POV-Ray : Newsgroups : povray.off-topic : new C# stuff Server Time
16 May 2026 06:39:17 EDT (-0400)
  new C# stuff (Message 24 to 33 of 43)
Subject: Re: new C# stuff
Date: 22 Jan 2009 16:13:31
Message: <4978e17b@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> Warp wrote:
> >   The benefit is that, at least in theory, the member function can be
> > dynamically bound, while the regular function can't.
> But not on an object that only occupies four bytes, which is your usual
> example. :-)
  Ok, if it takes 8 bytes, then it could have virtual functions. ;)
Date: 22 Jan 2009 23:56:46
Message: <1D437723C00B4A49991A466C4B99CA8F@HomePC>
> -----Original Message-----
> From: Warp [mailto:war### [at] tagpovrayorg]
>   In other words, you simply can write the same thing with a slightly
> different syntax, but otherwise there's no difference. I really fail
> to see the usefulness of this.
You're terribly correct, there is no use to this at all.  After all, the
following are all identical:
VectorAdd(v1, v2, &v3);
v3 = VectorAdd(v1,v2);
v3 = v1+v2;
Since there's no difference between them, the second two should just be
taken out completely, don't you think?
...Ben Chambers
www.pacificwebguy.com
Date: 23 Jan 2009 01:54:17
Message: <49796999@news.povray.org>
Darren New wrote:
> But yeah, it's syntax sugar, like overloading operators is.
And if anyone cares, here's a fairly complex query written in LINQ, in C#
with extension methods, and in C# without extension methods.
http://www.interact-sw.co.uk/iangblog/2005/09/30/expressiontrees
about 3/4ths the way down, after the text "A little further into the demo"
Pretty cool. Especially since there's an Expression.Compile() instance
method that will generate actual CIL code for a parse tree you created at
runtime. (A la http://www.jot.fm/issues/issue_2008_03/column4.pdf ). But
AFAIK, once you've created CIL code, you can't unload it, at least not
without dumping the whole assembly context, so it winds up being a sort of
resource leak if you do this dynamically too much. I've seen libraries to
manage this, tho, starting with multiple assemblies and dumping them when
they get full, restarting with new ones. Seems kind of kludgey.
   "Ouch ouch ouch!"
   "What's wrong? Noodles too hot?"
   "No, I have Chopstick Tunnel Syndrome."
Date: 23 Jan 2009 10:20:05
Message: <4979e025@news.povray.org>
> v3 = v1+v2;
  Ah, so this extension can be used for operator overloading in C#?
Nobody told me that before.
Date: 23 Jan 2009 10:34:14
Message: <4979e376$1@news.povray.org>
Operator overloading has existed since C# 1.0
I think the poster was trying to demonstrate a syntatic sugar feature
you may be familiar with and might like.
Rather than using, for example:
GraphicsExtensions.DrawButton(g, rcArea, caption);
You could define it so you simply type
g.DrawButton(rcArea, caption);
It just simplifies things a bit.
~Mike
Date: 23 Jan 2009 10:38:44
Message: <4979e484@news.povray.org>
  I was being sarcastic.
  And the demonstration was invalid.
  We are talking about "object.function()" vs. "function(object)", not
about "a+b+c" vs. "add(a, add(b, c))".
  I see no relevant difference to making a function so that you can write
"DrawButton(g, rcArea, caption)".
Date: 23 Jan 2009 10:45:29
Message: <4979e619@news.povray.org>
Except that in C# everything is defined in a class. So, if the function
is part of a library, you'd have to either define static methods or
instance methods. The Graphics class is sealed, so there's no means of
defining a sub class, such as GraphicEx ...so your choices are define a
bunch of static methods, or define a class whose constructor takes a
pointer to a Graphics object, and offers the extended functions.
C# 3.0 offers the extension methods to get around this. It may seem like
a pointless feature to you, but for some it is a minor convenience.
~Mike
Date: 23 Jan 2009 22:23:55
Message: <729ACF33ED7A4BBABC86F4948DA3EA48@HomePC>
Actually, it can't, but that's irrelevant.
You said:
"In other words, you simply can write the same thing with a slightly
different syntax, but otherwise there's no difference. I really fail to
see the usefulness of this."
In other words, you see no usefulness in having syntactic sugar.  I
think it's useful.
...Ben Chambers
Date: 23 Jan 2009 23:55:47
Message: <497a9f53@news.povray.org>
> think it's useful.
Especially when you want to chain methods together to make things work.
Writing
   myCollection.Select(...).Group(...).Transform(...).Sort(...).Output()
is a lot more clear than
   Sort(Group(myCollection.Select(...)).Transform(...)).Output()
just like writing
   cout << 123 << endl << mystuff.xyz() << endl
is more clear than
   cout.write(cout.write(123).endl(), mystuff.xyz()).endl()
or something like that.
Plus, it interacts with other syntax of the language that the compiler turns
into syntax like this. When your C++ sorting template has to know whether
the right call is myThing.compare(otherThing) or
MyUtil.compare(myThing,otherThing), it gets messy. That's exactly what this
is for, so it's pretty much just like what operator overloading is for.
   "Ouch ouch ouch!"
Date: 24 Jan 2009 06:06:55
Message: <497af64f@news.povray.org>
> think it's useful.
  No. What I said was that I don't see usefulness IN THIS CASE. The
difference is practically nonexistent. It's only in reordering of
names.
