POV-Ray : Newsgroups : povray.off-topic : Haskell Server Time
16 May 2026 06:29:35 EDT (-0400)
  Haskell (Message 1 to 10 of 106)
Subject: Haskell
Date: 27 Nov 2008 22:21:34
Message: <492f63be@news.povray.org>
My impressions so far, to whom may concern:
I read a bit of http://haskell.org/ and from
http://www.haskell.org/ghc/index.html also downloaded and installed GHC
(400+ MB installed which I find great) but.... no IDE, to make libraries
and .dll u need this thing (can't remember the name) that need this
other thing (Cywin) to emulate a Linux enviroment and get compiled so it
can be used and the 'darcs' thing to do a kind of repository and the
other thing to do documentation...
I think all of them are goo ideas, what I don't like it is the PIA of
learn how to compile them, compile them, learn how to use it SEPARATELY
and finally start to gather all the DISPERSE tutorials and find what
BROKEN links doesn't show to stat learning the language. Which is not as
easy to read for non-experienced programmers, even the intro text said
it is, I understood better Rubi and Python (a Fibonacci example), wtf!
I'm not saying is hard but is not simple nor obvious, is something in
the middle I think. No doubt it's what I'm looking for in a language,
simple yet powerfull, but u need to go deep into it to learn how to make
fast and/or small .exe files that can compete with C.
In short: is a PIA that is worth suffering it, so I'm not going to quit,
I'm going to continue reading and searching and downloading and
searching some more other peaces as I need them along. I see this
project has come a long way for a freeware, powerful, very smart,
programming language but ir really needs to put things together (IDE,
GHC, the .dll/libraries making thing, doc making thing and darcs in a
funtional package ALREADY COMPILED) and have better support (too much
disperse info and broken links).
Any advise would be VERY WELCOME, thx for ur time.
Subject: Re: Haskell
Date: 27 Nov 2008 23:05:00
Message: <web.492f6dc41bbb3fc88a22ca50@news.povray.org>
Haskell is a language and they provide a reference implementation in the form of
a compiler, plus organized repositories of useful libs.  You choose to
write-compile-debug it in whatever you like best, be it notepad, emacs or
Eclipse, which are outside the scope of the project.  They don't have the
resources of Microsoft to bundle it together with an IDE and deep bindings to
native OS APIs...
Date: 28 Nov 2008 05:12:37
Message: <492fc415$1@news.povray.org>
I'm surprised that alone didn't scare you off! ;-)
It comes with lots of libraries. (Plus their documentation.)
I'm guessing you've got the brand new 6.10.1 release, which is
significantly larger than previous releases, because it comes with the
new Data Parallel Haskell library, plus the document generation tool
[which used to be a seperate download].
AFAIK, when you install a C compiler, you don't get OpenGL bindings, a
parser library, 4 seperate multithreading tools, a set of container
libraries, graph theory libraries...
> but.... no IDE
No, there isn't.
There used to be a Haskell plugin for something called "Eclipse", but
it's suffering from bitrot ATM.
> to make libraries
Ah yes... The Windows version of GHC actually uses the Cygwin POSIX
emulator. It also uses GCC (as in, the GNU C compiler), GAS (the GNU
assembler), and the Linux "ld" tool. And it uses Perl.exe. (??!)
Having just said all that, you shouldn't actually need to install Cygwin
just to compile pure Haskell libraries from source. I've never needed to.
I'm not sure if building DLLs is actually supported ATM... I know
they're working on it, but I don't know if it's functional right now.
Darcs is a source control system (like CVS is). It's very popular for
Haskell projects, since it's written in Haskell. Some programs and
libraries are distributed as "use Darcs to download the current souce
repository, and then compile it". Others are packaged and distributed on
Hackage, and you need to use Cabal to build those. (Cabal being
Haskell's home-grown package manager. Apparently they also translate
packages to various native Linux package formats too.)
Ah yes, Haskell's legendary documentation. It's scattered all over the
place, half of it is published as academic papers that you and I can't
access, much of it is written for compiler designers and academics
rather than actual *programmers* who just want to know how to use the
thing, and lots of stuff isn't documented _at all_.
For example, laziness can be a bad thing. This is highly non-obvious,
and it ISN'T EXPLAINED ANYWHERE. If you pop into the IRC channel and ask
about it, somebody will explain it. But then it's *still* not written
down for the next newbie who wants to know. It's sort of an oral
tradition; there are many "well known" techniques, but nobody has
written any of this stuff down anywhere, making it infuriatingly hard to
learn about this stuff.
...which neatly demonstrates my point. Programs compiled with GHC
contain C debugging symbols by default - even though these are
completely useless in a *Haskell* program. By using a special
command-line switch, you can "strip" the symbols, making a typical
program about 200KB smaller. But this isn't written down anywhere; I
found out about it by chatting to people on IRC.
And yes, Haskell is designed for writing complex algorithms easily. If
you want *speed*, it's very non-obvious how to do this. There is some
scattered documentation about it, but currently the most expedient
method is to post the source code and ask Don to look at it for you. ;-)
> In short: is a PIA that is worth suffering.
That pretty much sums it up, yeah.
FWIW, getting libraries and stuff to work tends to be far easier on
Linux. (E.g., there are packages which require Automake and Bash scripts
as part of their build process... Because, *obviously*, all coding
happens on Linux, right? Right??) Us Windows users tend to be the poor
relations; even Mac OS has better support!
You might try looking through this:
http://book.realworldhaskell.org/
It's the website for a book that just got released and is meant to
explain all this stuff - not just the language syntax, but how to work
the compiler, what the best coding strategies are, etc.
I must say, I was very excited about this book, but having actually read
it now it's out, I'm dissapointed. Still, it's a single *large*,
coherant body of information, all in one place. That's a step in the
right direction...
> I see this
The *language* is fantastic! It's the other stuff that needs to go with
a language, such as...
...exactly.
Date: 28 Nov 2008 05:55:03
Message: <492fce07$1@news.povray.org>
>> but.... no IDE
> No, there isn't.
...unless you count the "Haskell mode" for emacs. :-P
Date: 28 Nov 2008 07:05:22
Message: <492fde82@news.povray.org>
  It depends on the C compiler. Some come bundled with OpenGL libraries.
> a parser library, 4 seperate multithreading tools, a set of container
  C++ is a bit better in this regard. Just because of the C++ standard,
compilers have to come with tons of libraries. And often they come with
tons of third-party libraries as well (eg. the boost library collection
is usually bundled with most linux systems alongside gcc).
  I think one of Haskell's major problems is that nobody has made an
advanced compiler for Windows, and the existing Haskell compilers only
rely on inconvenient cygwin ports.
Date: 28 Nov 2008 07:36:06
Message: <492fe5b6@news.povray.org>
Certainly the C++ containers library seems quite nice.
The thing is, the collection of libraries that come with GHC is...
pretty random, actually. E.g., there's a library for OpenGL, but there's
no GUI library (and hence no way to *use* OpenGL).
Well, the Windows version of GHC is maintained and tested by the core
GHC development team. (And, for example, it comes with bindings to the
Win32 API - incomplete though it is.) And the Cygwin thing isn't as
inconvenient as it sounds... but yeah, this really needs to change.
Apparently a long-term goal is to remove the C compiler completely, but
the internal code generator needs improving first. It's a long-term
project that they've been working on for years, but there's no much
visibly happening at the surface on this particular work item.
Of course, this is an open-source project. I suppose if it annoys me so
much, I should go fix it myself.
I mean, as if I could *ever* do something like that...
Date: 28 Nov 2008 11:28:23
Message: <49301c27$1@news.povray.org>
Warp escreveu:
Why should a compiler project package together other project's
libraries, specially ones that are likely to be found on the host system?
The situation with Haskell is different:  it doesn't come with "opengl
lib", it comes with a Haskell binding to opengl. C/C++ doesn't need
this, as it's perfectly fine calling the lib functions in the very same
syntax and calling conventions they were written in.
Date: 29 Nov 2008 20:33:38
Message: <4931ed72@news.povray.org>
Thx for the advise, I see I'm not alone in my POV (Point of View) and I
also see my common sesnse isn't far from the truth as I thought.
I thank everyone who cared on guiding me in this long Haskell road I
just started to crawl.
I have read in the Haskell site that the best way to learn Haskell is
from a book, so I've downloaded a couple (don't ask from where since
those are illegal ways, I have to, my salary is 180$us a month, I hope u
can understand if not well, I have no other choice) also Haskell98, the
most recent manual and other .pdf files and in other formats.
Also I've come aware of Leksah and how to COMPILE(darn) it. The screen
shots were from a Linux version (how convenient... for them! :D ).
I hope Haskell gets better soon, it has a SPECTACULAR FUTURE.
Well, I think I can raw my boat alone from here, again I thank you for
ur help. God bless you all.
Date: 30 Nov 2008 20:42:30
Message: <49334106@news.povray.org>
>God bless you all.
To each his own, but no matter how many times I see or hear about the
apparently happy coexistence of blatantly conflicting ideologies within
people's minds, I cannot but grin.
Date: 30 Nov 2008 20:53:59
Message: <493343b7@news.povray.org>
To each his own, but no matter how many times I hear monotheists assume that
everyone referring to god must intend that monotheist's interpretation of
their own god's holy scriptures, I have to grimace.
Me, I think Pan and Loki would both be proud.
   The NFL should go international. I'd pay to
   see the Detroit Lions vs the Roman Catholics.
