becomes completely unworkable.
Still, I gather that with analogue electronics, anything much beyond 6
poles is basically hopeless...
...CLR is on more than one platform? :-P
>> But if you just want to make interesting noises, precision is not
>> important. Indeed, resonance, ripple, and other "artifacts" that are
>> usually to be avoided suddenly become useful and interesting! :-D
Indeed. ;-) Distortion is the new hifi.
I've always loved synthesizers because... I like the crazy music they
make! :-D My dad has some old Moog recordings on LP. Obviously the
synthesizer itself is pretty lame, but some of the compositions people
put together... they don't make recordings like that any more.
> article, so Yes. :)
And then you get into the whole "waveguide synthesis" thing, like
Reaktor's Steampipe instrument. Very neat...
Date: 2 Feb 2009 11:04:32
Message: <49871990@news.povray.org>
> for example.
Real world is never as nice and neat as ideal..
> different.)
Hmmm. That I did not know...
> NOT FRIGGIN HAPPY!"
He's in the point in a vague direction and grunt. If you don't figure
out what he wants immediately, he goes thermonuclear on you. Quite fun.
Just the tip of the terrible twos iceberg, I'm afraid.
Me, too. I can only hope our guidance through his early years will lead
to him making sound decisions later in life.
Of course he has the option to ignore all of our guidance advice and
upbringing, too. :/
> What, Reaktor?
Yes, They have a time-limited demo (with no saving ability) just to play
with. I imagine I won't be able to do terribly much in 30 minutes ...
but I can play for a bit.
Right. Eventually rounding error will add up causing instability.
Hmmm, that would be a rather ugly circuit design, I imagine....
Look at mono.
Ooh, Moog.. neat :) Wish I could find some really good synth tracks.
I remember you posting something created with Steampipe.
~Mike
Date: 2 Feb 2009 11:17:03
Message: <49871c7f$1@news.povray.org>
On the contrary...
http://www.xkcd.com/538/
>> you end up with a correct cutoff frequency even if the rolloff angle
>> is different.)
If you just remap all the points on a line into a circle, the distances
between the poles and zeros changes, which changes the shape of the
transfer function (and hence frequency response). You can minimise this,
but not eliminate it.
Or so I discovered when I tried to *do* this stuff! ;-)
>> course, you can never tell if he means "feed me" or something else -
>> just "I'M NOT FRIGGIN HAPPY!"
LOL @ thermonuclear.
I never cease to be amazed by the energy efficiency of small humans.
They are so small, yet so ably produce deafening levels of sound. It's
quite astonishing! ;-)
>> would be seriously upsetting as a parent, I imagine... o_O
> upbringing, too. :/
Hmm... I bet that would suck though. Man, being a parent just sounds
really stressful and unrewarding...
>> What, Reaktor?
Yes, IIRC you install the program and it runs in "demo mode" until you
type in the license code. (So you *are* getting the "full program", only
with saving disabled and a timelimit imposed.)
It can, of course, load anything created with the registered version of
the program... ;-)
The DSP guide claims that they're usually designed with biquads. (A
biquad being a design that produces two poles and two zeros.) Cascade as
many biquads as you need for the number of poles you want. But I'm told
that high-order filters require you to configure the circuits in
inherantly unstable ways, so they tend to not work properly.
I've got some chewed up tapes of a chewed up LP featuring Bach's Toccata
& Fugue in D minor, and also something called "13 variations on a theme
of Paganini".
If you only play with one thing, play with Steampipe.
Kontact gives you real recordings of a real flute, which do sound more
"real". But only Streampipe lets you very the breath pressure so that at
first there's only hissing, then suddenly a note, and the note goes out
of tune, and finally it jumps up an octave... You can't do that with a
recording.
