POV-Ray : Newsgroups : povray.off-topic : Learning C++ Server Time
4 Jul 2026 19:51:56 EDT (-0400)
  Learning C++ (Message 21 to 30 of 57)
Subject: Re: Learning C++
Date: 12 Dec 2008 09:56:18
Message: <49427b92$1@news.povray.org>
Mike Raiford wrote:
> My first C program was a program that used the Windows API directly...
Same here.  I did allot of C programming using the Windows API, for
Windows 3.1, and then for Windows 95.  Back then, I was using Borland
Turbo C++, version 4.5.  Things have come a long way from those days.
Date: 12 Dec 2008 10:02:46
Message: <49427d16$1@news.povray.org>
Warp wrote:
>   OTOH one small problem with C++ is that there is no standard way of
> drawing any graphics.
That's been one of my major hang-ups with getting back into C++
programming.  That, and a lack of inspiration, as Darren currently has.
>   There are two popular 2D engine libraries for Windows which I know of:
> http://hge.relishgames.com/
> http://developer.popcap.com/forums/pop_index.php
>   You could consider this one too, which would make your program much
> more portable:
> http://www.libsdl.org/
I'm going to have to look into these myself.
>   You could try making DirectX or OpenGL code directly, but that would be
> even lower-level code, and might become a nightmare.
I've been overwhelmed by DirectX before.  It's not for the
faint-of-heart, or for someone relearning C++, as I was at the time.
Thanks for this post Warp.  It'll be helpful to me too.
Date: 12 Dec 2008 10:36:36
Message: <49428504@news.povray.org>
>  I once tried to look how I would create a simple dialog which contained
> some radio buttons, textfields and buttons directly with the Win32 API,
> and
> I was absolutely horrified at how horrendously difficult it is.
The only thing I ever do with the Win32 API by hand is to create a simple
window for applications that solely use Direct3D, it is just a few lines of
code and much faster and cleaner than using any IDE.
For a real windows-based application with textfields, buttons etc, you'd be
mad to try and code it by hand, unless you wanted to generate a load of
icons/text boxes algorithmically.
Date: 12 Dec 2008 10:37:40
Message: <49428544@news.povray.org>
  From what I have heard, DirectX 9 is much easier to use than earlier
versions. Same is probably true for DirectX 10.
Date: 12 Dec 2008 10:43:01
Message: <49428685@news.povray.org>
Warp wrote:
> From the example codes I have seen of the HGE
> library, it might not be the easiest possible to use either.
I wish I knew how to comment from an OOP background, but I've been
putting off learning about classes/inheritance/polymorphism until now :/
> more portable:
>   However, I unfortunately have absolutely no experience in using it,
I have experience with it, and I can tell you this: getting a reliable
VSYNC is difficult or impossible. I have looked high and low for a
solution. Either I didn't use the correct search terms, or there isn't
an obvious way to get a VSYNC with SDL on every platform. Most of the
discussion I found was of people having their frame rates capped between
60 and 100 FPS (monitor refresh rate), yet with the same settings I did
not experience an FPS cap in any way. I have been getting between
400-1000 FPS, which means there is no capping going on because I'm not
getting a VSYNC with my programs. This leads to ugly things like jerky
motion and screen tearing. I have a relatively new graphics card, so
outdatedness is not an issue.
> nor
> do I know how easy it is to integrate in Visual Studio.
AFAIK, SDL is easy to set up in any language.
> Being a C library
> it will most probably be of a much lower level library than an abstract
> high-quality C++ library would be, and consequently probably hard to use.
Most tutorials will hand you functions for drawing pixels/loading
images/drawing sprites/etc. on a silver platter.
Other than the VSYNC issue, another thing to consider when using SDL is
the speed at which it operates. Compared to DirectX or OpenGL, SDL is
slow. It's faster at drawing pixels, but slower at drawing sprites and
alpha blending. Forget rotating a sprite unless speed is not an issue.
You can mix SDL and OpenGL, but doing this multiplies the mass of your
code significantly. This is why I'm looking to OOP for answers. The
combination is faster than SDL alone, but you lose some SDL
functionality. But you gain better control over the VSYNC. You get to
rotate sprites, have alpha blending, all those great things.
Watch out for HGE. It may be fast and great, but it hasn't had a good
update for a while.
Sam
Date: 12 Dec 2008 10:45:34
Message: <4942871e$1@news.povray.org>
DX6 was a nightmare to use, DX7 got a *lot* easier, DX8 and 9 made small
improvements here and there.
The problem with DX10 is that there is no longer any fixed-function
pipeline, so you have to write all the vertex shaders (to handle world and
perspective transforms) and pixel shaders (to do lighting) yourself.  This
might be a bit overwhelming for a beginner.
If you were starting out, I'd recommend DX9 for sure, especially because as
a beginner you are unlikely to need any of the features of DX10 and DX10
won't run on XP.
BTW the documentation for DX9 is really good, plenty of tutorials and
samples building up from just drawing a plain triangle on the screen to lit,
textured more complex meshes.
Date: 12 Dec 2008 12:37:36
Message: <4942a160@news.povray.org>
Warp wrote:
>   Coding a small game is always fun, and a good environment for
I once made a Pong -clone with Pascal. It was very hard to beat the
computer, since I saved memory and used the same variable for the Y-axis
placement for computer player and the ball :).
-Aero
Date: 12 Dec 2008 12:46:32
Message: <4942a378@news.povray.org>
Invisible wrote:
> Question: Why is this undecidable?
It's due to a proof known as Matiyasevich's theorem which I'm not
familiar with the details of offhand.  The gist is that you can show
that every recursively enumerable set* can be represented as the roots
of such a polynomial.  Since there are non-computable recursively
enumerable sets there must be such polynomials (known as Diophantine
equations) which are not computable.
If you're interested in the details, this paper looks like it might be
useful, although I haven't read it myself:
http://modular.math.washington.edu/edu/Spring2003/21n/papers/hilbert10.pdf
If you're interested in the details, but less so, this is probably more
useful:
http://en.wikipedia.org/wiki/Hilbert%27s_tenth_problem
More intuitively, note that the problem statement come pretty close to
having Fermat's last theorem as a subproblem.
> Surely it's a trivial matter of iterating over all integers and testing
> whether any of them is a root?
If there is no solution to a given polynomial, when does this program
you describe halt?
* A recursively enumerable set is defines as any set for which these
exists an algorithm that will eventually list any number in the set, and
no numbers that are not.  Note that the algorithm is not required to
ever halt, so you can't , in general, be sure which numbers are not in
the set and which are in the set but it just hasn't gotten around to
listing yet.
An example of such a set which is not computable would be the set of
numbers corresponding to the binary representations of all programs
which eventually halt.
Date: 12 Dec 2008 13:05:43
Message: <4942a7f7$1@news.povray.org>
Nice!
~Mike
Date: 12 Dec 2008 13:07:15
Message: <4942a853$1@news.povray.org>
>> testing whether any of them is a root?
> you describe halt?
...so it's "undecidable" because you can't always figure out the answer
in finite time?
http://blog.orphi.me.uk/
