POV-Ray : Newsgroups : povray.off-topic : Linux really costs a _lot_ more than $40 Server Time
5 Jul 2026 03:43:22 EDT (-0400)
  Linux really costs a _lot_ more than $40 (Message 101 to 110 of 189)
Subject: Re: Linux really costs a _lot_ more than $40
Date: 2 Nov 2008 13:32:27
Message: <490df23a@news.povray.org>
Jim Henderson wrote:
> Yeah, I've read a few stories about the newest Ubuntu (8.10 IIRC)
> delivery that state that the benchmarks are slower than the previous
> version.
OTOH, I read about a developer who quit contributing to the Linux kernel
because he was tired about devs caring about companies saying
$BULLSHT_BENCHMARK now gives lower results, instead of caring about the
desktop becoming faster for users. (it was about lowering latency and
improving the process scheduler, which would give better speed to the
desktop)
Date: 2 Nov 2008 14:36:07
Message: <490e0127@news.povray.org>
>> JUst a thought, does the device have a SSD drive in it?  Or does it run
>> completely over the network?
> Completely over network. It's a low-budget system, built from leftovers
> - AMD Athlon 1,2GHz, 768MiB, Matrox G400 16MiB, Intel EtherExpress
> Pro/100+, some random case, Gentoo Linux. The PSU still makes slight
> noise.
Cool, I've been thinking about putting a system like this together, this
is a useful parts list. :-)  How's it work for you?
Jim
Date: 2 Nov 2008 14:37:44
Message: <490e0188@news.povray.org>
On Sat, 01 Nov 2008 22:21:15 -0700, Darren New wrote:
> Well, it asks once per process you invoke with admin rights, just like
> sudo.
That wasn't my experience - or rather, once per program wasn't my
experience.  This was pre-Vista SP1, though, so it's very possible the
behaviour changed at that point.
Jim
Date: 2 Nov 2008 14:38:20
Message: <490e01ac$1@news.povray.org>
>> version.
> desktop)
I hadn't read that one...
Jim
Date: 2 Nov 2008 21:55:00
Message: <web.490e67be769b32302060de5d0@news.povray.org>
> > sudo.
Nope.  Every damn time you open the same program...
Date: 2 Nov 2008 22:57:25
Message: <490e76a5$1@news.povray.org>
>> > like sudo.
Well, that's what I meant.  I had situations where it asked me two and
three times about specific things the program wanted to do (like VNC).
Jim
Date: 3 Nov 2008 10:36:29
Message: <490f1a7d$1@news.povray.org>
That would be "once per process", where "process" is used in the
technical sense there.
I'll be installing VNC, so I'll see. Of course, if you know it's going
to do this, you can start it with rights in the first place, but that
doesn't help the first times you run it. I'm still working on getting
everything set up the way I want it, so I haven't gotten very far in the
process of being annoyed by Vista yet ;-)
Date: 3 Nov 2008 11:45:38
Message: <490f2ab2$1@news.povray.org>
I probably mentioned it before, but my annoyance at Vista was pretty
extreme - was pulling video off my DVR via firewire, and silly me, I
thought I could run it headless.  Disabled the firewall, UAC, installed
TightVNC and set it up to autostart, set up autologin, background to
solid black...everything was perfect.
Rebooted the system and it started as expected.
Shut down, took the system to the room with the TV and plugged it in.
Powered it up.
Couldn't connect to it remotely via VNC.
Eventually went and got a keyboard and monitor and plugged in - Vista had
reverted *every* *damned* *change* *I* *made*.  I'm surprised it didn't
uninstall TightVNC.  But sure enough, UAC enabled, autologin turned off,
background restored, firewall reenabled - all of it.
That's the last time I ran it.  Well, no, tell a lie, I installed the 64-
bit version in a VM so I could extract the wireless drivers for the
wireless NIC in the machine using ndiswrapper - HP very *helpfully*
requires that you use the actual OS the drivers are written for in order
to extract them.  I wasn't real happy about that either.
Jim
Date: 3 Nov 2008 11:56:55
Message: <490f2d57$1@news.povray.org>
Darren New escreveu:
>> What really annoys me the most is that I'm quite sure I turned the
>> damned UAC feature off...
> I believe you. I don't have a whole lot of experience with it yet. I
> just have to say it hasn't annoyed *me* yet, except for the broken
> software crap that came with the computer.
Hmm, odd.  I'm seeing html sources on IE7 with notepad just now without
problems or questions.  I took a look at my UAC, and it was ON!  It's
more schizophrenic than I thought!  It's now faking to be a fine OS... :P
Ok, once I installed Firefox, I haven't used IE in a while.  I only
really used it in the first few days post migration.  Perhaps SP1 did
improve things a bit, I guess...
Our memory can betray us sometimes.  :P
Date: 3 Nov 2008 12:37:44
Message: <490f36e8$1@news.povray.org>
Weird. I've occasionally had it happen where it "couldn't load my
profile" when I remote loggined, leaving me with everything as if I was
logging in for the first time. But logging out and logging back in
always fixed that. I figured a temporary timing failure somewhere.
> HP very *helpfully* requires that you use the actual OS the drivers are written for
in order
> to extract them.
The abusiveness of HP's "rescue disks" are one of the many reasons I no
longer will buy any HP machine. :-)
