Warp wrote:
> The problem is that I don't want to "hover for a bit" or make an extra
> click to show the full menu.
You are aware you can turn this off, right? It's some click-box in the
options stuff.
> If I have used a menu a lot, I remember from
> heart where those most used menu elements are, and selecting is usually
> a question of click+drag+release. A menu which changes contents and doesn't
> even show all the options and where the options I use change locations
> completely defies this and is one of the most annoying things ever.
I'm assuming you're talking about Word or some such here? If not, which
are you speaking of? I've not been bothered by menus reordering
themselves, but maybe I haven't run into it. Things showing up and
disappearing, or different sets of menus being available depending on
what you're editing, yes. But not arbitrary reordering.
> Do you know what I hate in Firefox? The damned changing context menu!
> It drives me crazy. Whether or not the first element is "back" depends
> on where you click! It's annoying as hell.
That's kind of the point of a "context" menu, tho. :-)
>> And I still miss the Smalltalk technique of bringing up the pop-up menu
>> such that the previous thing you selected is selected again for you. :-)
> That could also become annoying if you are accustomed to click + drag a
> certain amount + release, to select an option you use a lot.
Sure, I suppose. I find that kind of menu always has my mouse sliding
off the edge of the desk, tho, when I'm doing something repetitive. I
guess if you're used to one way of working, another is going to annoy
one until one gets used to it. Sounds like you have better mousing
precision than I do. :-)
Not that much.
There's another very annoying feature which, as far as I remember, they
changed in Windows95 (or Windows98) compared to Windows 3.x: In the latter,
if you had a menu with a submenu, you would click on the menu element for
that submenu, and then it would open the submenu to be on the side of the
parent menu and, most importantly, it would *keep it open* until you select
something or click somewhere else.
In Win95 (or something) they changed this behavior to be much, much worse:
Now the submenu opens by simply hovering the menu element (not that bad in
itself) but if you unhover that element, it *closed* the submenu. There's
no way you can keep the submenu open other then carefully keeping the mouse
hovered on that parent menu element while you move it towards the submenu.
This is extremely annoying and irritating because it requires really precise
mouse handling to not to unhover and thus unintentionally close the submenu.
It can be difficult even to me, an experienced computer user. I can only
imagine how difficult it must be eg. for the elderly or people with
impariments.
The worst of all? Everybody has copied Microsoft on this! Now you can see
that braindead behavior everywhere. Even this KDE has it. It's annoying!
On Mon, 03 Nov 2008 09:44:10 -0800, Darren New wrote:
> Invisible wrote:
>> The new-style start menu is just horrid. Each time you use a different
>> program, the order of the icons on the start menu changes. Horrid,
>> horrid, horrid! >_<
> Heh. I like it.
GNOME does this sort of thing as well with the Computer menu - favourite
applications/documents with a "more" option (which shows a fixed list).
I've got that along with the traditional GNOME menu, but I tend to use
shortcuts on my panel or alt-f2 (equivalent of "Start->Run") most of the
time, or launch from a console window. :-)
Jim
I'll second that. I often use the keyboard on long nested menus just for
that reason.
That's another part of the kill. MS spends bunches of money testing this
sort of stuff, so everyone assumes they should copy it too.
Altho I will say, a lot of the vista visual tweaks seem very nice as
well as subtly useful. Not that I've more than a couple hours experience
with trying to get it all set up the way I want. :-)
Invisible wrote:
> You jest, but I believe several companies are making serious moves in
> this direction. The idea is that the "software" exists on their servers,
> and is never installed on your machine, and you "rent" the right to
> access this software for X days for a given fee.
Web apps are an experiment for that: same concept, only free. The only next
step is start charging.
I hate web apps.
> see
Websites with fancy navigation menus copy it *and* don't even implement a
delay. Everything is instant. Move mouse over a submenu and it INSTANTLY
shows it (closing the other).
I take it you haven't used a commercial web-app. Like salesforce.com for
example. :-) It's not the next step, it's the previous step.
> next step is start charging.
"Software as a Service" or SaaS.
Jim
It's not the worst. The worst is that no system equipped with this
feature offers no choose. You can turn off XP's personalized menus. You
can turn off XP's new start-menu. AFAIK you can do the same on Vista.
But you *can't* turn off that submenufeature.
Once again, Afterstep <3. If you'll click on submenus headerbar, it
becames own window and stays there until you close it. Yep, you can even
click 10 Xterms open at the same menu.
-Aero
Sure I haven't... What *is* salesforce?
