POV-Ray : Newsgroups : povray.off-topic : Ok, who didn't know, or at least guess this? Server Time
5 Jul 2026 10:32:32 EDT (-0400)
  Ok, who didn't know, or at least guess this? (Message 161 to 170 of 218)
Subject: Re: Ok, who didn't know, or at least guess this?
Date: 30 Jan 2009 20:08:24
Message: <4983a488$1@news.povray.org>
Darren New wrote:
> I had no problem moving my home directory to a different partition.
Home, yeah. But.. You don't want to do this "before" you install some
things, or they break (and yeah, yeah, they don't follow spec, blah,
blah.. But geeze...), and somehow I doubt that it moved "everything",
not just the documents.
Main point is, must Linux allow you do do this when setting it up, you
don't have to "manually" change it later on, when you have been using it
for weeks, and realize you screwed up.
>> to defraggers that still, to this day, don't have the common sense to
>> defrag the "unused" space,
> Sure they do. Have for ages.
Just ran mine recently and watched. It may now crunch the unused space
(badly though), but not the other.
>> or optimize program access (never mind all the third parties that
>> figured that one out as far back as Win3.11), to.. an endless list.
> They do that too, and have for ages.
No they don't. Or not visibly, and/or obviously. If anything, load times
on some things have gotten "worse" since the last defrag I did...
void main () {
   If Schrödingers_cat is alive or version > 98 {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 30 Jan 2009 20:15:05
Message: <4983a619$1@news.povray.org>
Darren New wrote:
> Patrick Elliott wrote:
>> Seen the lists, seen the rebuttals. Still not impressed. Especially
>> when some of them are things like "Added a mess of new features to
>> DirectX",
> There's a bunch of internal stuff, as well as things like Media Center,
> .NET, etc.
>> unless it is something in the class of user interfaces, and those tend
>> to be used to "hide" things you don't want people mucking with,
> Sounds like One True Scotsman syndrome to me.  Because Microsoft doesn't
> innovate, anything Microsoft does is, by definition, not innovation.
>> FOSS has an excuse for this, they don't have thousands of developers
>> working 24/7 on *one* project, trying to make it bloody work right.
> Actually, it's worse. FOSS actually discourages getting projects
> "finished" and easy to use and reliable, unless it's infrastructure for
> the people working on other projects. Apache and gcc work great, because
> on top of *that* people can write code that you can sell without giving
> it away (like google does, in other words). But if you actually turned
> out a professional-quality piece of software that needed what it did and
> it had to work well, you couldn't make money off of maintenance. Hence
> the dearth of games, accounting software, user electronics, and so on.
Why in the hell would I ever want something that is "finished", in any
such sense. I want something where the stuff already "in it" is
reliable, but people are still looking at how to improve it. MS stuff...
The damn thing gets patched so often fixing things you never "see" that
a month after you install it the entire OS must have been replaced with
new binaries... Which means, most of it wasn't working quite right to
start with, and probably still isn't, even after being patched 500
times. By comparison, FOSS projects I use, usually, only send out
"stable" patches, or ones with "significant" changes, unless they, on
rare occasion, do have a serious bug, in which case it comes out,
updates without rebooting, (thought XP and Vista wasn't supposed to need
that BS so much any more?), remembers what it was doing before you did
restart the program, if you even did, and the patch comes out the moment
they have it, not a week later.
Either your argument is that FOSS is "just as bad" as MS stuff, because
neither is ever "finished", or your arguing that MS stuff is, because
they spend 5 years to come out with a whole new OS, instead of 2 months
to come up with a patch that adds some features. Either way, I don't
think its a winning argument.
void main () {
   else
Date: 30 Jan 2009 20:19:58
Message: <4983a73e$1@news.povray.org>
>> DirectX",
> Huh? How many programs have you written using DirectX9 and DirectX10?
> Why do you think the improvements are a mess?
Mess as in "a bunch of", not "disaster". Otherwise, I really don't care
what "special" BS MS gets to use, but no one else does, because everyone
added all the features to the cards/drivers, in a way that is unusable
to anyone that doesn't want to spend $2,000+ upgrading everything from
hardware and memory, to the OS, to run stuff it would be cheaper to buy
an XBox 360 to play.. Yeah, I "prefer" the changeability you get from a
PC platform, which is locked down on consoles, but not at the "cost" of
doing it, especially when nearly every dang thing for PC now is using
something like Steam, which defeats the whole fracking point of running
without internet, if you need to, and I am stuck with an OS I don't need
for "anything else" to do it.
void main () {
   else
Date: 30 Jan 2009 20:35:44
Message: <4983aaf0$1@news.povray.org>
> new binaries...
Oh, and FSM forbid they "ever" patch anything that isn't the OS to
something, unless the problem is so critical its crashing thousands of
corporate networks, never mind "adding" anything useful to it, including
fixing their documentation when its wrong.
void main () {
   else
Date: 30 Jan 2009 21:46:56
Message: <4983bba0@news.povray.org>
Um, no.  Zero problems with it.  Indeed, it's done *exactly* the same way
you do it in Linux.
Alternately, you can go and change your home directory setting in the
registry after you copy all the files over, and you're good again.
Since you haven't any idea how I moved things, I'm not sure what basis you
have for doubting it moved everything.
But OK, we get it, no amount of actual rational discussion will change your
mind about how evil Microsoft is or how sucky their products are.
So does Windows.   Not by default, but certainly if you use the more
advanced setting up options.
They don't optimize program access? It's been doing that since like Win 3.1
or so. What's "the other" you're talking about?
You've actually measured this scientifically, then?
   "Ouch ouch ouch!"
   "What's wrong? Noodles too hot?"
   "No, I have Chopstick Tunnel Syndrome."
Date: 30 Jan 2009 21:49:53
Message: <4983bc51$1@news.povray.org>
> such sense.
I dunno. My TV, Microwave, and automobile are all "finished".
They don't.
> Either way, I don't think its a winning argument.
Because you did not read what I actually wrote. That whole bit had NOTHING
TO DO WITH microsoft. :-)  But your hatred runs strong in you, so I'll just
drop it.
   "Ouch ouch ouch!"
Date: 30 Jan 2009 21:50:58
Message: <4983bc92$1@news.povray.org>
> something,
Huh?  You mean, like the way they don't patch Office, say?  Unless you ask
them to?
Uh, sorry. They add lots of stuff over time to *my* machine. Maybe you're
looking at the wrong update site.
   "Ouch ouch ouch!"
Date: 31 Jan 2009 02:49:34
Message: <4984028e$1@news.povray.org>
Darren New wrote:
> That kind of depends on whether you need the complicated bits, don't you
> think? The opposite of "unnecessarily complicated" is "lacking features."
Somehow they've managed to pretty far miss both with Excel - it can bend
to incredible counting pretty easily, but it's still easy to use for
just basic-level report creating etc. Word seems to "suck" more on the
easy part - sometimes it seems to miss a button that says "disable
automatics, forget styles etc, just let me do this damn 1-page document
quickly out of way).
> MS has some of the best documentation out there, and they teach classes
> in using their stuff. Just because you never learned it doesn't mean it
> isn't out there.
Excel is one of the very few graphical programs that I've actually had
help from the help system - because it's help documentation is freaking
good.
> Somewhat. Much of that is due to people not installing patches or people
> not using the system as designed.
And another much is just the users, which break the security of any
system :).
> Why is it that OpenOffice can't do something that Word can?
I think mostly because the developers haven't seen those features
necessary (at least yet) and not enough users have asked for them.
-Aero
Date: 31 Jan 2009 02:52:50
Message: <49840352$1@news.povray.org>
> And, if they where doing something more than just sticking the "shell"
> of this:
http://www.livescience.com/php/multimedia/imagedisplay/img_display.php?s=technology&c=news&l=on&pic=080324-aptera-car-02.jpg&cap=The+electric+hybrid+Aptera+(greek+for+%22wingless+flight%22)+is+a+3-wheeled+motorcycle+registered+with+DOT+and+the+California+DMV.+The+production+model+will+go+85+mph+and+get+300+mpg%2C+the+company+states.+Credit%3A+Aptera.com&title=
> on this:
> http://www.omnieye.com/mc/ad-pics/22140345.jpg
> I might be a bit more impressed. ;) lol
Yes, but that's you and me. Most people just take what comes with the
computer and those people mostly see the visual difference. IIRC OTOH
Darren has found some positive development from Vista comparing to XP.
-Aero
Date: 31 Jan 2009 02:59:21
Message: <498404d9$1@news.povray.org>
Since 2k Windows has supported mounting partitions to directories. It
doesn't come up on the normal installation, but wouldn't it be possible
to just mount another partition to C:\Documents and settings or
C:\Users? Of course using both styles makes it more complicated to
think, but I don't see why it wouldn't work just like mounting another
partition to /home in Linux.
> 3.1 or so. What's "the other" you're talking about?
Running defragger on Windows 3.1 sounds somewhat frightening.
Multitasking still sucked on Win3.1 (it existed, but it was veeeery slow
comparing to another implementations) and it certainly locked amount of
files while running. Running the defragger from DOS sounds more familiar
and sane.
-Aero
