"Darren New" <dne### [at] sanrrcom> wrote in message
news:48e3a9aa$1@news.povray.org...
> Gail wrote:
>> Yes. 32 and 64 apps running fine. That's games, graphics stuff, dev
>> stuff. I've had no problems with apps at all.
> Good to know. I was just thinking about how I'm going to upgrade my aging
> machine.
I have however had problems with drivers, even ones that are supposed to
work on Vista 64.
Ever since I installed the wireless network card and drivers, my machine
frequently hangs on bootup. They're supposed to work, but I get the feeling
it was a half-done job for an older card.
> Has anyone used an XBox as a media center extender on Vista? I've still
> got an N64 and a 15-year-old TV downstairs. Time to upgrade that too
> maybe.
No. On my list of things to do is to 'persuade' the Xbox to talk to the
Server 2003 machine.
Gail wrote:
> Do you, by any chance remember what a single beep signifies?
> I'm getting it intermittently from one of my machines on startup.
Depends on the motherboard. On most "modern" systems that don't have a
POST beep, it usually means the BIOS has a message on-screen. it could
be as simple as a keyboard error, or something like a message stating
the processor was overclocked too much (Yes-- I've seen it, no I didn't
overclock, I think CMOS memory got junked somewhere along the way.)
But, check with the OEM or board manufacturer for any codes.
Of course, on some systems there's a beep on start-up if everything is
fine.
~Mike
Wireless seems to be a bugaboo for everyone, which is rather surprising
to me.
Interestingly (at least mildly so), my machine has been hanging trying
to log out, with some compute-bound process locking up for 2 or 3
minutes when I log out. I finally got around to replacing a failing DVD
drive, and all of a sudden, it's not failing again. I wonder how much of
the "My Windows slows down over time" kind of complaint is just hardware
that's wearing out and causing hangs during retries in places where the
kernel really doesn't need to be waiting for retries.
"Mike Raiford" <"m[raiford]!at"@gmail.com> wrote in message
news:48e63bfd$1@news.povray.org...
> POST beep, it usually means the BIOS has a message on-screen. it could be
> as simple as a keyboard error, or something like a message stating the
The screen's black at the time, so no message
Intel board, intel processor.
I'll search their site, see if anything comes up. I should have the manual
for it somewhere.
> fine.
This is intemittant, so...
Gail wrote:
> Not fun.
> Worst I had was not seating the CPU properly then switching the machine
> on. The system did nothing. No beeps, nothing on screen, zip.
1999 oslt, I had just fried ~half of my summer-job payment to new
hardware (AMD K6-2 350MHz, MoBo, 128MiB SDRAM DIMM etc). I carefully
loaded the set to my case, checked everything and re-checked everything.
I flipped the switch and the light at the ceiling of the room came out.
That kind of... hmm.. freaked me out a bit.
Eero "Aero" Ahonen
http://www.zbxt.net
aer### [at] removethiszbxtnetinvalid
A peace of advice:
1) You may want a 64-bit Windows, if u r gonna use Windows, on 4G system
since is a tricky business to get Windows XP/(maybe Vista) 32-bit to
recognize 3+ GB of RAM even 2+ GB 'coz of the PAE (Physical Address
Extension) support on motherboards and their ability to successfully
remap hardware addresses above the 4 GB limit and keep device drivers
still working properly.
2) Don't forget to buy memory modules in even pair(s) to enable
Dual-Channel and Dynamic Page mode on a Intel platform.
Here's what I ordered today:
* Intel Core 2 Quad Q9550
* Xigmatek HDT-S1283 CPU cooler
* Asus P5Q-E motherboard
* Corsair 4GB DDR2 800
* 2x Seagate Barracuda 7200.11 1TB 7200RPM drives (for RAID1 configuration)
* Asus EN9800GT video card
* Samsung 22X DVD burner
* Antec Three Hundred case
* Antec 850W power supply
* Samsung 2232BW+ 22" LCD
* Window Vista Ultimate 64-bit
It should be pretty sweet, so long as everything plays nice together. We'll see when
it all gets here...
when it all gets here...
It looks like you are going to have a bit of fun ;-)
I can take that comment both literally and sarcastically, as it will likely be true in
both instance. :-D
I am not a big fan of the Three Hundred. It may look nice on the outside,
but it can be rather awkward when you actually try to mount things inside
it. Antec cases are usually good, but this one seems almost deliberately
poor.
FE
